  1. Apr 20, 2025 at 8:13 PM
    Tcoma16
    Tcoma16 Galatians 2:20
    California
    2016 TRD Sport
    Thanks for the encouragement :thumbsup:
    TVphotog97[QUOTED] likes this.
  2. Apr 20, 2025 at 8:24 PM
    switch
    switch Well-Known Member
    Norther California
    2022 Tacoma Access Cab
    I upgraded my solar panel from 50W to 100W. The panel is attached using adhesive magnetic tape.
    Always taking the extra time to use split conduit tube and automotive wire harness tape. Also upgraded to MC4 connectors for the panel.
    The panel fits great but I don't like the white boarder of the panel. The eyelets also prevented me from running the magnetic strip all the way to the corners. The new panel is also a plastic sheet rather than aluminum. But ultimately either it will stay on the hood and generate electricity or it won't. That is the test.
    Most important is that it is producing more than 2x power. Here is a screenshot of my Victron solar charge controller. At 5:18 PM the sun is at about a 30° angle.
  3. Apr 20, 2025 at 10:29 PM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    It's a good looking design and compliments the 3G and 4G Tacoma well.
    If I was getting a Snork, I'd run one of those spinny boys at the top that does the Dyson thing with centrifugal (or is it centripetal?) forces to separate out the dirt from the air at the entrance to the snorkel.
    Seymootaco[QUOTED] likes this.
  4. Apr 21, 2025 at 10:20 AM
    Max8
    Max8 Thinking Outside The Box until they close the lid
    23 SR5 DCLB stock
    2012 ARE DCU contractor cap, Transmission aftercooler kit (Iconic Fabrication & Hayden 698), Bed Stiffeners (Kwikfab LLC), Firestone airbag leaf springs, wye connector and pressure gauge, Tailgate security mod (mfgr. by Christian06 on TW), OEM mud flaps, OEM tailgate electronic lock, Tow-Pro Elite Electric Brake Controller, Anytime Backup Camera hardwired 42 ft to camper, RCI Alum. Skid plates & cat covers, 2WD LO mod (BB Tuning), Fumoto oil drain, ECT Always-On Mod (hardness by Funman1steve), 6awg DC DC tow charger wiring, inline 60 amp breakers & battery terminals, Kill switch, KJTO driver side grab handle, Hood hold open gas struts, Scangauge III, Seat Covers (Seat Covers Unlimited... wearing poorly),
    Now that we're ice-free I removed the hockey gear from the back seat... and installed it!
    Kudos to others who posted about this first. Now I can jack from the front center point with my RCI skids in place. Construction adhesive on puck topside and other half of puck on bottomside, sprayed orange.
    FYI puck center point is 5-5/8" from CL of driver side bolt towards passenger bolt,
    and 1-5/8" towards rear of line between them.
    RCI plates created a strong 1/2" gap between alum. plate and molded steel jacking point on truck. Splitting a 1" puck and thickness added from adhesive worked out nicely to fill gap dimension and not deform plate during jacking.
    Edit: the construction adhesive liquefied under jacking pressure in warm weather. Forget the brand but doesn't bode well for construction usage! Will reglue with another brand.
    20250419_104457.jpg 20250419_105223.jpg 20250421_124609.jpg 20250421_124819.jpg
  5. Apr 21, 2025 at 10:33 AM
    Max8
    23 SR5 DCLB stock
    Installed the Kwikvette Internal Bed Stiffeners (https://www.tacomaworld.com/threads/closed-internal-stiffeners.837114/)
    Went smoothly, great product, precise fabrication, teriffic instructions on his site.
    Purchased M10 x1.5thd 30mm flanged hex bolts from McMaster Carr (#93474A223) 2 x $8.60 per ten-pack.
    I wore welding jacket, ballcap and facemask while drilling from underneath.
    Hot oiled metal shavings are dropping on you while drilling Tacoma sheet steel.
    Degreased and primed all holes after drilling.
    20241122_124440.jpg 20250311_163916.jpg 20250311_160031.jpg 20250311_160040.jpg 20250311_160058.jpg 20250311_161950.jpg 20250311_160110.jpg
  6. Apr 21, 2025 at 10:37 AM
    azhiaziam
    azhiaziam Well-Known Member
    The reef ca
    White 2023 trd off-road
    This is the best time of year there. Or the months that end with er.
    grambo911[QUOTED] and dand like this.
  7. Apr 21, 2025 at 11:59 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    That alignment is beautiful! Nice job
  8. Apr 21, 2025 at 3:22 PM
    jpark62
    jpark62 Member
    I would suggest you check out the Hamilton Motor Company CarPlay module for the Tacoma. I installed one and it has been great over the last several months. It retains all the OEM controls and adds CarPlay and Android Auto to your Entune 2.0 head unit.
    doublethebass likes this.
  9. Apr 21, 2025 at 4:07 PM
    Smudge2075
    Smudge2075 Member
    Matthew
    Florida
    White 2023 TRD Off-road
    Not mine, but my wife's 2019 4 cyl sprung a leak in the radiator. 130K Miles and a braze failed. Ordered a replacement from Rock Auto and then went ahead and ordered a new water pump, hoses and serpentine belt. Since I was already tearing the front of the truck apart I went ahead and ordered new pads and rotors. Bosch ceramics. Really pleased with how nice the brakes are. At least as good as OEM so far. I would also like to strangle the engineer who decided to put the fancy plastic plenums that direct air to the radiator right in front of the radiator bolts. What a pain in the rear. Same with not being able to remove the fan shroud without also removing the fan. Makes putting the belt back on tedious... The brakes are a breeze on this truck though. Very well thought out design...
    spin180 and RCrumb like this.
  10. Apr 21, 2025 at 4:24 PM
    flatteneverymountain
    flatteneverymountain Member
    WA
    2017 Tacoma TRD Off-Road Inferno
    Icon Stage 3, Black Rhino Arsenal, KO3 265/75/16
    Just got new 265/75/16 KO3s after 4 years of 285/75/16 Duratracs... I just haven't been going off road and much and wanted a more comfortable ride and who knows maybe slightly better mpgs? LOL, roast me!
  11. Apr 21, 2025 at 4:55 PM
    TacoDell60
    TacoDell60 Well-Known Member
    Please tell us you didn't put a Rock Auto water pump in a 2019 2tr-fe....
    RCrumb likes this.
  12. Apr 21, 2025 at 7:33 PM
    Max8
    23 SR5 DCLB stock
    Kudos to Kwikvette. Beautifully crafted machined parts. Curves and fitment for form as well as function. Buy his product.
    MagicToolbox and ERod27 like this.
  13. Apr 22, 2025 at 5:29 AM
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    I hope you changed your filter out yourself and not let the dealer ship do it, i made that mistake once. they charged me $20.00 for the filter which sells for like $12 at the auto parts store and 35.00 to put it in.
    Never again Balise Toyota over charge me never again.
  14. Apr 22, 2025 at 5:29 AM
    AwesomeLaw68
    Lawson
    Brand new.
    was the back seat east to put on and how much do they run?
  15. Apr 22, 2025 at 5:31 AM
    AwesomeLaw68
    Lawson
    Brand new.
    Rear Tailgate light bar Question.
    I installed an opt 7 rear light bar i used magnets vs double sided tape and or drilling the clips into my body, and it has a wire to tap into the back up light to power the clear light for backing up, which wire do i tap into ? I know it is positive , but what color is the positive in the back up light, red or white?
  16. Apr 22, 2025 at 5:34 AM
    AwesomeLaw68
    Lawson
    Brand new.
    Do you use this tool so you don't have to bleed the brakes, just open the cap, compress the pistons, install the new pads and just close the cap ?
  17. Apr 22, 2025 at 5:35 AM
    AwesomeLaw68
    Lawson
    Brand new.
    Question, why not use internal bed stiffeners ?
  18. Apr 22, 2025 at 5:37 AM
    AwesomeLaw68
    Lawson
    Brand new.
    Could you have removed the factory horns and just used the newer ones? and use the factory wiring?
    grambo911 likes this.
  19. Apr 22, 2025 at 6:19 AM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    I totally agree...
    Like just about anything in life, when/if you can do it yourself it can/will save you money...
    What the dealer charged you is pretty standard pricing at about any non independent automotive shops... But not everybody is mechanically inclined or even care what the cost as long as they don't have to deal with it... I can't tell you just how many customers I have told you could do this yourself before even given them a price and they say to do it even after knowing the price..... I mean look at people paying someone to mow their 1/4 acre yards that are capable of doing it themselves...lol
  20. Apr 22, 2025 at 6:27 AM
    flakbait
    flakbait Well-Known Member
    2022 TRD OR DCSB 6MT
    35% Tint, OEM Floor Mats, Bed Lights, Door Sill Protectors, Bed Mat, A/c Drain Mod, Gas Cap Holder, LED Reverse Tail Lights, Pace Edwards Ultragroove Tonneau Cover, Yakima Crossbars, Black "Tacoma" Inserts, Black Emblems, Center Console and Glove Box Organizers, Paint Matched Bumper Caps, Chalk Bag Bottle Holder, OEM Bed Step, OEM Black Housing sr5 Taillights, Diode Dynamics Hitch Pod, Interior LEDs, Footwell Lighting, OEM Remote Tailgate Lock, VTAIL Taillights and Plenty More to Come!
    Took it on a trip to the Outer Banks, best mod so far too, paid it off early! :woot:
    Bodie Island Lighthouse
    And the day we picked it up, traded in my Corolla Hatch XSE manual - I sure do miss the smoked paprika, color would pop in the sun.
    RealTruck, ClassyTacos, MAS and 12 others like this.
