  1. Mar 23, 2025 at 8:44 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I installed mine in the same spot, had to move it shortly after as I constantly got "key not detected" errors while driving. Once I moved it to the left side, the errors went away.
    Not really sure why the tow controller dial being mounted there caused the issue though.
  2. Mar 23, 2025 at 8:44 AM
    nevertoomanytacos
    nevertoomanytacos Taco Fan
    3rd Gen
    MagicToolbox likes this.
  3. Mar 23, 2025 at 10:57 AM
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
  4. Mar 23, 2025 at 12:01 PM
    jersey jim
    jersey jim Well-Known Member
    Jim
    2018 Cement DCSB TRD Sport 4x4 6MT
    That Boeshield is good stuff, great for squeaky leaf springs among many other things.
  5. Mar 23, 2025 at 12:16 PM
    OscarWildwood
    OscarWildwood Well-Known Member
    Jay
    2023 Ice Cap Tacoma SR5 DCSB
    Finally got my OEM LEDs installed on the SR5 with wiring harness from @Puppypunter! They are so much sexier than the halogens. Install wasn’t too terrible and I’m probably the least handy person I know.
    I’d suggest, as others have before, to put painters tape on the sides of the lens before installing. I got a little scratch on the first headlight. Used tape on the 2nd and no scratches.
    Any suggestions on easily removing the scratch? I’m kinda leaning towards leaving it alone instead of risking making it worse. I know I’ll eventually have more wear and tear anyways. Open to suggestions.
  6. Mar 23, 2025 at 12:35 PM
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    The metal sleeves that go inside the rubber bushings in the shock eye. I have seen a lot of mentions of them for some reason including 2 but most fail to realize they have slightly different inside diameters. Either way both the metal and rubber parts have to be trimmed to fit a 3rd gen Tacoma properly. Although there do appear to be correctly sized replacements available as well.
  7. Mar 23, 2025 at 12:57 PM
    dallasmavs92
    dallasmavs92 Well-Known Member
    DFW
    2020 OR 6MT
    I straightened all the fins on my radiator. My OCD is pretty nuts sometimes
  8. Mar 23, 2025 at 1:51 PM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    I use Novus. It's a 3 stage polish and does a great job. https://novuspolish.com/
    OscarWildwood[QUOTED] likes this.
  9. Mar 23, 2025 at 1:52 PM
    dand
    dand Blood and tears
    Dan
    Newport News VA
    2021 DCSB TRD Sport Army Green
    Forget about it.
  10. Mar 23, 2025 at 2:49 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    I felt your pain. Happened on my new evos. Lesson learned:oops:
    RCrumb and OscarWildwood[QUOTED] like this.
  11. Mar 23, 2025 at 3:29 PM
    OscarWildwood
    Jay
    Sucks man. I know there’s going to be more dings and scratches down the road, but just sucks having it on Day 1 of install. I’m gonna do some research on that Novus stuff @OldSchlPunk mentioned. 50/50 on leaving alone/attempting to polish out.
    NightProwler[QUOTED] likes this.
  12. Mar 23, 2025 at 3:53 PM
    MrMustacho
    MrMustacho Well-Known Member
    YES! Love this chart from Team Oil Drop!
    Tacosha and thomasburk[QUOTED] like this.
  13. Mar 23, 2025 at 4:05 PM
    dallasmavs92
    DFW
    2020 OR 6MT
    I would be kinda iffy about polishing it, might polish the protective clear off and then make it worse long term
  14. Mar 23, 2025 at 4:14 PM
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Washed away the winter salt.. quick coat of Colenite 845 .. replaced wiper blades
    Got a little rust on some of my lugnuts, I'll have to crawl underneath to see what else got rusty with the winter salt. My truck hasn't had a proper bath in several months.
    RCrumb, -Rorschach-, rgljr831 and 5 others like this.
  15. Mar 23, 2025 at 4:40 PM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    Nice chart, but us 6M guys get left out again :(
  16. Mar 23, 2025 at 4:43 PM
    NightProwler
    Harlan
    Maricopa, Az
    Thought this as well..
    What about using one of these clear coat pen applicator things?
    https://www.amazon.com/dp/B009VJXG5W
    thomasburk likes this.
  17. Mar 23, 2025 at 5:02 PM
    Pinchaser
    Alan
    Seems extremely risky to me, to use a solvent based touch up paint, on plastic. Not exactly sure, but I would bet that will make it worse.
    If the scratch can only be seen, but not felt, then the novus 3 step might work (though I do not know about a factory protective coating, if that is a real thing, the novus will remove some of that).
    If you can feel it, especially if you can feel it with a fingernail, then it is too deep for rubbing out, you would need to sand it out and then polish it. In this case, the simplest thing would be to get a kit for yellowed lenses, and it will have the proper sandpaper, and instructions. Though I would recommend leaving it alone. I have sanded many headlights from yellowing, and the only lasting success is when I start with slightly coarser paper than what is provided in the kits, and use a power buffer for all the buffing (separate pads for each size grit). By hand for an hour, does not produce the near perfect result, that a power buffer and the novus products, will do in about half the time. Also, the ones I did by hand were only clear for about a year, the power buffer method has been 2 years, and still looks new.
    Oh, and you probably should remove the headlight and brace it is a wooden structure on a bench; or the process of getting to the edges of the plastic, will remove some of the surrounding paint as well.
  18. Mar 23, 2025 at 5:10 PM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    What about us time wise and not mileage guys?? I just changed my oil @ 6 months with only 1,300 miles on it... :rofl:o_O
    And do I rotate the tires every oil change (1,300 miles) or every 5,000 miles?? :facepalm:
  19. Mar 23, 2025 at 5:13 PM
    DavesSR5
    Dave
  20. Mar 23, 2025 at 5:17 PM
    dallasmavs92
    DFW
    2020 OR 6MT
    dand likes this.
