  1. Dec 12, 2024 at 1:54 PM
    Jim727386
    Jim727386 Well-Known Member
    Jim
    Enjoying Floridays
    2023 SR 4x4 V6 DCSB
    Plain Jane - Bare bones
    Returned the Rough Country tonneau cover that didn't fit. Looking at Real Truck Truxedo now. Making sure I get full refund from RC, first.
    spin180, Stuck in VT and MiTacoTRD like this.
  2. Dec 12, 2024 at 1:59 PM
    unclewede
    unclewede Well-Known Member
    'Nard
    23 TRD Sport 4x4 Lunar
    It only has 71K? I bid $27.
    RIX TUX likes this.
  3. Dec 12, 2024 at 2:00 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    72k miles plus change ... no more than $25. And he runs it at 65 MPH ... merciless!
    unclewede[QUOTED] likes this.
  4. Dec 12, 2024 at 2:33 PM
    MrMolotov
    MrMolotov Well-Known Member
    Ples
    2022 Tacoma SR5 4x4
    None
    Ya I bet. I'm going passenger side, there's a nice area to bolt to, but I have to get more 7AWG to extend it to the battery. Should be here tomorrow, then I'll know. Plus, I have extra subwoofer power supply on driver side making it even tighter.
    azhiaziam[QUOTED] likes this.
  5. Dec 12, 2024 at 2:48 PM
    17taconut
    17taconut Well-Known Member
    Dave
    Baltimore, MD
    2017 Quicksand Tacoma Off-Road DCSB
    Good luck, have the same setup. Check out the Auxbeam forum, under the Lighting forum for help.
    wradar likes this.
  6. Dec 12, 2024 at 3:28 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    wradar likes this.
  7. Dec 12, 2024 at 6:22 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    You forgot to put the 2nd lock washer ring on under the nut and if the nut giggles loose, the switch is gonna fall out of reach. Also, is it on a fender or other location prone to weather? Well that’s not a waterproof switch - just saying. Get one that is coated and has a neoprene cover on it, else one day you’re not gonna be able to start your car because the switch is not going to work.
    https://www.amazon.com/dp/B07B6K6XC1
  8. Dec 12, 2024 at 7:19 PM
    r_ben65
    r_ben65 Well-Known Member
    Robert
    2023 TRD Off-Road Lunar Rock
    Exhaust reroute, cargo mat, WeatherTech side window deflectors, glove box and center console organizer. RCI steel skid plates (engine, transmission, transfer-case, catalytic guards, fuel tank and differential), Total Chaos Bed Stiffeners, RCI rocksliders, Power Tray and Switch Pro, Taco Vinyl Pro Grill, Diode Dynamics SS3 amber fog lights. Powerbrake D-Line Disc & Pad kit, Fox 2 inch lift kit with 2.5 coil-over, Taruca Rogue 270 degree XC awning, Four Wheel Campers Project M, CBI Baja Front Bumper, Warn VR EVO 10S winch, Baja Design OnX6+ 20 inch LED Light Bar, WeBoost, Diode Dynamics SS3 Ditch Lights, Prinsu Pro Roof Rack with Heretic 6 series 40 inch light bar
    Paying off the truck way ahead of time.
  9. Dec 12, 2024 at 8:10 PM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Best mod ever!
    Tacosha likes this.
  10. Dec 12, 2024 at 8:30 PM
    uhchxrlie
    uhchxrlie Well-Known Member
    2020 MGM Tacoma SR SX Package
    RichMTB01[QUOTED] likes this.
  11. Dec 12, 2024 at 8:31 PM
    BTWNaRock&aHardplace
    BTWNaRock&aHardplace Well-Known Member
    DW
    47°47’47”N 123°41’41”W
    2022 TRD
    a cb radio and 2 baby seats
    I almost changed the oil! Might have been the 3rd or 4th time I have opened the hood since I bought it…in December of ‘21. Wow lots of metal under there but I think I found the filter. Learned the new one comes with o rings! Yea. Then I learned it wants 6qts!!!! I only bought the 5 jug. Glad I never pulled the plug… TBC
  12. Dec 12, 2024 at 9:14 PM
    RichochetRabbit
    Get a Motivx adapter ... grips the filter housing at the strongest point: https://www.motivxtools.com
    The o-ring on the side of the housing is what you need to watch for. The ring must fit into the groove on the side ... putting a coat of oil on the side where the o-ring brushes against the side when screwed in help to prevent the ring pulling out ... that is the greatest risk of causing a leak after install.
    Fumoto valve replaces a simple plug ... hot oil will flow out like a bitch when a bolt is removed, but the Fumoto allows controlled release of the oil and attaching a tube to redirect the oil out-flow: https://www.fumotousa.com/cars-pickups-toyota-2022-tacoma-3-5l-v6
  13. Dec 13, 2024 at 5:45 AM
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Looks great..
  14. Dec 13, 2024 at 10:12 AM
    Shawgf2000
    Shawgf2000 Well-Known Member
    2018 Silver TRD Off Road
  15. Dec 13, 2024 at 10:58 AM
    Cheesetoast
    Cheesetoast Active Member
    Dale
    SoCal
    2023 TRD off-road 4x4 DCSB
    OTT Tune
    congrats!!
    DavesSR5 likes this.
  16. Dec 13, 2024 at 2:47 PM
    OnHartung'sRoad
    Custom molle side window rack/fold out shelf (paint is drying- will post shelf down later).
  17. Dec 13, 2024 at 4:50 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    I got a shake in the steering wheel when on highway and tap or apply full brakes. Since my tires are less than 5k old, I'm going to get my rotors turned see if that eliminates shake. What do you guys reccomend, turning, or new rotors, at 69539 miles on truck?
  18. Dec 13, 2024 at 5:08 PM
    RockBunny
    RockBunny Well-Known Member
    Northern NH
    22 LunarTRD DCLB Sport
    I always buy new rotors because warped is warped.
    My 3rd gen. 4runner went thru rotors like you wouldn't believe. Finally upgraded to 1st gen Tundra calipers and rotors. Much better.
    drizzoh, Ngneer and thomasburk like this.
  19. Dec 13, 2024 at 5:22 PM
    OLDTRAP
    OLDTRAP Well-Known Member
    2021 TRD OR
    Stock
    Buy new one's, in pairs. One and done.
    thomasburk likes this.
  20. Dec 13, 2024 at 5:51 PM
    switch
    switch Well-Known Member
    Norther California
    2022 Tacoma Access Cab
    I took the 33" BFG MT wheels/tires off and put on the 35" BFG AT wheels/tires. I removed the water tank, awning, and entire Yakima roof rack; then I removed all of the camping gear and replaced it with ski gear. Thus completing the transformation of my Tacoma from Summer camping mode to Winter skiing mode.
