  1. Mar 22, 2025 at 5:04 PM
    934txs
    934txs Member
    Central PA
    2023 Tacoma Access Cab TRD Off-road
    Honestly, I just have some extra of both and when I opened up the tailgate to get the edges of the carpeting in there, it was all this hollow space that I thought could benefit from both. I'm going to be sleeping in the bed once the cap is on when driving cross-country and it's usually in cold climates so I figured, while I have it opened up, might as well shove some insulation in there. I was originally planning on putting the thinsulate between the carpet and the plastic tailgate cover, but this seemed like a cleaner (and less bulging) solution.
    -Rorschach- likes this.
  2. Mar 22, 2025 at 5:11 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Sniff
  3. Mar 22, 2025 at 5:19 PM
    ITmaD
    ITmaD Well-Known Member
    Atlanta
    I had the same issue with my pop and lock, when I opened up the tailgate and checked it out I noticed the mechanism was trying to work but the pressure on the lever was too much so I backed off the screw that tightens down the lever arm a little and everything started working fine and has been for over 1.5 years now.
    When the temp changed from cold to hot I think the plastics just expanded a bit and made it harder with the extra friction to open.
    thomasburk and wcoffman like this.
  4. Mar 22, 2025 at 5:25 PM
    ceddings
    ceddings Active Member
    Clinton
    22 Taco Trail
    Thought about typing it that way but thought it was too on the nose
  5. Mar 22, 2025 at 5:55 PM
    MrMustacho
    MrMustacho Well-Known Member
    Front diff, rear diff and transfer case gear oil changed.
    4xThad, RCrumb, MAS and 18 others like this.
  6. Mar 22, 2025 at 6:58 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Nice, how many miles on the truck? Same weight oil in all 3?
    Looks like FL area, am I right?
  7. Mar 22, 2025 at 7:00 PM
    G_W_Chonkr
    G_W_Chonkr Well-Known Member
    Enzo
    Clackamas, OR
    2020 Tacoma TRD OR
    Finished up my drawer slide system over the last couple of weekends. Few more things to do for the electrical system portion, but its working and happy with the end setup so far.
  8. Mar 22, 2025 at 7:08 PM
    MrMustacho
    Greetings from Largo!
    I have 35,000 on there, I was meant to do it at 30K but life got busy and finally got everything I needed to do this.
    I did end up going with Redline 75W85 that has the same weight as OEM. It wasn't as easy as it would have been with the squeeze pouches but I figured I'd get the closest I could to OEM. For the transfer case I went with Redline MT-LV since I have a manual transmission.
    RCrumb and thomasburk[QUOTED] like this.
  9. Mar 22, 2025 at 7:09 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    OK - gotcha. I had a cap on my old truck. I’m planning to add a cap later, and it’s going to take some work to seal up the bed on the 3rd gen. Good luck with your project.
    :cheers:
  10. Mar 22, 2025 at 7:22 PM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    Great looking Red Nose shop foreman!!!!!
  11. Mar 22, 2025 at 7:30 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Greetings from Brandon area!
    Looks like you are near enough to the specified interval. I got my 75k service coming up probably this summer so I'll be doing the same, again.
  12. Mar 22, 2025 at 7:45 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    In case the newbies haven't found this nice Service Interval chart, I'll post here. I think it is a sticky thread in the 3rd Gen area.
    jeejay, musicisevil, Tacosha and 8 others like this.
  13. Mar 22, 2025 at 8:14 PM
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    Added the last skid. RCI aluminum t-case skid.
    RCrumb, Tacosha, 215Yota and 9 others like this.
  14. Mar 23, 2025 at 4:32 AM
    dand
    dand Blood and tears
    Dan
    Newport News VA
    2021 DCSB TRD Sport Army Green
    Ordered a Rek Gen bed mat.
  15. Mar 23, 2025 at 6:57 AM
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
    I know WD-40 is very popular as a liquid lube, though not sure how it got that reputation, since it is a Water displacement spray, more for drying out ign. wires than to actually lubricate. It does serve well as a mild solvent, so for dried grease it would work better than just adding oil; but even for this, brake clean is a faster prep, where it is safe to use.
    Anyhow, my go-to for penetrating or liquid lube, is Boeshield T-9. Comes in small bottles (some are labeled as bicycle chain lube), and comes in spray cans. This stuff clings very well, creeps well also, and has fantastic anti corrosion properties. I got introduced to this product in the airplane building and maintenance circles, where it is highly regarded.
    T-9 is also possibly the most recommended product for anti corrosion of amphibian aircraft, that will be used in salt water. For this you coat everything with a thin film, and it is so good a creeping, that it is reported to find its way in to all the laps and joints, providing great protection. I wonder how it's performance would compare for use as annual undercoating?
    One warning though, something about the properties of this lube, clogs the nozzle on spray cans, if they are not used frequent enough. So I use the squeeze bottle most often (ensuring my spray will be clogged when I need it, ha).
    Anyhow, great liquid lube, will definitely last longer than WD-40 in any pivot joint.
    MagicToolbox and CB350G like this.
  16. Mar 23, 2025 at 7:24 AM
    934txs
    934txs Member
    Central PA
    What's the thickness of the steel and aluminum on those skids?
  17. Mar 23, 2025 at 7:25 AM
    nevertoomanytacos
    nevertoomanytacos Taco Fan
    3rd Gen
    Agree on your comments on WD40 and on T-9. I use the T-9 on a bunch of stuff exposed to my nearby saltwater environment. CRC 6-56 is another good multi-purpose light lubricant with many of the same properties as T-9. I'm currently using that on my saltwater outboard engines under the cowlings. After use/periodically hose them down with Salt-away, let them dry and then hit metal surfaces, wires and seals with 6-56.
    IMHO, both T-9 and 6-56 are too light for an undercoating but I've never tried 'em...
    CB350G likes this.
  18. Mar 23, 2025 at 8:01 AM
    photodoc
    Northern Kentucky
    '23 TRD PRO 6MT
    Aluminum is 1/4” for the RCI. Not sure what the thickness is of the TRD engine skid. The steel crossbrace is 3/16”. The steel versions are all 3/16”. I am not planning on rock crawling so these are more general protection that’s why I went for the weight savings on aluminum.
  19. Mar 23, 2025 at 8:07 AM
    DavesSR5
    Dave
    Would you mind posting a link to the exact product you are talking about, I mainly just saw spray cans.... lol
  20. Mar 23, 2025 at 8:08 AM
    934txs
    934txs Member
    Central PA
    Didn't realize that was your stock skid. At some point in the very near future I'm planning on getting back into TIG welding and want to make some skids; similar to you, I'm not planning on crawling so aluminum will do just fine.
    photodoc[QUOTED] likes this.
