  1. Mar 27, 2025 at 4:42 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    Yep that was my thought process on what they did.
    I just have the sound deadening in front of it but not touching it, kinda like the factory fabric they have behind the cubbies already, and it is still open on the sides where the molle panel ends.
  2. Mar 27, 2025 at 5:00 PM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    18 months is about as long as you'll get out of them before the adhesive gets bad and they become a nightmare to get off.
  3. Mar 27, 2025 at 5:53 PM
    James2406
    James2406 Well-Known Member
    James
    South Carolina
    2021 TRD OR Premium
    Lots
    AlphaRex dual color fogs added, 16x8 Method 315's added, love the setup now.
    Anytime Locker works good.
    PXL_20250327_235032011.PORTRAIT.ORIGINAL.jpg PXL_20250327_231317332.PORTRAIT.ORIGINAL.jpg PXL_20250327_231353491.PORTRAIT.jpg PXL_20250327_231443288.PORTRAIT.jpg PXL_20250327_231458698.PORTRAIT.jpg
    99kx250, JT_RF, K9tacoma and 23 others like this.
  4. Mar 27, 2025 at 6:13 PM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    They can be swapped side to side, but it gains you nothing. The problem is you have the battery and gas tank on the driver's side and nothing to balance the weight out on the passenger side. The best you can do, without going with new shocks/springs is a 1/4" spacer. I have an extra laying around here I'll send you for cost of postage it you'd like. I'll warn you, I'll be out of town from early tomorrow until at least late the following Fri.
    Kane50, -Rorschach-, artvarck and 2 others like this.
  5. Mar 27, 2025 at 6:23 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Interesting, no gain, did you try it before? That's a fine offer, thank you. Believe it or not I got a 1/4" spacer already installed, and I got an extra, but I don't think another will fit in there not enough threads to make it happen.
  6. Mar 27, 2025 at 6:28 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Aftermarket shocks will come set up with the driver's side pre-loaded a bit more than the passenger to level the truck off. I have Dobinsons that I assembled myself. The instructions tell you how to set them. After my springs did their initial settling, I did have to go in and add a little more preload because I also have an AGM battery in the bed...on the driver's side.
    Edit: You're right, if you already have a spacer in, you won't have room for a second...the studs in the tophat aren't long enough.
    wcoffman likes this.
  7. Mar 27, 2025 at 6:58 PM
    wcoffman
    wcoffman Well-Known Member
    '18 TRD Sport DCLB 4x4 SuperWhite
    Fr pass door handle replace, Tyger step rails and soft bed cover, DDSS3 fogs, TRD skid, OR front tow hook, SokieTech hood struts, fr seat covers (neoprene), metal oil filter housing, magnetic oil plug, Cyclone under hood lights, Blue Sea Systems 5025 Fuse Block ST Blade 6 Circuit with Ground and Cover, Blue Sea Systems 60A DC Panel Mount circuit breaker.
    +3.75 bonus points
  8. Mar 27, 2025 at 8:22 PM
    Junetaco03
    Junetaco03 Well-Known Member
    Bay Area, California
    2019 TRD OFF ROAD 4x4 DCSB
    man that looks nice. Glad I got a cement color too :thumbsup:
    thomasburk, RCrumb and Concrete_taco like this.
  9. Mar 27, 2025 at 8:41 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Gave my truck a much needed wash and wax today, going to do a nice cleaning of the inside tomorrow and steam clean the carpets.
    99kx250, Tacosha, wcoffman and 19 others like this.
  10. Mar 27, 2025 at 8:46 PM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    So it is 10pm and dark outside, with my truck inside the garage and all the lights off except for the trucks exterior lights... I took pictures with and without the glare blockers installed.. I only taped them on temporarily, but same effect...
    Then I took pics (with the garage lights on) of the back of the truck with and without the glare blockers, big difference...
    No Glare Blockers...Garage lights off...
    With Glare Blockers...Garage lights off...
    No Glare Blockers...Garage lights on...
    With Glare Blockers...Garage lights on...
    Now I do have the Vtails, so the reverse lights are crazy bright when using the back up camera...
    I will have to try this again one day once I finally install the anytime camera, I wonder if it will make much if any change without the reverse lights being crazy bright...
  11. Mar 27, 2025 at 9:16 PM
    Metalskool
    Metalskool Adversity Builds Character
    Michael
    2020 TRD 4WD
    It happened to mine. It needs lube or oil to keep the hinges working correctly or it will bend again. I found a thread on this and you can stick a screwdriver in the hinge to lightly pry it back in alignment. @MNGTaco
    https://www.tacomaworld.com/threads/have-to-have-my-fuel-door-replaced.533274/page-3#post-23145342
    works great.
  12. Mar 27, 2025 at 9:31 PM
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Found the perfect spot for a phone mount. Required drilling a hole through the center of the little bracket behind it but no visible screw at least.
  13. Mar 28, 2025 at 4:47 AM
    shoeshineninja
    shoeshineninja Active Member
    2018 Cement DCSB TRD Sport
    Not today but yesterday/last night. Installed DD SS3 Sport fogs
    JPTx, AGTaco22, Tlaloc1916 and 24 others like this.
  14. Mar 28, 2025 at 8:06 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Yay! Science!!
    Hell of a job my man! I appreciate your efforts and pics, especially of the exterior of the truck. The tag lights definitely throw light up the tailgate and into the camera, but the effects are clearly negligible. Prior to swapping bumpers, I could have sworn blockers had a much more pronounced effect on reducing the grainy backup image in the dark with headlights on, but it was apparently just placebo.
    Apologies to @dand for my faulty memory and for my past shitty responses to your comments
    DavesSR5[QUOTED] likes this.
  15. Mar 28, 2025 at 9:11 AM
    TacoDell60
    TacoDell60 Well-Known Member
    OEM Toyota coils are side specific, fyi
    thomasburk[QUOTED] likes this.
  16. Mar 28, 2025 at 9:13 AM
    TacoDell60
    OEM Toyota coil springs are side-specific
    thomasburk likes this.
  17. Mar 28, 2025 at 9:43 AM
    RonnieDarkoh
    RonnieDarkoh Well-Known Member
    Aaron
    2023 Lunar Rock Tacoma TRD OR
    Love that color. There's just something about getting into a clean truck. Just feels like they drive better.
    BBogey likes this.
  18. Mar 28, 2025 at 9:44 AM
    5nahalf
    Erik
    Minnesota
    They really do. In the winter my truck just feels smoother after I exit the touchless car wash.
    doublethebass likes this.
  19. Mar 28, 2025 at 9:46 AM
    Junetaco03
    Damn this is spot on! I don't care if I’m taking it camping I still have to clean it before I leave. I even think my MPG goes up! :rofl:
    RCrumb and 17taconut like this.
  20. Mar 28, 2025 at 3:07 PM
    OscarWildwood
    OscarWildwood Well-Known Member
    Jay
    2023 Ice Cap Tacoma SR5 DCSB
    Finally gave it a bath for the first time since winter. Raptor lights and white DDSS3s on for the haters :D:D:D I love it!
    99kx250, andthen, ttl85 and 13 others like this.
