  1. Apr 13, 2025 at 1:36 PM
    artvarck
    artvarck Well-Known Member
    Art
    CO
    '22 AC OR “TotallicA”. Previous '13 SR5 4WD AC MT 2.7
    Installed the Cali Raised catalytic converter shield, and while doing so found that my pickup is only meant to travel forward or backward. I've been doing it wrong all this time...
  2. Apr 13, 2025 at 1:40 PM
    artvarck
    Art
    CO
    That looks like the stock pre-'20 head unit, but with AA/CP. Am I high?
    GTGallop likes this.
  3. Apr 13, 2025 at 1:47 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    I wonder if your breather is plugged, like mine, pushing out your fluids. When you say the bottom plate, are you referring to undercarriage protection?
    Hope you got it stopped leaking!
    auskip07[QUOTED] likes this.
  4. Apr 13, 2025 at 2:07 PM
    ULURU
    ULURU Well-Known Member
    2018 Inferno TRD OR DCSB
    Well, I had it installed for 2-3 years before I noticed any issues... It's already purchased, so the cost is sunk. Buying an OEM version doesn't change that. Besides, the cost of a fuse is negligible when compared to a new unit. The time it takes to pull off the kick panel, check the fuses, and seal it back up? Fifteen minutes, tops. I'd consider OEM if I was starting over, but that bridge has sailed.
    I can open the tailgate the old-fashioned way should it fail again.
    thomasburk likes this.
  5. Apr 13, 2025 at 2:26 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    You are correct and not high, 2018 OEM head unit sporting CarPlay.
    artvarck[QUOTED] likes this.
  6. Apr 13, 2025 at 3:42 PM
    artvarck
    Art
    CO
  7. Apr 13, 2025 at 4:13 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    First step was the remove the breathers and convert to the remote filter setup. No more stock "breathers"
    Yep undercarriage protection.
  8. Apr 13, 2025 at 5:30 PM
    MTBTACORN
    MTBTACORN Well-Known Member
    Ontario, Canada
    23 Tacoma TRD Pro 21 Sportster S
    Lightbar adjusted a bit better. Pics do not do it justice.
    CDDA34B0-0BA0-4B93-9F30-EDC850C49468.jpg A478F54A-AD0A-4F32-B95B-546DFE767BC5.jpg
    K9tacoma, dand, andthen and 3 others like this.
  9. Apr 13, 2025 at 5:42 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Gotcha, was it easy to reach the Tcase stock breather, and are there 2 of them? Frome the TW posts on same topic, seemed like they're buried between firewall and engine.
  10. Apr 13, 2025 at 6:03 PM
    auskip07
    Skip
    Atlanta, Ga
    Nope not at all. Pulled it as far as I could then yanked from under the trans to pull the breather down to me. cut the line going to the transfer case and got a barb that fit on the other end of the pressure fitting of the ARB kit then ran the plastic line up into the engine bay and then over to the fender passenger side. Did this to both but the other line that goes to the actuator (black box. The name escapes me) hooked into the barb from the box without a fitting
    thomasburk[QUOTED] likes this.
  11. Apr 13, 2025 at 6:34 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Got it, I see, I'll remove the trans skid plate and I should be able to see it and get a hand on it. Appreciate it.
  12. Apr 13, 2025 at 6:39 PM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Tested my new headlights. I approve!
  13. Apr 13, 2025 at 7:00 PM
    Tacosha
    Tacosha Well-Known Member
    Andy
    Calgary, AB, Canada
    2019 Black Tacoma TRD OR ACLB 6MT
    minor, TRD skid plate, front recovery points, Regken mud flaps, rear diff breather, AC drain pipe extended. Upgraded sound with active sub woofer, tonneau cover, CB radio.
    Hail problem we have here in Alberta, Canada. Lots of damaged nice cars on the streets, some of them totalled, every next season is worst than previous.
    Was running outside to cover my truck with moving blankets to protect.
    Finally order hail protective cover from Amazon. It's not cheap ($600 CAD), but seems nicely built, thick padded and capable.
    Have a fitment check today, happy with result.
    Will add some loops at the key point at the bottom, for more attachment points against the wind.
    Happy overall, let's see how it works in real conditions.261cfb0c-7856-40bc-bea9-b41af903a07a (1).jpg
  14. Apr 13, 2025 at 7:17 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    You unhooked the radio and put it back on with a screen protector? Expensive protector or if that’s what you felt your labor is worth I’m all about that- know your worth! lol
    but for real?
  15. Apr 13, 2025 at 7:20 PM
    MGMDesertTaco
    carplay added
    musicisevil likes this.
  16. Apr 13, 2025 at 7:48 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    Son of a -bleep-! 32” model not available on the stediusa.com website. :annoyed:
    MTBTACORN[QUOTED] likes this.
  17. Apr 13, 2025 at 8:05 PM
    Breknraj
    Breknraj Well-Known Member
    Roger
    2017 Tacoma TRD Off Road
    Eibach mild lift Relentless Stingray low profile bumper w/ Warn 8000S Warrior Products Roof Rack RRW Sliders
    What was your method of adding it to the HU?
    I might be interested in something like this for my Taco, if it also supports Android.
  18. Apr 13, 2025 at 8:16 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    which CarPlay adapter did you go with?
  19. Apr 13, 2025 at 8:18 PM
    baldbeardedtaco
    FL
    at the end of me writing I noticed the app layout but didn’t want to delete or change what I wrote
    What kit did you go with? Lately I have been leaning towards a new head unit just because it’s 7 yrs old already and some of that- oh no it’s brand new I’m not replacing that - is gone now. I really want to see what a head unit will do for my speaker upgrades
  20. Apr 13, 2025 at 8:36 PM
    MGMDesertTaco
    It's not mine, but if I had to guess....
    https://www.hamiltonmotorcompany.co...carplay-upgrade-module?variant=50345971024186
    Personally, I would opt for a Sony from trailgridpro or the Pioneer 6600nex/7600nex/8600nex.
    https://trailgridpro.com/
    https://www.tacomaworld.com/threads/new-pioneer-dmh-wc6600nex-flush-mount-install.668580/
