  1. Feb 1, 2025 at 9:00 PM
    nds0000
    nds0000 Well-Known Member
    Once, on day two! Not ever since. Separating stock and leave it on the starter batt while running mods over the house battery helps reducing starter batt discharge. Installed the trickle charger because batteries need TLC to last. Installed the connector because I am looking into adding a block heater and was fed up of opening the hood for connecting/disconnecting the charger. But my research has not gone far enough yet to purchase.
  2. Feb 2, 2025 at 4:30 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Thanks, really appreciate it.
    Road_Warrior[QUOTED] likes this.
  3. Feb 2, 2025 at 5:50 AM
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Yes . Not constantly, but on occasion depending on the severity of the potholes/general road conditions. I believe this is largely due to suspension. For instance my cushy sedan-like SR shocks are much more friendly than a set of 4600s that are setup a bit stiffer on bumpy street terrain. The stiffer the shock/spring combo the more jarring those potholes will feel. I also noticed when my first gen was lifted any bump or pothole required me to "correct" the tracking, but that truck had a stiffer shocks/springs.
    Yes on occasion. More so than my first gen, but this truck is also a little bigger all around.
  4. Feb 2, 2025 at 6:37 AM
    D-knoww
    D-knoww D-Know
    Washington state
    2019 Tacoma TRD Sport Longbed
    same thing happened to me with my old truck. I wasn’t as lucky as you, I didn’t work in a body shop, so I drove around with that pesky dent until I traded it in on the Taco. I agree with the other member, people suck.
  5. Feb 2, 2025 at 6:40 AM
    Taxx
    Taxx Well-Known Member
    That connector is there for service and inspection/monitoring tools. It is power and ground and some communication wires. As long as you don't short the communication wires together or to anything else, you are not going to hurt anything.
    There are two photos below. The one with the red is the current schematic for the DLC (datalink connector, OBD II plug, whatever you want to call it). The red wire, pin 16, is battery. Pins 4 and 5 are ground. You can cut that red wire, cap off the battery side so it doesn't short to anything, and splice a new wire into the DLC side of that wire.
    The second photo shows part of the radio schematic. The wire circled in yellow is ignition to the radio. You can splice into that wire to get ignition and then run it down to the DLC. You can add an inline fuse if you want, but there is already one for the radio so no real need unless that dongle is pulling some serious power.
    You could also put a manual switch on the power to the dongle if you wanted. The sky is the limit.
    As long as you are comfortable, cutting, stripping and crimping wires you'll be fine.
    Keep in mind, you may have other parasitic draws too and this one was just the one that put it over the top.
  6. Feb 2, 2025 at 6:40 AM
    Taxx
    sucks to hear that Scott.
  7. Feb 2, 2025 at 10:29 AM
    nds0000
    Thanks for this! When it warms up a bit outside here I will attempt to put a switch on the red wire. Gotta do some wiring anyways. Thanks again for your great help!
    Taxx[QUOTED] likes this.
  8. Feb 2, 2025 at 12:12 PM
    alphaomega420
    alphaomega420 Well-Known Member
    2019 SR SX V6 RWD
    Put this badge overlay from Upturn Prints on today. Not sure if I’m gonna keep it on or not. I feel like it looks a little ricey, and I like a cleaner, OEM+ look, plus there are a few small creases that you can see if you’re right up on it. I have a different, more minimal HD front plate coming to hopefully help clean it up, but we’ll see.
    andthen, MTBTACORN, spin180 and 3 others like this.
  9. Feb 2, 2025 at 2:41 PM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    That combo has GOT to start some interesting conversations.
    cotaco05 likes this.
  10. Feb 2, 2025 at 3:27 PM
    alphaomega420
    2019 SR SX V6 RWD
    It’s definitely a funny thought! Haven’t found any cool Toyota front plates that I like, unfortunately.
  11. Feb 2, 2025 at 3:53 PM
    OLDTRAP
    OLDTRAP Well-Known Member
    2021 TRD OR
    Stock
    Good looking tire tread, what we got?
  12. Feb 2, 2025 at 5:02 PM
    ScottThePainter
    ScottThePainter Well-Known Member
    2023 TRD Off-Road Magnetic Grey
    Falken Rubitrek AT, 265/70R17. Super quiet and only $180ish per tire.
    RIX TUX likes this.
  13. Feb 2, 2025 at 5:12 PM
    douglas_ngo
    douglas_ngo Well-Known Member
    2018 Tacoma TRD 4x4 6MT
    Spent the day up in the mountains. Got the Tacoma legs stretched today.
  14. Feb 2, 2025 at 6:27 PM
    James2406
    James2406 Well-Known Member
    James
    South Carolina
    2021 TRD OR Premium
    Lots
    I actually just got mine too, and wasn't really happy with the color match either. That and the nipple ring tow hooks. I'm getting rid of both for the nytops expensive ass front and rear hooks and a V2 Pro grille.
  15. Feb 2, 2025 at 6:34 PM
    alphaomega420
    2019 SR SX V6 RWD
    Yeah this was my attempt at dressing up this grill before I plunked down the money on a Pro Grille haha. Undecided if I want the OG or the V2 just yet; I like the V2 just because it’s different than what everyone else has, but I like OEM+ and the fully blacked out Pro Grille is classic. I also like the NYTOP recovery points, but I’ve only recovered someone once and I used a hitch-mounted shackle. Let me know who you go with for the grill and how the quality is.
  16. Feb 2, 2025 at 6:35 PM
    James2406
    James
    South Carolina
    2021 TRD OR Premium
    Lots
    Heard, I REALLY like the style of Nytops and currently working Overtime to pay for them, but I got the all black V2 Pro grille without raptor lights from Yotaverse and I'll probably order the nytops in a few weeks.
    I'll update when I get the grille tomorrow
    alphaomega420[QUOTED] likes this.
  17. Feb 2, 2025 at 6:45 PM
    SomeTacoDude
    SomeTacoDude Well-Known Member
    Rocky Mountains in 285/75/16. Look good on the truck, we'll see how they wear.
  18. Feb 2, 2025 at 6:45 PM
    MGMDesertTaco
  19. Feb 2, 2025 at 6:46 PM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    I got a set of nytop rear hooks collecting dust. Black Never installed them. Pm me if you’re interested.
  20. Feb 2, 2025 at 6:48 PM
    James2406
    James
    South Carolina
    2021 TRD OR Premium
    Lots
    Red?
