  1. Apr 5, 2025 at 1:42 AM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    I'd like to see some empirical data on these too. MORR is all the time bragging on the Patagonia's but he's mostly talking pure off-road.
    nastynick[QUOTED] likes this.
  2. Apr 5, 2025 at 4:50 AM
    Odlcjro01
    Odlcjro01 Well-Known Member
    Lee
    Rhode Island
    2021 Tacoma MGM DBC SR5
    LT265/75R16 tire, side steps
    I am running the 265/75/16 Firestone Destination. I want to move up to 32 or 33. Any rubbing issues?
  3. Apr 5, 2025 at 5:48 AM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    @DavesSR5
    20250404_175706.jpg Those were great trucks. Simple and the beginning of OBD times I believe and the start of tuned OEM trucks! I think. Lol . Seen very few around but when they show up they're 20k ++.
    Here's a pic of mine, do you know if the part number stayed the same but they updated it?
    (Tried bumping old dead thread too)
    andthen likes this.
  4. Apr 5, 2025 at 6:04 AM
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Just cancel your order.
    This happened to me with bed Stiffeners.. order cancelled. Money returned. I still don't have bed Stiffeners... I just decided to forget it.
  5. Apr 5, 2025 at 6:11 AM
    stealthmode
    Alberta
    High pressure Pump. I skipped the F for fuel. HPFP.
    thomasburk[QUOTED] likes this.
  6. Apr 5, 2025 at 6:41 AM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    You all are both at 31.6” and 31.7”. Neither at the true 32” tire
    Taco22trdor likes this.
  7. Apr 5, 2025 at 8:07 AM
    Texas-Gorilla
    Texas-Gorilla Well-Known Member
    Thomas
    2016 Tacoma TRD OR
    Picked up a TRD exhaust off FB marketplace for $250. Hoping to install it later today or tomorrow. Previous owner removed the muffler and had a straight pipe welded in its place. The drone on the highway is ridiculous so I’m excited for the TRD exhaust!
    MAS, Fireme, MrMustacho and 2 others like this.
  8. Apr 5, 2025 at 9:02 AM
    TacoDell60
    TacoDell60 Well-Known Member
    The 235/85R16 Destinations are only like 4.5lbs more per tire than the 245/75R16 ATIII in SL load (39.75lbs vs 36lbs). On the highway I have not noticed a difference in feel. Have not done long steady climbs yet tho. The only place where I do feel a slight difference is when I accelerating from a complete stop, and even then it's just barely slower.
    If you were to switch to 245/75R16, you would probably only feel it "off the line" and in your MPGs mostly.
    I'm getting the truck OTT tuned next week so that should be nicer, too.
    What PSI range do you like with these tires, btw??
  9. Apr 5, 2025 at 9:04 AM
    TacoDell60
    No rubbing at all in any direction or suspension flex, they are much too skinny to interfere with UCA etc and not tall enough to hit the fenders
    BC Hunter likes this.
  10. Apr 5, 2025 at 9:06 AM
    TacoDell60
    yes exactly
  11. Apr 5, 2025 at 10:13 AM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Maybe I didn’t read it right but about wiring through firewall grommet- that huge grommet behind the engine fuses/next to brake reservoir, has multiple unused nipples. The bulk harness is centered, that hood latch cable I think is using 1 of the outer nipples but there are many more.
    easier to see (and pass through) from the footwell I believe and it maybe more of a valley than true nipple but
    I wouldn’t use heat, damn you got all the wire to be careful of. Poke it with a hanger and Rheem it out with something bigger or just take some small side cutters and nip it. From the engine side put a dollop of caulk where the wire exits the grommet (that’s what was done from my port installed fogs that I removed)
  12. Apr 5, 2025 at 10:24 AM
    MiTacoTRD
    MiTacoTRD Well-Known Member
    N. Idaho
    2019 Tacoma TRD Off-Road DCSB
    "Rollie" might need to come off too...It's a heavy piece of accessory. :D:thumbsup:
    SlavO2020taco[QUOTED] likes this.
  13. Apr 5, 2025 at 10:27 AM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    I just tried looking it up on a couple of Toyota dealer websites with no luck, I don't know what I am doing wrong and I have never looked to deep into it, sooo..
    You could try poking around on the car nut's YT cannel to see if he says anything about it...
    Here is a pic of my 2023 HP fuel pump...
    andthen likes this.
  14. Apr 5, 2025 at 10:30 AM
    MGMDesertTaco
    I recall 1st gen Tacoma's could be ordered with a step side bed. Looks kinda goofy imo.
    https://www.tacomaworld.com/threads/step-side-bed-anyone.565858/
  15. Apr 5, 2025 at 10:43 AM
    DavesSR5
    Dave
    Good point, as soon as I looked at firewall, I thought of the dangers...
  16. Apr 5, 2025 at 11:35 AM
    TacoDell60
    More goodies trickling in for a front end beefing up + some maintenance:
    -RC Fabrication gusseted spindles curtesy of @zippsub9
    -OEM Toyota spindle seals & O-rings
    -OEM Toyota UCAs
    -Dialed Designs (previously WARfab) tie-rod sleeves
    -OEM Toyota 2TR-FE engine air filter
    Awaiting more parts, more pics to follow when everything is installed
  17. Apr 5, 2025 at 1:12 PM
    Cement_wheels
  18. Apr 5, 2025 at 1:53 PM
    SlavO2020taco
    SlavO2020taco Well-Known Member
    SlavO
    2020 silver sport
    KO3 275/60/17
    It's something some of us have to have a front plate. Went off road today... and we had R 1st touchless tacowash together today.
  19. Apr 5, 2025 at 2:14 PM
    Renniizzle
    Renniizzle New Member
    Sacramento
    2023 Tacoma TRD Off Road
    Baja Designs SAE Fog Lights, CBI Rocksliders, Bakflip MX4
    Shout out Stellar Built in Sacramento!!
    Had them install a Dobinsons IMS lift with a Deaver add a leaf and SPC UCAs. Nice level stance. My dream truck is finally complete. Hope you boys like it!
    Wheels RRW RS2-H 17x8.5 +0
    Tires: BFG KO2 265 70
    jolford, *Delirium*, andthen and 27 others like this.
  20. Apr 5, 2025 at 3:04 PM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    The end of the last day on the above trails, I had an error coming out of 4lo. It seemed to be out, but the dash kept telling me there was an error. Cycling the ignition finally cleared it. Drove home fine. When I got into town, I decided to go to the ball diamonds a few blocks from home and see if/how 4lo would engage. Instant error, but it did engage and now I'm stuck in 4lo. So I limped it home to take a look yesterday after unpacking.
    The first thing I saw was the breather hose hanging next to the actuator...not a good sign. So, I grabbed a screwdriver (JIS, not Phillips) and started pulling the actuator cover and got me somewhere between 1/3 and 1/2 cup of KY stream water. Got it all dried out and back together. When I hit the ignition, I instantly heard the actuator cycle and had no error. I put the trans in neutral, switched to 4hi and bam, into 4hi! Backed out of the driveway and switched to 2wd, perfect!
    Hopefully, that's the end of that.
    Next time you're under the truck, pull the breather hose and check to see if it's splitting...I had to trim off about 12mm.
    MAS, artvarck, scouterjan and 3 others like this.
