  1. Mar 19, 2025 at 6:20 PM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    Great looking truck, if you can't get it level, you might just need to elongate the holes a little, might split the difference and raise one side and lower the other... I could not tell it was unlevel from my laptop...
    Imbored[QUOTED] and dand like this.
  2. Mar 19, 2025 at 6:21 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    Did some more work on the cross bar after dinner. Got the water tank brackets made and test mounted, along with my shovel, and hi-lift.
    It is quite a bit back heavy with the hi-lift so we will just have to see how it works when mounted in the truck.
    MAS, andthen, RCrumb and 11 others like this.
  3. Mar 19, 2025 at 7:06 PM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    No photos but took advantage of the warm weather and did a (fairly) quick exterior cleaning/waxing. Knocked the big stuff off with the garden hose and used Aero Cosmetic Wash Wax All. While vehicle is wet (panel at a time) spray with AC and wipe with damp microfiber towel. Buff dry using orbital buffer with microfiber bonnet and detailing hand cloth. Rinse microfiber applicator between panels. Didn’t think Taco was very dirty but rinse water was black by the time I was done. Used 303 on fender flares, black bumper plastic and wheels. Raining tomorrow so leaving in garage until weather clears up, probably Saturday.
    MTBTACORN, DavesSR5, Scotfree and 2 others like this.
  4. Mar 19, 2025 at 11:00 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Did you drive it before you bought it?
    What did the dealership say?
    My truck came with a gas cap holder
    The truck has thirteen cup holders
    10k miles is what the manual says
    and
    Coming in 15 comments deep to say what’s been said 14 times, with less tact
    :burp:
  5. Mar 20, 2025 at 1:52 AM
    Cement_wheels
    That's pretty much dead on. :thumbsup: But he became so predictable that it's what made me chuckle. You just knew what was coming.
  6. Mar 20, 2025 at 5:42 AM
    Tony382
    Tony382 Well-Known Member
    2022 Tacoma TRD Sport
    LOLZ…..all comedy!! You sir are not wrong!
  7. Mar 20, 2025 at 6:09 AM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Excellent Summary.
    :101010:
    rgljr831, thomasburk and musicisevil like this.
  8. Mar 20, 2025 at 6:13 AM
    ucmike11
    ucmike11 Active Member
    CT
    2021 Voodoo Blue TRD Sport
    I put on new AGP black wheels and Cooper R+T tires, so far really enjoying the look vs the stock Sport wheels!
    Dam325, MAS, andthen and 14 others like this.
  9. Mar 20, 2025 at 6:18 AM
    -Rorschach-
    -Rorschach- The Black Helicopters are coming…I gotta go!
    2019 Silver Sky Metallic Tacoma DCLB TRD OR 4x4
    Check the metal shims that came with it. There's a minor difference on 2 of them, it's hard to notice if you are not comparing all of them side by side. On my initial install I had them installed wrong creating a similar situation to yours. Good luck!
    DavesSR5 likes this.
  10. Mar 20, 2025 at 9:21 AM
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    Didn't take much in the way of pictures but I installed an OEM 1in block and bilstein 5125s in the rear. Allows for use of the full travel from the stock springs. Did a quick drive over some speedbumps down the street and the difference really is night and day. Way smoother and less bouncy.
    Front suspension is still stock height but its a dclb and they don't have quite as much rake from the factory so I think it looks fine for now. Eventually want to throw some 6112s up front but might cheap out and do 5100s sooner.
  11. Mar 20, 2025 at 9:31 AM
    Mach
    Also wanted to note that the 2 metal sleeves that come with the shocks actually have slightly different inside diameters. I think one is metric one is SAE. Most people dont seem to realize this. Of course those and the bushings are too wide for a 3rd gen so I had to machine them down. Also made up brackets to lower the ebrake cables.
  12. Mar 20, 2025 at 11:20 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Yes, or maybe, Rix TuxeGo.
    I didn't see that coming.
    musicisevil and Willy Lump Lump like this.
  13. Mar 20, 2025 at 11:30 AM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Yes, and this, I would assume, might also be a food requiring an 'aquired taste'. What sauce is made from fish guts?
    Garum was produced by fermenting fish intestines and other parts, often with herbs and spices, to create a flavorful sauce. Similarly, modern fish sauces are made using a similar fermentation process, yielding a liquid that is rich in flavor and aroma, reminiscent of the garum used in ancient Roman cuisine.​
    musicisevil likes this.
  14. Mar 20, 2025 at 11:31 AM
    Imbored
    Imbored Member
    Brian
    2021 Tacoma TRD Off Road
    Interesting thought. I thought I could shim the one side to bring it up. This bumper did not come with shims. Nor did it refer to shims during install. I will double check. I did notice washers of different thickness but the washer shouldn’t affect the height of the part based on location above and below mounting point. The bumper is sitting flat on both mounting points. I would be interested in seeing yours if shimmed.
    it’s probably a moot point since most people won’t notice. I guess I will run an experiment and see how noticeable before I worry too much.
    -Rorschach-[QUOTED] likes this.
  15. Mar 20, 2025 at 11:46 AM
    TacoGeeloor
    TacoGeeloor Well-Known Member
    Chad
    Washington State
    2020 TRD OR
    Took our new pup to her first vet check up in the Taco today…she seems pretty comfortable in the truck!
    VatoTaco623, MAS, TVphotog97 and 45 others like this.
  16. Mar 20, 2025 at 12:34 PM
    Cement_wheels
    The face says it all. Like most kids, not a big fan of doctors.
  17. Mar 20, 2025 at 12:41 PM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    He can be demoted to “lil Ricky T-shirts”.
  18. Mar 20, 2025 at 12:54 PM
    Mach
    Took some better pics of my anti leveling kit.
    Plus some archive garage u bolt flip love.
    MAS, andthen, Tlaloc1916 and 11 others like this.
  19. Mar 20, 2025 at 1:01 PM
    -Rorschach-
    I have the older version of the bumper, it came with 6 aluminum shims you could use or not, depending on the rest of your setup.
    Is yours not level to the eye or an actual level?
    Don't forget to keep in mind the driver side lean due to the weight of the gas tank/battery.
    Good luck figuring it out. And remember, sometimes close is good enough. :thumbsup:
  20. Mar 20, 2025 at 2:12 PM
    grambo911
    grambo911 Well-Known Member
    SF Bay Area, Kommiefornya
    2023 Lunar Rock Trail Edition
    AWE Exhaust, KARTBOY exhaust hangers, custom 1/0 exhaust grounding, lots of Titanium hardware from my old builds, silly JDM bits from my old Subaru builds, Uniden Bearcat Off Road CB, Firestik 2 w/custom CF mount, custom KARTBOY plate frame with Rigid Industries Spot on ball head mount, Yakima Mega Warrior w/custom CF cross brace. ARP extended studs (not installed yet), Optima Red Top, Siless Insulation in cab. Diode Dynamics LEDs throughout... More titanium fasteners. K&N intake snorkus delete. Greddy hose clamps throughout. DBA 4000XS Brake Rotors. TRD PRO fogs. Dakine Tail Gate Pad. Body Armor Sliders. Icon Stage 4 Lift. Eibach 1" Lift Blocks. Overland Taylor Tune. Rough Country Spare Tire Bed Mount. 67 Designs stuff on the dash. Uniden Radar Detector Hardwired. Spod Lighting Controls. RC Black Series Bumper Lamps RC Black Series Grill Lamp. Body Armor Stealth Front Bumper. Extended Brake Lines. Greddy Shift Knob. More to come of course.
    Makes me wish I had an unnecessary hood scoop. That is rad.
    MTBTACORN[QUOTED] likes this.
