  1. Apr 6, 2025 at 7:15 PM
    MGMDesertTaco
    How do they ride out of the box?
    AwesomeLaw68 likes this.
  2. Apr 6, 2025 at 10:49 PM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    Should be 8mm x either 25mm or 30mm long...
    Typically, universal ATF is not good for transmissions today and will likely void any warranty you have left on the transmission... I wouldn't use anything but Toyota WS...
    But you do you...
    K9tacoma, Scotfree and BC Hunter like this.
  3. Apr 7, 2025 at 2:46 AM
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    I installed mine and it only lasted 4 months come to find out it wasn't made correctly and water got into it and they wouldn't do anything to replace it as i purchased it through Amazon, amazon said, sorry due to no extended warranty we can't help you.
  4. Apr 7, 2025 at 3:54 AM
    Toyotas4Tots
    Toyotas4Tots Well-Known Member
    NC
    2023 Tacoma SR5
    DT6 is spec’d as a replacement for Toyota. I appreciate your concern but it’s not something I’m worried about in regards to warranty. They’ll probably find 10 other reasons to wiggle out of a warranty claim if I ever have one.
    thomasburk likes this.
  5. Apr 7, 2025 at 5:32 AM
    Scotfree
    Scotfree I drive slow
    2021 sr 4x4 2.7
    Drain and fill onthe six speed automatic is a process… I do it once a year on all my cars after 50 K
  6. Apr 7, 2025 at 6:05 AM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    No Joke....
    I like to check and top off fluids before a trip. Especially off-roading.
    That trans process is like trying to figure out the temperature settings on a hotel shower. All other fluids, belts, hoses, and critical consumables are observable by the consumer. But not the transmission. You have to schedule half a Saturday to check that one. Not to mention, it takes skills and tools that the average customer doesn't have. I've asked to have it checked during oil changes and they want to charge me for a complete flush and fill. So no - your average Single Mom with Two Kids isn't going to do this.
    And if that transmission fails because it didn't have enough consumable liquid in it? Guess what. That ain't Toyota's Problem that's YO problem.
    My 70+ Father and Mother in law have the same / similar design on a Ford Explorer. Truck was 18mo old and the transmission gave out on a trip to California. Left two elderly people stranded in the Mojave Desert on the edge of cell service. Reason? Insufficient Transmission Fluid. Fortunately Ford paid for the repair. But that doesn't change the fact that they were up the proverbial estuary without a means of locomotion one afternoon on a late summer day. What could have prevented that? A muther flippin dip stick.
  7. Apr 7, 2025 at 7:33 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Massaged my fenders to battle some more rubbing.
    Before:
    After:
    Final product, ha:
  8. Apr 7, 2025 at 10:13 AM
    DavesSR5
    Dave
    It is also spec'd for a multitude of other transmissions, and those other additives may not be compatible with the clutch fibers and solenoids and what nots, ATF is very critical in these transmissions and just because it has all the WS recommended additives in it, doesn't mean that the different other manufactures additives are correct for it... One of the reasons for premature transmission failure is using the wrong (that includes universal ATF) ATF...
    Even the car care nut says that using universal ATF has damaged Toyota transmissions...
    But then again, what do I know...
  9. Apr 7, 2025 at 12:47 PM
    Scotfree
    2021 sr 4x4 2.7
    But it’s sealed, it’s good for a lifetime…
    I would never flush my transmission that’s begging for problems to happen. if you do it the way you’re supposed to, you shouldn’t have any issues because of the leveler tube evens it out, but you’ve gotta make sure your transmission is level. I put my little magnetic level right across the drain plug. Made the mistake of changing it out in my Camry when it was 20° outside and that back-and-forth from drive to neutral took a lifetime, my advice is maybe do it on a warmer day. Diagnosis’ mode is like a Christmas tree on your dashboard display
    GTGallop[QUOTED] likes this.
  10. Apr 7, 2025 at 12:50 PM
    Scotfree
    2021 sr 4x4 2.7
    How are you liking the ARK guards?
  11. Apr 7, 2025 at 1:53 PM
    shaggy135
    I like them a lot better than OEM. The seem to actually keep stuff out of my engine bay too.
  12. Apr 7, 2025 at 2:47 PM
    steve1503
    steve1503 Well-Known Member
    New Hampshire
    2020 SR5
    waiting for a night picture....
  13. Apr 7, 2025 at 2:59 PM
    SlavO2020taco
    SlavO2020taco Well-Known Member
    SlavO
    2020 silver sport
    KO3 275/60/17
    Easy switch... but I'm not gonna lie thought i was about to break the cover on the passengers 1st side i did.. easy 10 minute jib.. I'll feel way better doing thee grill if that every shows up...
  14. Apr 7, 2025 at 3:07 PM
    grambo911
    grambo911 Well-Known Member
    SF Bay Area, Kommiefornya
    2023 Lunar Rock Trail Edition
    AWE Exhaust, KARTBOY exhaust hangers, custom 1/0 exhaust grounding, lots of Titanium hardware from my old builds, silly JDM bits from my old Subaru builds, Uniden Bearcat Off Road CB, Firestik 2 w/custom CF mount, custom KARTBOY plate frame with Rigid Industries Spot on ball head mount, Yakima Mega Warrior w/custom CF cross brace. ARP extended studs (not installed yet), Optima Red Top, Siless Insulation in cab. Diode Dynamics LEDs throughout... More titanium fasteners. K&N intake snorkus delete. Greddy hose clamps throughout. DBA 4000XS Brake Rotors. TRD PRO fogs. Dakine Tail Gate Pad. Body Armor Sliders. Icon Stage 4 Lift. Eibach 1" Lift Blocks. Overland Taylor Tune. Rough Country Spare Tire Bed Mount. 67 Designs stuff on the dash. Uniden Radar Detector Hardwired. Spod Lighting Controls. RC Black Series Bumper Lamps RC Black Series Grill Lamp. Body Armor Stealth Front Bumper. Extended Brake Lines. Greddy Shift Knob. More to come of course.
    Took the family, and the truck, down to San Luis Obispo County. Monterey, Solvang, Pismo Beach, Morro Bay (pictured), Cambria, San Simeon... People hate on Cali but, dang we've got some super dope places to visit and the Spring weather had the wild flowers popping and all the hiking trails green. Oh, and the truck actually saw some dirt finally! Nothing requiring 4WD but, spots I would not have taken my slow car. :thumbsup:
    JT_RF, MrMustacho, Haymaker and 19 others like this.
  15. Apr 7, 2025 at 3:09 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    @Dfpftw
    M8-1.25 x 25mm
    Flange head with washer
    I don’t know the Toyota part number.
    2 years of PA salt and the Fluid Film and Krown spray are holding up.
  16. Apr 7, 2025 at 3:10 PM
    N64_Wallmaster
    N64_Wallmaster Carolina Cajun
    Raleigh, NC
    2017 LTD 4WD
    - Bilstein 5100 Shocks - Icon AAL - Old Man Emu 2885 Springs - 16" TRD Bead lock style alloys - bronze - Falken Wildpeak AT3W 285/75 r16 - IFS Skid Plate; Bare Aluminum - Body Armor 4x4 Revo Rock Sliders - Diode Dynamics SS3 Fog Lights w/ Amber Accent Lights - Tacoma Lifestyle Side View Mirror Sequential Turn Signals - Cali Raised LED Bed Channel Supports; added self-adhesive rubber edge trim - AFE Magnum Pro Dry S Filter - LEER 100R Camper Top - Weathertech Window Deflectors - Bulletpoint Mounting Solutions Dash Mount - TRD Pro Grille with Raptor Lights - Headlight H11 to H9 DIY bulb conversion - Diode Dynamics interior and license plate LED bulbs - FBC license plate light DIR - Replaced chrome LTD mirror covers with oe black - Replaced chrome LTD fog light bezel with oe black trim - Meso Customs map and dome lights - Hot Shot Offroad All Lights On - Metal replacement Toyota oil filter housing - VIOFO A119 Mini 2 dash cam
    Looks great.
  17. Apr 7, 2025 at 3:11 PM
    N64_Wallmaster
    Raleigh, NC
    2017 LTD 4WD
    I'm one of those people who hate -- but it isn't without a bit of jealousy. Truly beautiful country.
  18. Apr 7, 2025 at 3:17 PM
    Nyrob
    Nyrob Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
    Agree i would never "flush" a trans either, normally does more harm then good unless you were having issues and its a last ditch effort. Changing the fluid too much is also not good once a year is extreme and likely too often, light clutch material in the fluid is not a bad thing. I thought i was on top of my maintenance but youre a step above, i change it 30-50k or every 3-5 years. Then again i know that tacoma will likely never see 50k in your hands lol.
    2k2 and Scotfree[QUOTED] like this.
  19. Apr 7, 2025 at 4:10 PM
    grambo911
    I completely understand. I was born and raised here and, without getting into politics, the changes I've seen over the past 50 years make me sick.
  20. Apr 7, 2025 at 5:02 PM
    Scotfree
    2021 sr 4x4 2.7
    it holds like 16 quarts. Draining and filling 3 1/2 quarts once a year doesn’t hurt because that’s about all that comes out. I’m not gonna get to 50 K on my truck until 25 years from now anyway I got a ways to go. Might get to 5000 this year if we have to move. Sitting at 4128 miles. Changed the oil five times though! my Camry has the same six speed transmission. I wish they were all like the Corolla though where you just refill through the dipstick it’s so freaking easy.
