  1. Apr 3, 2025 at 12:07 PM
    Scotfree
    Scotfree I drive slow
    2021 sr 4x4 2.7
    They are all used to going in one direction, if you got any kind of crud in there sometimes it breaks it free.
  2. Apr 3, 2025 at 4:18 PM
    Mickey65
    Mickey65 Well-Known Member
    Carroll, Maryland
    2023 Solar Octane TRD Pro
    Took the day off yesterday since it looked like it was going to be the best weather wise of the next five. Cleaned and changed the water in the hot tub and then put the IM medium leaf packs on the Taco.
    Took me about 3 hours from the time I grabbed the tools to the time I wrapped up. The only pain was getting the driver side shackle in place. Had to pry the springs down with a bar to where I could get a drift punch in to align the holes. The IM U bolts could be 5/8-3/4 of an inch longer as there wasn't any thread exposed (still a couple threads showing in the nut) when using the nuts they shipped with so I ended up reusing the OEM nuts. Even with the OEM nuts there's only 2-3 threads exposed. Other than that it was a breeze. Sits about 1.25" higher than it did with the stock springs + AAL, guessing it will settle some over time. Took it for a short ride, so far I'd say the ride is better and more smooth over small bumps. Also seems to have taken away a fair amount of roll in cornering which is nice. Will probably grab a set of Timbren bumps soon as those OEM ones are kinda low now.
    Previous to this we've done a Westcott Designs kit on the front, AAL, 4 Runner SEMA wheels w/ 285/70-17 Wildpeak AT4Ws and EGCS swap.
    Added a spacer sleeve on the center pin because of the 2.5 degree shim I'm using between the spring and the axle. You can tell my c-clamps don't get used often. Time to clean them up and wipe them with oil.
    Yes I put the bolt in the e-brake support :) Also note that they no longer have a bolt in the guide that sits next to the fuel tank. Guess enough people complained about it cutting in to the tank.
  3. Apr 3, 2025 at 4:37 PM
    JBoulder
    JBoulder Well-Known Member
    Boulder Creek, CA
    Nice truck!
    Is that a full sized spare under there?
    Went to 265 from 245, like to get a 265 spare, not that I'll ever needed it :fingerscrossed:
  4. Apr 3, 2025 at 4:44 PM
    kona25
    kona25 Well-Known Member
    2022 Black TRD Off Road crew cab
    None
    I just put on some Toyo’s yesterday and like of your much better.
  5. Apr 3, 2025 at 5:20 PM
    Mickey65
    Carroll, Maryland
    It's full sized for what came on the truck stock. I need to get one. I wanted to go with the 255/85-16 for the spare, still 33" but will fit the stock 16" rim. For the others I went from the 16" wheels that came on it to 17" so I could go with load range "C" tires instead of "E". The 255/85-16 was on national backorder in February when I got the others.
    BC Hunter likes this.
  6. Apr 3, 2025 at 6:04 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Finally got the TRD Suspension Upgrade...next month is 4 years of ownership of my Sporty Skewp. :)
    Since it's my USAF Anniversary/Retirement and I got a work Bonus last month, this is well-deserved suspension improvement.
    I had a 2024 Tacoma Limited as a Loaner and I will say, the upgrade put me in the same/firmer ride.
    Thank you Newark Toyotaworld!
    I'm one very happy Taco owner.
    After/Before photo
    99kx250, MAS, andthen and 22 others like this.
  7. Apr 3, 2025 at 7:28 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    I Google-fu for fun. Looks like his Taco in the sat view! I was curious about the tree, too. Damn near the size of the garage door.
  8. Apr 3, 2025 at 7:31 PM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    You should hit those c clamps with some wd-40 instead of storing them in the lake. :boink:
    Hot tub
  9. Apr 3, 2025 at 7:45 PM
    wcoffman
    wcoffman Well-Known Member
    '18 TRD Sport DCLB 4x4 SuperWhite
    Fr pass door handle replace, Tyger step rails and soft bed cover, DDSS3 fogs, TRD skid, OR front tow hook, SokieTech hood struts, fr seat covers (neoprene), metal oil filter housing, magnetic oil plug, Cyclone under hood lights, Blue Sea Systems 5025 Fuse Block ST Blade 6 Circuit with Ground and Cover, Blue Sea Systems 60A DC Panel Mount circuit breaker.
    Mad sleuthing skills there Yo.
    scouterjan likes this.
  10. Apr 3, 2025 at 7:50 PM
    scouterjan
    scouterjan Well-Known Member
    Jan
    22 TRD OR AC in good old white
    You bet, tomorrow
    thomasburk[QUOTED] likes this.
  11. Apr 3, 2025 at 8:37 PM
    CB350G
    Western PA
    Yours is bit tougher… :rolleyes:
    wcoffman[QUOTED] likes this.
  12. Apr 3, 2025 at 8:42 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Looks great Jan. If not the dealer for service, where will you take it for service in the future?
  13. Apr 3, 2025 at 9:10 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    He borrowed your C-clamps ... or did you want to hide that inconvenient little fact from us? :facepalm::crazy:
  14. Apr 3, 2025 at 9:21 PM
    BornaBurden
    BornaBurden Active Member
    Raymond
    Sonoma County
    2022 SR5 4x4
    17" Pro Sema Wheels & Tires, TRD Skid, OTT Tune (mild), ROKBLOKZ mud flaps, Cali raised Rock Sliders, Bilstein 6112/5160 w/ Bilstein UCA's, Tiger Tough seat Covers + BAM molle truck bed systems. Carhartt dash cover, Diamondback Switchback bed cover, Other cosmetic gems
    Finally wrapped up the suspension with the ICON Multi-Rate RXT leaf springs (option 1). Paired up with Bilstein 6112/5160 and Bilstein B8 UCA's that I had installed a few months backtacoma.jpg tacoma2.jpg. California potholes are no longer an issue. I actually look forward to seeing them on the roads and smashing them.
    99kx250, andthen, MrMustacho and 12 others like this.
  15. Apr 3, 2025 at 9:41 PM
    G_W_Chonkr
    G_W_Chonkr Well-Known Member
    Enzo
    Clackamas, OR
    2020 Tacoma TRD OR
    I need to do this this weekend. Pretty straight forward install? Tedious?
    DavesSR5 likes this.
  16. Apr 3, 2025 at 10:18 PM
    Jthizz2006
    Jthizz2006 Well-Known Member
    Jesse
    16 black tacoma DCSB SR5 4x2
    12E6DA84-DC03-4A7E-8DD1-A0864C4209A7.jpg AD554A36-475C-4B85-B1BA-DE6A05432AF6.jpg 6C8A8D59-6B34-4527-B442-D66DA2662D88.jpg Tonight, swapped out my 16’s for 17’s trd gloss black wheels and upgraded to 265/70/17 tires. Also passed 140k miles
    99kx250, andthen, 2k2 and 8 others like this.
  17. Apr 3, 2025 at 10:21 PM
    wcoffman
    It’s my dialect. I knew I should’ve used a different accent….
    CB350G[QUOTED] and artvarck like this.
  18. Apr 3, 2025 at 10:32 PM
    Willy Lump Lump
    21’ dcsbmt
    This and that
    Sea clamps my friend.
    TartanEagle and indoomitable like this.
  19. Apr 3, 2025 at 10:43 PM
    RichochetRabbit
    I shell accept that response beclaws I want to be be civil. :cheers:
    ChortlingPorg, 2k2, RCrumb and 4 others like this.
  20. Apr 3, 2025 at 11:03 PM
    Cadha13
    Cadha13 初音ミク #1 Fan, and Bacon Wrapped Hot Dog Cook
    David
    Albuquerque
    2022 TRD OR DCSB 6MT
    OEM Bed Lights
    Changed the oil in the Taco. Just so busy these days.
    Back to driving.
    andthen, RCrumb, TartanEagle and 3 others like this.
