  1. Feb 24, 2025 at 12:13 PM
    grambo911
    grambo911 Well-Known Member
    SF Bay Area, Kommiefornya
    2023 Lunar Rock Trail Edition
    AWE Exhaust, KARTBOY exhaust hangers, custom 1/0 exhaust grounding, lots of Titanium hardware from my old builds, silly JDM bits from my old Subaru builds, Uniden Bearcat Off Road CB, Firestik 2 w/custom CF mount, custom KARTBOY plate frame with Rigid Industries Spot on ball head mount, Yakima Mega Warrior w/custom CF cross brace. ARP extended studs (not installed yet), Optima Red Top, Siless Insulation in cab. Diode Dynamics LEDs throughout... More titanium fasteners. K&N intake snorkus delete. Greddy hose clamps throughout. DBA 4000XS Brake Rotors. TRD PRO fogs. Dakine Tail Gate Pad. Body Armor Sliders. Icon Stage 4 Lift. Eibach 1" Lift Blocks. Overland Taylor Tune. Rough Country Spare Tire Bed Mount. 67 Designs stuff on the dash. Uniden Radar Detector Hardwired. Spod Lighting Controls. RC Black Series Bumper Lamps RC Black Series Grill Lamp. Body Armor Stealth Front Bumper. Extended Brake Lines. Greddy Shift Knob. More to come of course.
    Slapped on the rears. I was able to use 100% Ti hardware. Drilled and tapped the frame instead of using the chinesium self tappers provided for the reservoir brackets. The difference between good hardware and cheap hardware is huge. Going to replace all the hardware on the leaf packs with 316 stainless. Ti is a bit pricey for an M10x1.25x90mm bolt. :eek:
    99kx250, andthen, spin180 and 2 others like this.
  2. Feb 24, 2025 at 12:30 PM
    sphinxbccp
    sphinxbccp Not a Well-Known Member
    Tim
    Kathleen, GA
    '19 TRD PRO
    A lot of shaking. I grabbed the front bumper bar and shook the front end up and down until it recreated the squeak, this let me hear that it was mostly coming from the passenger side. Then grabbed the passenger wheel well and again started rocking the truck side to side and listening. Had my wife rock the truck from the passenger wheel well also and was able to tell it was coming from forward of the suspension so that removed all of that from the suspects. Started looking up others with a similar squeak in similar place and found a video that had my exact sound. They replaced the bushing and fixed their squeak so I made the determination that would be my fix. I guess it wasn't a definite thing, but worth the money/ time to test.
  3. Feb 24, 2025 at 2:27 PM
    Dozer14
    Dozer14 Active Member
    Central Florida
    grambo911 likes this.
  4. Feb 24, 2025 at 2:34 PM
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Getting your moneys worth outta that tread
    NoOne, RollTide!, BC Hunter and 12 others like this.
  5. Feb 24, 2025 at 2:44 PM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    I think that you are running a little too much tire pressure there.
  6. Feb 24, 2025 at 2:49 PM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
    Calm down guys, they’re racing slicks
  7. Feb 24, 2025 at 3:09 PM
    alphaomega420
    alphaomega420 Well-Known Member
    2019 SR SX V6 RWD
    Got the H9’s put in (shoutout to @crashnburn80 for his super informative thread) and just had to remove the green tabs from the headlight connectors. Also went ahead and took the air dam off (again) and gonna see how the mpg looks after a few weeks. I’ve got an Amazon TRD skid that I’ll put on if I can deal with the MPG decrease. I also think I’m gonna take off the badge overlay and try a piece of tint on it instead to darken it and not make it look so chrome.
    MrMustacho, usmc2msu, RCrumb and 11 others like this.
  8. Feb 24, 2025 at 3:12 PM
    JohnnyGraphic
    JohnnyGraphic Well-Known Member
    Johnny
    Northern California
    2021 4Runner TRD OffRoad Premium
    Falken Wildpeak AT3Ws
    90k mile oil change, lube driveline. Going to get a mini-detail soon which it is in desperate need of.
    artvarck and 99kx250 like this.
  9. Feb 24, 2025 at 4:16 PM
    grambo911
    haha yep. I've been "procrastinating" for a full year on installing the lift. Actually, my honey do list was like a San Francisco phone book. I wanted to get the lift on and alignment before I bought tires. Plus, I am still on the fence about getting some JDM wheels for the truck and going bigger diameter and aggressive offset. Knowing me, I'll throw some OEM tires back on. They are cheap. Then save up for the bro setup.
  10. Feb 24, 2025 at 4:18 PM
    grambo911
    Yeah, inflated in the dark with no glasses on. Ain't care. News ones on in a few.
  11. Feb 24, 2025 at 4:19 PM
    grambo911
    I live my life a quarter mile at a time...
    2k2, musicisevil, Mickey65 and 2 others like this.
  12. Feb 24, 2025 at 8:39 PM
    HLSATRK
    HLSATRK Well-Known Member
    2021 Tacoma Long Bed 4x4
    in this case, 1 vote for the air dam!
  13. Feb 24, 2025 at 8:40 PM
    MGMDesertTaco
    *may pops :rolleyes:
  14. Feb 24, 2025 at 10:39 PM
    DNguyen1033
    DNguyen1033 Well-Known Member
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    GMRS antenna on roof top. Finally pulled the trigger drilling the roof. Been using the magnetic mount but I can see it’s starting to damage the clear coat a bit due to the stock antenna is rusting. Don’t want any more damage, might as well drill it. It’s done, only waiting for the antenna to arrive to mount it.
    Pry with something thin to remove cover.
    Pull both tab (red circle) with finger. Pull down light, the other two corner, pull down with a little force & light will come off. Measure 1.5” & use 1/8” drill bit drilling from the headliner up to roof (I did this step last in case I can’t fish the cable thru. Making the hole less visible by pushing the drill bit thru the headliner without running the drill. As soon as it hit the roof, start the drill thru the roof. Exit vehicle & from the rooftop, use a step drill bit, drill 3/8” diameter)
    Pull weather strip & run fish cable from here to the dome light. It will take a few try but can be done without help. (After finish fishing the cable, start drilling)
    Antenna is center of roof.
    artvarck, jericho777, trdo-r and 7 others like this.
  15. Feb 24, 2025 at 10:57 PM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    Heated steeling wheel? Tell me more.
    Tacodog likes this.
  16. Feb 24, 2025 at 11:00 PM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
  17. Feb 25, 2025 at 3:33 AM
    alphaomega420
    2019 SR SX V6 RWD
    You think it looks better on the truck than without or just for mpg?
  18. Feb 25, 2025 at 5:38 AM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab with 155000+ kms
    Everything working except the auto-sensing for headlights failed a few years ago. On my 2nd set of winter rated tires, working great getting through 2x major snow storms in SW Ontario.
  19. Feb 25, 2025 at 9:49 AM
    raptor2018
    raptor2018 Well-Known Member
    Paul
    2023 Black TRD Off Road DCSB
    Added some car wash pin striping today. Only part without scratches and swirls is the tailgate. Filed a claim with them.IMG_6145.jpg IMG_6152.png
    thomasburk likes this.
  20. Feb 25, 2025 at 9:52 AM
    EvlFlash
    EvlFlash Well-Known Member
    Utah
    2023 Tacoma TRD OR 6MT
    This is the one that I ordered from Amazon. Basically the same one from Car Trim Home (even had that labeling on the box).
    https://www.amazon.com/dp/B0DNJKV6TL?ie=UTF8&pd_rd_plhdr=t&aref=HYlQYiQ74x&th=1
    Replacing the clock spring is a bit sketchy given it's not an OEM part at that point. After running some errands with the passenger seat removed and seeing the SRS airbag errors it produced, I'm less worried about the airbag not working with the new clock spring (not gonna test it either, lol). The steering angle sensor is my only other concern but it's been fine so far and I'll be keeping the OEM parts on the shelf in case something goes south.
    thomasburk and oostroma[QUOTED] like this.
