  1. Dec 13, 2024 at 6:43 PM
    Ejctt
    Ejctt Well-Known Member
    2023 White Tacoma Off-road
    Finished a big project today. I never used the wireless charger so it’s gone, replaced with a voltmeter and a scan gauge. @Taxx 3d printed the mount, modified from his project. I installed the scan gauge and meter in the mount. Also installed footwell lights from Vled, a custom Molle panel on the center console, two usb plugs (one in the back seat center console and one in the driver’s center console), and added leds in the Molle panel. I have been working on it for about a month. I’m happy with the results.
    Thanks again @Taxx
    kas2828, E.T., d0ugh0ck and 30 others like this.
  2. Dec 13, 2024 at 6:44 PM
    PondScum
    PondScum OG 303
    Colorado
    2023 Trail Edition
    6112/5160, Deaver J66, Wildpeaks, OTT, Sliders, Armor
    Badass!
    Hotwheels85 and Pinchaser like this.
  3. Dec 13, 2024 at 6:49 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    X2
    Ngneer, Hotwheels85 and Pinchaser like this.
  4. Dec 13, 2024 at 7:04 PM
    switch
    switch Well-Known Member
    Norther California
    2022 Tacoma Access Cab
    If you like your VLED footwell lights, it is super easy to add puddle lights on the bottom or yours doors using a few more parts from VLED's website. I wrote that up here:
    https://expeditionportal.com/forum/threads/switchs-2022-tacoma-access-cab-build.233840/post-3165469
    And BTW, nice use of that space in the center console!
    stealthmode and dryheat like this.
  5. Dec 13, 2024 at 8:05 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    slowly close the hood and back away from the dangerous mechanical piece of technology
  6. Dec 13, 2024 at 8:46 PM
    MrMobile
    MrMobile Well-Known Member
    Greg
    Colorado
    22 TRD OR DCSB Lunar Rock
    RCI sliders & engine skid, BAKFlip MX4, PPF, and many other smaller things
    I’ve always just had my rotors turned and with young drivers on mountain roads (and improper braking techniques) I had to do it often enough. In fact I’ve never replaced rotors and we always drive our cars well over 200k miles.
    thomasburk[QUOTED] likes this.
  7. Dec 13, 2024 at 9:00 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    What brand would you recommend or that you have good track record with?
  8. Dec 13, 2024 at 9:01 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Same question, what brand would you purchase, and why?
  9. Dec 13, 2024 at 9:02 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    I found a hungry local who does turning, was thinking if it cost under 25 each I would just give him a try to keep the economy local. I don't know, yet...
    RIX TUX likes this.
  10. Dec 13, 2024 at 9:27 PM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    As long as they are above min machine to limit (you should have at least 0.030 above machine to, to turn the rotors), then just machine/turn them, they should only remove a max of about 0.025"/0.635mm, the shop will have the machine to limit if not already on the rotors... Best to replace the pads or scuff them down to knock off any glaze and "flatten them" out (you can do that by moving them over smooth pavement in a circle, like wax on wax off) .. make sure to clean and lube everything properly for the best results...
    thomasburk[QUOTED] and robin303 like this.
  11. Dec 13, 2024 at 9:30 PM
    robin303
    robin303 Well-Known Member
    Robin
    Houston Tx
    21 TRD Sport
    I always got OEM from Bell.
  12. Dec 14, 2024 at 2:08 AM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    I used to catch a ride in a Kiowa to get to mountain top microwave sites in ROK. Sometimes a Cayuse. 36th Signal Battalion. Liked those WOs.
    edit: Sorry for the sharp left turn. It was my first time away from home during Christmas.
  13. Dec 14, 2024 at 4:24 AM
    1994SR54x4
    1994SR54x4 Well-Known Member
    I installed the driver's side of the Cali Raised console molle system and experimented with the Midland GMRS radio bracket. Will install the passenger's side today and try the bracket there as well to see which works best. Radio install is Monday. Photos when it's all completed.
  14. Dec 14, 2024 at 5:39 AM
    nds0000
    nds0000 Well-Known Member
    Replaced the flimsy hood light switch that came with it. Had to drill the hole a bit bigger and an additional one for the stainless screw to fixate it. When the temps rise a bit (30F here), I will rewire the entire thing to make it look nice and dandy.
  15. Dec 14, 2024 at 5:52 AM
    dryheat
    dryheat Well-Known Member
    MagicToolbox likes this.
  16. Dec 14, 2024 at 6:40 AM
    RockBunny
    RockBunny Well-Known Member
    Northern NH
    22 LunarTRD DCLB Sport
    The last few rotors I bought weren't very good. You don't need to worry as much in FL but I would buy ones with a rust resistant coating. Maybe even OEM.
    I had a terrible time with the pads for my RAV4, also. They were cast/machined very poorly. Ended up with Akebono and would seek them out for my Tacoma, also.
  17. Dec 14, 2024 at 6:49 AM
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    You can't go wrong with OEM
    Fireme and thomasburk[QUOTED] like this.
  18. Dec 14, 2024 at 7:33 AM
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
    I only learned this at the track a few years ago; so might be helpful to some here. When the brakes are HOT form extended or hard use, and you come to a stop; keeping your foot on the brake while stopped will almost ALWAYS warp the rotors. The simple solution is to get your foot OFF the brake once you are stopped.
    This is only necessary when the brakes are really HOT, so not all the time, but the explanation is that the rotors are cooling off when you stop, Except the potion of the rotor with the pads held tight to them, has considerable more heat contributed by the hot pads, and so the circumference of the rotor cools at a substaintial difference, enough to cause a warp. Getting your foot off the brake reduces the heat transfer from pad to rotor. This also probably helps to reduce pad transfer to the rotor which also feels like a warp. Again, only needed when the brakes are really hot, long downhill to a stop, Panic brake, Heavy load or towing, etc.
  19. Dec 14, 2024 at 9:11 AM
    scouterjan
    scouterjan Well-Known Member
    Jan
    22 TRD OR AC in good old white
    And shutting down
  20. Dec 14, 2024 at 1:03 PM
    Pinchaser
    Alan
    Assume you have similar; it looks like these do not turn off and on to the set temperature, but go from high to low; meaning in small space or warmer ambient, low will be more than needed and it will drive the room temperature up uncomfortably. Is this true, and can anyone recommend one that turns on and off too?
