  1. Dec 8, 2024 at 10:34 AM
    ParksGoddess
    ParksGoddess Member
    Lara
    2021 Cement TRD Off-road
    I’ve had my Tacoma for a week and a half and so far, I’ve blacked out my chrome badges, tinted all the windows except the sunroof (the windshield got an eyebrow!), bolted on my friend’s old stock running boards, and ordered my Bilstein 6112/5100 lift kit. Once my Taco is lifted, I’ll be switching the tires to the 285/75/16 KO2’s from my Frontier, since they have less than 10k miles on them.
    I have to edit my post to add the DD SS3 Sport fogs I picked up for $100 & raptor lights.
  2. Dec 8, 2024 at 10:45 AM
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    Your going to have rubbing issues with those tires on those wheels. Switching to zero offset wheels(or using spacers) and doing some clearance work will be required and you may still rub under some situations without a cab mount chop.
    BC Hunter and Canadian Caber like this.
  3. Dec 8, 2024 at 11:00 AM
    OscarWildwood
    OscarWildwood Well-Known Member
    Jay
    2023 Ice Cap Tacoma SR5 DCSB
    Installed DD SS3 max fogs with the less popular white lenses that I got for BF from Hotshot Offroad. I still need to adjust them lower I believe when I have time.
    2025 Wish List:
    -TRD engine skidplate
    -OEM LEDs (maybe customized?:confused:)
    Bonus picture while in the garage:
    -2024 MO buck skullcap. Soon to be on a wooden plaque.
  4. Dec 8, 2024 at 11:29 AM
    SteveB313
    SteveB313 Well-Known Member
    Detroit
    20 Tacoma TRD OR blackout/MGM, dbl-cab, AT3W’s
    Crawled underneath to find my 2020 is completely zerk-free, all joints sealed, rolled back out from under, threw Sta-Lube Sta-Plex Extreme Pressure Premium SL3190 Red Grease back into Amazon box, drove to UPS to return. Spent my spare 8 minutes smiling and nodding at truck.
  5. Dec 8, 2024 at 12:16 PM
    bc.trd
    bc.trd Active Member
    Alignment went well, the tech advised to get UCA for more caster because 285/70/17 would rub the cab mount when I get them mounted on some wheels after winter. Sitting within spec. Tracks straight no rub. So I scored a set of brand new open box OME UCA on eBay for 400 bucks. Added a 1 inch block to the back. And a carrier bearing drop I had laying around from my old Tacoma for reassurance. Will do an AAL in spring. For now block was readily available so I threw it on.
    My DD SS3 Pros will go in tomorrow.
  6. Dec 8, 2024 at 1:31 PM
    spin180
    spin180 Well-Known Member
    WNC
    2022 Army Green TRD Off-Road DCSB
    All I want for Christmas is my two front teeth.
    TT005, SoCal_Erik, wcoffman and 6 others like this.
  7. Dec 8, 2024 at 1:33 PM
    bryan83taco
    bryan83taco Well-Known Member
    Hawai’i
    2023 TRD Sport 4x4
    Garage door opener installed on OEM style switch.
  8. Dec 8, 2024 at 1:35 PM
    bryan83taco
    Hawai’i
    2023 TRD Sport 4x4
    This is perfect. I miss this cubby from my old 2nd Gen. I'll be doing this soon. Where did you source the cubby?
  9. Dec 8, 2024 at 1:38 PM
    ParksGoddess
    ParksGoddess Member
    Lara
    I already have the plates for the CMC & a shop that’ll do it for me. Planning on spacers too, but I know very little about them, as far as what’s good & how thick I will need.
  10. Dec 8, 2024 at 1:40 PM
    Pwakchop
    Pwakchop Well-Known Member
    Nate
    Georgia
    2021 Cement DCSB TRD Sport
    Whole lotta' momentum
    :annoyed:
  11. Dec 8, 2024 at 1:48 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
  12. Dec 8, 2024 at 2:00 PM
    topochico23
    topochico23 Well-Known Member
    2022 DCSB SR5 V6 4x4
    Cargo net from our Highlander + $2 spring clip/carabiners from the hardware store. To hold my delicate bed cargo after shredding the gnar in some mall parking lots.
    Dam325, indoomitable, RIX TUX and 5 others like this.
  13. Dec 8, 2024 at 2:19 PM
    SGalvanNerd
    SGalvanNerd Well-Known Member
    This is nice
  14. Dec 8, 2024 at 2:29 PM
    cleetus33
    cleetus33 Member
    cleetus
    Illinois
    2023 Sr5 SX
    Had a bunch of trees come down, time to load up
    spin180 and andthen like this.
  15. Dec 8, 2024 at 2:46 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Um, pretty sure this is not possible. Cam timing is not electronically controlled, it uses hydraulic pressure from the oil. There is nothing the computer can do to change cam timing. VVT-iE is a thing, but not on our engines.
  16. Dec 8, 2024 at 3:26 PM
    -Rorschach-
    -Rorschach- The Black Helicopters are coming…I gotta go!
    2019 Silver Sky Metallic Tacoma DCLB TRD OR 4x4
    Got a new battery last week and have only had a few short trips, so I hooked it up the the Battery Tender to top it off before the cold sets in for good.
    Also notice a little rust on the battery hold down, hit it with a wire brush, a little OSPHO, and finally some touch up paint.
  17. Dec 8, 2024 at 3:35 PM
    Dmesser92
    Dmesser92 Well-Known Member
    Dylan
    Easley, South Carolina
    2023 Tacoma SR AC V6 4x4 | 1991 Toyota Pickup 4x4 DLX V6
    Out of curiosity, why did you switch from a Frontier to a Tacoma?
    robin303 likes this.
  18. Dec 8, 2024 at 3:42 PM
    dryheat
    dryheat Well-Known Member
    Which brings everything else said about tunes for the past few pages into question
    Suggestausername and robin303 like this.
  19. Dec 8, 2024 at 4:30 PM
    ParksGoddess
    ParksGoddess Member
    Lara
    I drove my 2006 Frontier for over 18 years and put 250k miles on it. She was a good truck until everything started breaking all at once. My best friend has a 2019 TRD OR, so I learned quite a bit about Tacos and all the fun things you can do to them. I didn’t want to get another Fronty of the same generation and I’m not a fan of the 3rd gen body, so I got a Tacoma! Love it!
  20. Dec 8, 2024 at 4:40 PM
    sarcastictechsupport
    sarcastictechsupport Well-Known Member
    SoCal (805) - Mohave Desert
    2020 Super White TRD OR
    Out with the old
    In with the new
    Also helping my husband mount some tires on his new rims for his Jeep. It’s now
    his (in the process of being mounted)
    and hers
    TT005, Dam325, MrMustacho and 11 others like this.
