  1. Jan 25, 2025 at 3:58 PM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Hey, it takes your eyes off of all that godawful white...:burp::crapstorm:
    :bowdown:
  2. Jan 25, 2025 at 4:03 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    Well, now you gotta chrome wrap the tailgate handle, too. Looks so out-of-place.
    Chrome side steps, too.
    Mirror caps?
    TW - we’re here to help!
    :spending:
    thomasburk and Breknraj like this.
  3. Jan 25, 2025 at 4:06 PM
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Yes. My assumption would be that I would have to do this quickly in order not to loose a lot of oil
    Generally when I change the oil in any of my vehicles I drain the pan then remove the filter.
    I have never removed a filter prior to draining, so I'm assuming this would just wind up being a mess and would require me to work quickly.
    In any case I'm just gonna wait. Everything will be fine. When it's time for my next oil change I'll put a dealership purchased filter in and see if that alleviates the recent issues I've been experiencing.
  4. Jan 25, 2025 at 4:14 PM
    wcoffman
    wcoffman Well-Known Member
    '18 TRD Sport DCLB 4x4 SuperWhite
    Fr pass door handle replace, Tyger step rails and soft bed cover, DDSS3 fogs, TRD skid, OR front tow hook, SokieTech hood struts, fr seat covers (neoprene), metal oil filter housing, magnetic oil plug, Cyclone under hood lights, Blue Sea Systems 5025 Fuse Block ST Blade 6 Circuit with Ground and Cover, Blue Sea Systems 60A DC Panel Mount circuit breaker.
    The bonus of white: at some point the paint sheets off and reveals the greenish-gray primer underneath. You just gotta be patient.
  5. Jan 25, 2025 at 4:26 PM
    HLSATRK
    HLSATRK Well-Known Member
    2021 Tacoma Long Bed 4x4
    My next mod, since you guys like my chrome so much…
  6. Jan 25, 2025 at 5:00 PM
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    Squint
    VTCAL, VLTHNTR77, BoomerGVNG and 7 others like this.
  7. Jan 25, 2025 at 5:16 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Bedazzle ...
  8. Jan 25, 2025 at 5:34 PM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    or just turn the brightness down on your screen.
  9. Jan 25, 2025 at 6:48 PM
    Bon3h3a6
    Bon3h3a6 Well-Known Member
    Retro Bronco 4 dr
    Retro Ford letters, KBD flares, Morimoto headlights and taillights, Bronco script, prerunner bar
    I have a few questions for all you 3g owners. How well does the 3rd gen ride and what are the most common issues with them? Does it ride similarly to the 4.0?
    The reason why I am asking this is because later on in the future when my bronco is payed off, I have been thinking about getting a truck. One of my dream trucks is 3rd gen Tacoma TRD pro with the MT and solar octane. And after having two 2nd gen’s I have missed part of the Tacoma experience.
  10. Jan 25, 2025 at 6:48 PM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    No, the only oil that you will loose is what is in the canister plus a little in the oil passage... Basically the majority of the oil is in the oil pan (sump), and the oil pump gears/rotors/veins (whatever) has to be turning (engine cranking/running) for the oil pump to suck up the oil through the oil pump pick up tube that extends close to the bottom of the sump, it then pumps the oil from the pan/sump through the pump to the filter before being distributed to the bearings and various parts of the engine... So no, you will not loose much oil, maybe a quart give or take a tad, but anytime that oil light is flickering or coming on, that means the oil pressure is at or below a very dangerous preset psi (normally 5psi), having that light on while running the engine is the same thing as running the engine with no oil in it for the most part... As an engine builder etc we always want 10psi of oil pressure per 1,000 rpms, so 30psi at 3,000 rpms, 50psi at 5,000 rpms and so on... I think the industrial standard for OEM engines might be as low as 7psi per 1,000 rpms...
    So even if your engine is working great now, does not mean you are not removing bearing material off prematurely... You can potentially be doing permanent damage to your otherwise good engine... Better to be safe than sorry...
  11. Jan 25, 2025 at 7:46 PM
    nds0000
    nds0000 Well-Known Member
    I vary my intervals according to my use. As I drive higher speeds here as I ever did in the US (85+) and have a lot of quick accelerations, I change all my drivetrain fluids sooner than I would in the US and sooner than the owner manual suggests. On the other hand, seldom one of my travels is less than 40 miles, as I don’t take to Taco for short shopping trips. Therefore, I do not exceed around 5k miles for the oil and oil filter change. I use royal purple the recommended grade.
    Truth is that the oil sometimes looks so unused that I am tempted to take the old Tacoma oil and put it into my Clio 3. But looks are not all-as with humans… As soon as the oil gets brown, its chemical chains are broken. To what extent? I have no idea-so I change oil regularly and perhaps before even needed.
    I do cut the filter and look for debris and run a magneto over it ti see if I have ferrous metal or not. Will have to find a company that does the oil analysis for me here. No luck so far.
    Goal is to drive my 3rd gen Taco till it or I die. Hope it is me because it is one awesome vehicle.
  12. Jan 25, 2025 at 7:49 PM
    CB350G
    Western PA
    And don’t forget these:
  13. Jan 25, 2025 at 7:49 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    get the Sport
  14. Jan 25, 2025 at 8:00 PM
    nds0000
    Drove around 1000km with the new shoes. Same drive style and routes, same load. To now the mpg went from 17.8 with OEMs to 19.5 with new shoes. They are a lot quieter and feel softer than the OEMs. No rain experience yet.
    thomasburk likes this.
  15. Jan 25, 2025 at 8:13 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    oil gets darker because dirt sticks in the oil
  16. Jan 25, 2025 at 8:28 PM
    nds0000
  17. Jan 25, 2025 at 8:28 PM
    azhiaziam
    azhiaziam Well-Known Member
    The reef ca
    White 2023 trd off-road
    Does anyone have a picture of diode or baja rock lights on there roof rack? I can’t decide between the two. I like how the bajas hide more but the diodes are brighter they just stick out more
  18. Jan 25, 2025 at 8:37 PM
    FunknNasty
    FunknNasty Well-Known Member
    San Jose
    2022 Tacoma Pro and 2025 Tacoma OR Max
    my 22 Pro is dream like to drive (on or off road). I also drive a 22 Sr5 access cab that drives nice, but it ain’t in the same driving class as my Pro - not even close.
    RIX TUX and Bon3h3a6[QUOTED] like this.
  19. Jan 25, 2025 at 8:42 PM
    RIX TUX
    too much thinking.....
    just enjoy the drive.....
    change it at 10k for normal driving...
    if you want something to keep running till you die then put it in the garage and drive once a month to the liquor store
    2k2 and BC Hunter like this.
  20. Jan 25, 2025 at 8:53 PM
    HLSATRK
    Oh hell yes. Cab lights rule!
    CB350G[QUOTED] likes this.
