  1. Jan 30, 2025 at 7:41 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    if the battery is dead its the only way
  2. Jan 30, 2025 at 7:49 PM
    RIX TUX
    whats wrong with a wrinkle on the spare?
    Cement_wheels likes this.
  3. Jan 30, 2025 at 7:54 PM
    RIX TUX
    :popcorn:
    Nomad26 and TacoTime55 like this.
  4. Jan 30, 2025 at 8:07 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Witness Protection?
    RIX TUX[QUOTED] likes this.
  5. Jan 30, 2025 at 8:28 PM
    RIX TUX
    maybe in jail....truck in storage
    TacoTime55[QUOTED] likes this.
  6. Jan 30, 2025 at 8:44 PM
    quickbike
    quickbike Member
    Jay
    Purchased aftermarket 2110 key fob, mini vci usb obdii cable, downloaded and installed tech stream, somehow got the drivers to work, programmed the key, cut the fob silicone membrane to fit a meso custom trd red v2 fob. Will get the key cut tomorrow. total cost so far $80.
    MTBTACORN, andthen and musicisevil like this.
  7. Jan 30, 2025 at 8:55 PM
    James2406
    James2406 Well-Known Member
    James
    South Carolina
    2021 TRD OR Premium
    Lots
    Get you this adapter from Amazon, it's been working perfectly all week, much better than that Motorola one, and it's tiny.
    https://www.amazon.com/dp/B0DKSH9ZD1
  8. Jan 31, 2025 at 2:48 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    If they do it's not enough for me to notice. I don't think so, I have the seat jackers installed up front so I may not be the best for deciding.
    EvlFlash[QUOTED] likes this.
  9. Jan 31, 2025 at 4:05 AM
    ClassyTacos
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Had some black paint peeling on the snorkel so I removed it, and holly shit its beautiful. Still have some cleaning to do in the photos.
  10. Jan 31, 2025 at 6:31 AM
    black3rdgen
    black3rdgen Well-Known Member
    STL
    3G on 35s, 5.29s
    YW tune, 5.29s, equal length dual exhaust, 2000w audio system
    What have you heard about alpharex? I’m pretty satisfied with my Nova series headlights
  11. Jan 31, 2025 at 6:42 AM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
    Need a pic of the whole truck, that actually does look pretty sick
  12. Jan 31, 2025 at 7:19 AM
    Nomad26
    Nomad26 Well-Known Member
    Escondido, CA
    '16 MGM OR Access Cab, ‘16 MGM RAV4 Hybrid
    Installed a Wolfbox G900 Pro. Tapped into my rear view mirror harness to run the hardwire kit, made for a clean install. I bought the Wolfbox OEM bracket kit so I removed my mirror and tucked away the cables all nice under the headliner.
    I also had to replace my third brake light on my GFC Topper (housing faded and cracked at the screws) so I did that and made a notch in the wire access hole using a dremel to fit the rear camera cable. It’s clean but I’m going to add some butyl tape to push out the light a little bit for the camera cable and seal it up good. Waiting on a Shittco camera mount for the GFC to make it even better.
    Impoy47, spin180, ClassyTacos and 3 others like this.
  13. Jan 31, 2025 at 7:28 AM
    Dtax
    Dtax Well-Known Member
    Massachusetts
    2017 Black Tacoma Sport
    Mods = N+1
    nice work - that tapping into the existing wiring like that looks very easy - i have this thing on my bench and have been putting off since it will take a while to wire etc (and i do like wiring, just takes me a while with 1. OCD and 2. I am newer so i take a lot of time to try to get it right and over kill).
    So curious of any issues pop up.... or if working fine nothing to consider?
    For me, not going back to the old mirror once the wolfbox is in.
    nice work! appreciate any insights!
  14. Jan 31, 2025 at 7:31 AM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    There is a thread but you can also use a dongar mirror cable, has a usb adapter. No tapping needed.
    Dtax[QUOTED] likes this.
  15. Jan 31, 2025 at 7:37 AM
    Nomad26
    Escondido, CA
    Thanks! No issues so far, but it’s been installed less than 24 hours. It runs flawlessly and goes into parking mode as intended once I turn off my truck. The mirror is bigger than I thought so I’m glad I removed my stock mirror because my driver side visor does hit the mirror if at a particular angle.
    I am also OCD about my wiring. I took the opportunity to clean up some wires in my topper, soldered and shrink wrapped all connections for my replacement light, and added wire loom to make it look neat.
    The biggest consumption of my time was running the wire from the back under my truck and back into the cab. I have done this several times for other accessories so I already knew where the wire would go but it still took a while. I also ordered a 10-foot camera extension cable, so glad I did because the cable would have been too short otherwise.
    andthen, Dtax[QUOTED] and DavesSR5 like this.
  16. Jan 31, 2025 at 7:38 AM
    Nomad26
    Escondido, CA
    Yes but this is for the hardwire parking mode cable. I also have a Dongar and removed it for this kit. The Dongar is great if you only want the camera to run when your vehicle is on.
    Dtax likes this.
  17. Jan 31, 2025 at 7:43 AM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    Nice job, looks good.. If I may give some unsolicited advise, add something to keep the wires from vibrating/rubbing on the metal edges of that brace, it will cut into the wire(s) and cause issues down the road... You can even use rubber fuel line hose slit down the center to go over the (sharp) metal edges and either glue or zip tie or whatever the rubber hose in place... Same thing as having a rubber gromet for wires going through the firewall or wherever to keep from damaging the wires down the road...
    ClassyTacos and Nomad26[QUOTED] like this.
  18. Jan 31, 2025 at 7:46 AM
    Nomad26
    Escondido, CA
    Good idea. I have some old bike inner tube I use for random projects, I’ll just put some of that there.
    Dtax and DavesSR5[QUOTED] like this.
  19. Jan 31, 2025 at 7:49 AM
    Hansamzac
    Hansamzac Well-Known Member
    Central Ohio
    2022 Tacoma TRD OR Lunar Rock
    BakFlip M4 tonneau, debadged, LED interior lights, LED bed light, Rhino mud flaps, window tint, blacked out chrome bumper, Clazzios
    Finally got my new to me wheels mounted with tires...thnx @K9tacoma...and swapped them out this morning. Gained just over an 1" in diameter, an additional 1" of poke and dropped 5lbs at each corner.
    spin180, ClassyTacos, 99kx250 and 8 others like this.
  20. Jan 31, 2025 at 8:00 AM
    Dtax
    Massachusetts
    Mods = N+1
    love it, thanks!!!
    Nomad26[QUOTED] likes this.
