  1. Jan 25, 2025 at 8:53 PM
    HLSATRK
    HLSATRK Well-Known Member
    2021 Tacoma Long Bed 4x4
    Looks like my ‘78 K5 Blazer!
  2. Jan 25, 2025 at 8:55 PM
    HLSATRK
    Seriously! Truck has waaaay too much white
    MagicToolbox likes this.
  3. Jan 25, 2025 at 10:07 PM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    andthen and Road_Warrior like this.
  4. Jan 25, 2025 at 11:20 PM
    Ejctt
    Ejctt Well-Known Member
    2023 White Tacoma Off-road
    How did you find putting the wings on? Did you trim the fender liner like Greenlane does or did you do something different? Getting ready to install and not sure how much to cut.
  5. Jan 25, 2025 at 11:22 PM
    Breknraj
    Breknraj Well-Known Member
    Roger
    2017 Tacoma TRD Off Road
    Eibach mild lift Relentless Stingray low profile bumper w/ Warn 8000S Warrior Products Roof Rack RRW Sliders
    No pics, but I got the new shoes put on. BFG AT KO2s, and had the best Blizzack left mounted on a matching rim (4Skinner 7 pt stars) to replace the original spare (available, if anyone in the Denver metro area is interested). At 95,000 miles, the old Bilstein 5100s were leaking in back, so those got replaced, and we added Eibach 1" blocks to even the stance. Discovered 2 seized control arm bolts, when we went for the alignment, so all 4 got replaced, and there was slop on the driver's CV shaft, at the diff, so bye bye needle bearing for the sleeve, and a new half shaft. New alignment, and all is good, for a while.
    Thinking seriously about yanking my roof rack, sliders and front bumper to get them all blasted and powder coated, since they are beginning to look a bit ratty.
  6. Jan 25, 2025 at 11:29 PM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    I pretty much used the instructions the set up in the videos. The sander is really helpful. It took me several cuts/sandings to get to where it is. Probably 6, 7, 8?
    Ejctt[QUOTED] likes this.
  7. Jan 26, 2025 at 4:30 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Rule? Maybe 30 years ago…
    Now you aren’t cool unless you have them poked into your grille
    Road_Warrior likes this.
  8. Jan 26, 2025 at 5:12 AM
    ERod27
    ERod27 Well-Known Member
    Eddie
    2019 TRD OR DCSB
    King 2.5s with Camburg Kinetik UCA Cooper Discoverer AT3 XLT 285/70/R17 17" 4 Runner TRD PRO SEMA wheels TRD PRO skid plate 5.29 Yukon gears Apogee front bumper with Warn EVO Apogee rear bumper with tire carrier
    Just in case people don't follow him on YouTube.
    andthen, RxYoda, DavesSR5 and 2 others like this.
  9. Jan 26, 2025 at 5:48 AM
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Thanks
    I'm gonna change my oil this week. Gonna run about 5oz of seafoam through the crankcase for 500 miles, grab an OEM filter or 3 from my local dealer, and run some Mobile 1 in lieu of Pennzoil Platinum... We'll see if that makes any difference
  10. Jan 26, 2025 at 6:06 AM
    azhiaziam
    azhiaziam Well-Known Member
    The reef ca
    White 2023 trd off-road
  11. Jan 26, 2025 at 6:07 AM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Sooooo...."Scrub Radius" is a thing.
    Start video at 3:30
    I just learned/advised not to change offset more than 1 inch from the factory.
    Is this true?
    This guy does great analysis and I'm leaning more towards 0 offset for my Tacoma.
    ca08tacoma likes this.
  12. Jan 26, 2025 at 6:13 AM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    Well at that point you will have changed 2 things and added another, so which one fixed it? or was it a combo of 2 or all 3??
    Me? I would change the filter and see if it helps 1st... But as a great Reginal manager used to say, it's your money, your vehicle and your decision...
    And no you can't go too wrong by doing all 3, but you will not truly know what the cause was...
    If it wear me, I would run Marvel Mystery Oil through the crankcase, seafoam is better in the gas tank for injector cleaning...
    But unless I was having any kind of build up or sludge from not changing my oil regularly, then I would not run a bottle of fix-it at all... too much of additives can cause build up/scaling of carbon deposits and do damage... My son for whatever reason decided to run fuel and oil additives in his Honda until a bit of scaling flaked off and pie cut a valve (broke off part of the valve)... His is a worst case scenario... lol
    It was a good teaching tool on misfire diagnostics for him and well as a learning lesson on if some is good more is not always better.... Yeah I drug it out until I finally told him to get the compression gauge out... lol
  13. Jan 26, 2025 at 6:14 AM
    D-knoww
    D-knoww D-Know
    Washington state
    2019 Tacoma TRD Sport Longbed
    Good looking truck. I like the way it matches up with the no parking red curb line.
  14. Jan 26, 2025 at 6:21 AM
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Doesn't matter what fixes it at this point. I just need it to startup trouble free
    Like I said I'm banking on the filter. I'll save it and cut it open
    DavesSR5[QUOTED] likes this.
  15. Jan 26, 2025 at 6:23 AM
    D-knoww
    D-knoww D-Know
    Washington state
    hope not.
    wcoffman[QUOTED] likes this.
  16. Jan 26, 2025 at 6:25 AM
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Yes. It's true.
    I have -25mm offset wheels and 265/75/16... If your tread pattern is aggressive enough you will get scrub radius rubbing.
    -12mm seems to work great and sit just outside the stock flares.
    TacoTime55[QUOTED] likes this.
  17. Jan 26, 2025 at 6:26 AM
    DavesSR5
    Dave
    Great video, and yes poking the tires out (well centerline of the wheel) on any vehicle off sets the geometry and loads the outer part of the wheel/hub bearing.. Yes, your hub bearing is a too row bearing and is designed to carry the weight of the vehicle over both and not just one.. Back when RWD's all ran tapered big and little wheel bearings, anytime someone ran an offset wheel (deep dish) on the front would kill the poor little outer wheel bearing, having a double row hub bearing with equal size bearings have helped greatly with that... But it is still hard on them.. Ever thought why the bearing dude on here probably never sold a bearing to a stock tire, wheel and suspension truck?? Mainly guessing on his sales numbers, but I have not seen many if any go bad from normal use unless high mileage... My brothers 2nd G has well over 200,000 miles with OEM bearings... BTW, offset can/will also damage ball joints...
    Ever heard the old saying, if ya want to play, you got to pay....
  18. Jan 26, 2025 at 6:29 AM
    D-knoww
    D-knoww D-Know
    Washington state
    Oooooooohh!
    MARSHBUSTER likes this.
  19. Jan 26, 2025 at 6:31 AM
    D-knoww
    D-knoww D-Know
    Washington state
    yeah, a white one.
    wcoffman likes this.
  20. Jan 26, 2025 at 6:44 AM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    Once IFS factory settings are disturbed, it effects it's intended purpose.
    Got it! :cheers:
