  1. Jan 4, 2025 at 2:34 PM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    New boot Goofing in the garage. No more cool guy orange boots for me. Lets see how long this one lasts.
    IMG_2868.jpg IMG_2869.jpg IMG_2872.jpg IMG_2876.jpg IMG_2877.jpg f
    Seymootaco, RCrumb, spin180 and 10 others like this.
  2. Jan 4, 2025 at 3:12 PM
    99kx250
    99kx250 Taco Bell king
    Joshua
    Arizona
    22 TRDOR
    Deaver+Icon AAL OME 885 springs Bilstein 5100s
    Yes, the discount I go to didn’t have a KO2 in stock so closest was a KO3 they had available atm
  3. Jan 4, 2025 at 4:45 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Changed out 7 qts of coolant with fresh pink coolant. Drained radiator, passenger block, and overflow tank.
    Old stuff looked pretty good at 70209 miles, but with a light straight down in bucket you can see orange, is that rust?
    Since I removed right front wheel to gain access to block drain valve, decided to rotate all tires, and of course they were installed at what seemed to be 200+ ft/lbs as noted on my torque wrench.
    20250104_133620.jpg 20250104_133654.jpg 20250104_135141.jpg 20250104_135158.jpg 20250104_135214.jpg 20250104_135447.jpg 20250104_144012.jpg
    OffRoadWannabe, MAS, RCrumb and 18 others like this.
  4. Jan 4, 2025 at 6:40 PM
    wcoffman
    wcoffman Well-Known Member
    '18 TRD Sport DCLB 4x4 SuperWhite
    Fr pass door handle replace, Tyger step rails and soft bed cover, DDSS3 fogs, TRD skid, OR front tow hook, SokieTech hood struts, fr seat covers (neoprene), metal oil filter housing, magnetic oil plug, Cyclone under hood lights, Blue Sea Systems 5025 Fuse Block ST Blade 6 Circuit with Ground and Cover, Blue Sea Systems 60A DC Panel Mount circuit breaker.
    When that drain plug gasket is stuck on the pan I’ve decided to leave it in place, mostly because my heavy-handed self would surely damage the oil pan. Haven’t had one leak on me yet thank goodness. (Continuing that “tradition” on the 2.4L in the ’23 RX350.)
    thomasburk and CrashZone like this.
  5. Jan 4, 2025 at 7:05 PM
    Bigeshorte45
    Bigeshorte45 Well-Known Member
    VA
    2017 DCSB 4x4 Sport
    Replaced old Amazon/Ebay (I forget) mud flaps with Tufskinz mud flaps. Not sure if I like the retro-style look or prefer the all black better.
  6. Jan 4, 2025 at 7:08 PM
    CalWheaten
    CalWheaten Active Member
    2018 Black Tacoma Off-Road
    Z Precision Cup Holder addition and I changed up the location of my phone mount so it doesn't block anything on the driver side.
    MAS, RCrumb, spin180 and 5 others like this.
  7. Jan 4, 2025 at 7:09 PM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    Those rims make everything look good.
  8. Jan 4, 2025 at 7:26 PM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    Got my H9's in today and installed, the hardest part was removing the green things in the plugs, but I was also using a cheap pair of needle nose pliers instead of going and getting the good ones... lol
    I think it would be much easier to just use a flat blade screw driver and pry them up and out, worked for the needle nose anyway...
    Only a short drive in traffic, so lots of heads lights around but in my neighborhood they seemed much brighter, like driving with the high beams on but with the normal cut off of the lows, so far so good. Seemed I could see much better...:thumbsup:
    And they had Germany on them also... :cool:
  9. Jan 4, 2025 at 9:02 PM
    DavesSR5
    Dave
    I hate to ask, but where did you get that 2 gal bucket from, and link if you still remember/have it please sir??..
  10. Jan 4, 2025 at 9:03 PM
    NenessTaco71
    NenessTaco71 Member
    Nelson
    2021 Green Army TRD SPORT
    2" front 1" rear RC leveling lift
    Bro! Did you measure your front lift from center hub to fender flare? I think you’re at least at 2" or 2.5" of lift there with the 4004 springs set on 4th notch! I also have the MT64 with the 4000 springs (which are shorter than the 4004) and mine are set at the 3rd notch and I have 1.5" of lift in the front! (Center hub to fender is 22.5" , stock you are at 21").
  11. Jan 4, 2025 at 9:16 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    thomasburk and DavesSR5[QUOTED] like this.
  12. Jan 4, 2025 at 9:21 PM
    MuleyCrazy13
    MuleyCrazy13 Well-Known Member
    Are those 285’s?
    99kx250[QUOTED] likes this.
  13. Jan 4, 2025 at 9:25 PM
    99kx250
    Joshua
    Arizona
    22 TRDOR
    No sir 265/75/16
    RIX TUX and MuleyCrazy13[QUOTED] like this.
  14. Jan 4, 2025 at 9:27 PM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    I considered that then thought what if I forget and double up the gasket? Or someone else does oil change and does same? Probably still wouldn’t leak but OCD self says remove stuck on gasket.
    DavesSR5 likes this.
  15. Jan 4, 2025 at 9:53 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    I got this one at Homey Depot.
    DavesSR5[QUOTED] likes this.
  16. Jan 5, 2025 at 5:52 AM
    DavesSR5
    Dave
  17. Jan 5, 2025 at 5:54 AM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Check the paint section! 10 or 5 quarts take your pick.Screenshot_20250105_090759_DuckDuckGo.jpg
    MGMDesertTaco likes this.
  18. Jan 5, 2025 at 6:54 AM
    DavesSR5
    Dave
    I'm thinking the 10 quart and the 5 gal (not quart lol) one, and they are the same price, for when I am messing with a transmission...
  19. Jan 5, 2025 at 7:32 AM
    jgarverick
    jgarverick Well-Known Member
    2021 DC SR
    I cut the tabs out of the bulbs instead. Not to difficult with an xacto knife set. Then did the same to an extra and threw it in the glove box. Now all 4 bulbs are H9s and I have a spare in the truck.
    Edit: also just so everyone knows that green thing is a locking cap to prevent the tabs that hold the terminals in from moving. The terminals won’t necessarily move without it on this particular connector but it is possible.
    Barsoom and thomasburk like this.
  20. Jan 5, 2025 at 8:08 AM
    Dtax
    Dtax Well-Known Member
    Massachusetts
    2017 Black Tacoma Sport
    Mods = N+1
    hey man. I don’t like to be a butt in know it all guy - I frankly don’t know much. But what do know is that ko3 is a completely different tire than the ko2. Meaning I would think the inbalance can’t be good for the drive team.
    can you make it your spare or is it your spare by chance ???
    again sorry to butt in. Just trying in the interest of being helpful / prevent future damage
