  1. May 10, 2025 at 5:04 PM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    First bath with my free pressure washer.
    Having a pressure washer is great.
  2. May 10, 2025 at 5:17 PM
    wcoffman
    wcoffman Well-Known Member
    '18 TRD Sport DCLB 4x4 SuperWhite
    Fr pass door handle replace, Tyger step rails and soft bed cover, DDSS3 fogs, TRD skid, OR front tow hook, SokieTech hood struts, fr seat covers (neoprene), metal oil filter housing, magnetic oil plug, Cyclone under hood lights, Blue Sea Systems 5025 Fuse Block ST Blade 6 Circuit with Ground and Cover, Blue Sea Systems 60A DC Panel Mount circuit breaker.
    Yes, a pressure washer will change your life. Careful when using to blast off what you thought were bug guts that turned out to be a paint chip that suddenly enlarged as you applied the pressurized water to the “bug guts”. Not that I have first hand experience, said no one ever!
    Tcoma16 and Jerry311SD[QUOTED] like this.
  3. May 10, 2025 at 5:21 PM
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    lol Yea I can see how that would happen. I did the Tacoma the dodge and the driveway, The driveway changed from dirty to new concrete.
    wcoffman[QUOTED] likes this.
  4. May 10, 2025 at 5:29 PM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    That block heater slides into a recess in the block and heats the block. No fluids, no plugs, just slide it in and run power.
  5. May 10, 2025 at 6:01 PM
    Nadjr
    Nadjr Well-Known Member
    2021 Army Green TRD Offroad
    Crawled under the truck and checked The witness marks I left from when I installed The lift
    spin180, thomasburk and Jerry311SD like this.
  6. May 10, 2025 at 6:09 PM
    Polythemus
    Polythemus Well-Known Member
    B.C. Canada
    2023 MGM Tacoma Trail Edition
    Toyo Open Country 265 75 r16 tires FN Countersteer Type X, 16x8, 0 offset Front clip PPF, ceramic coated.
    Picked up the truck from the detailers. 2 year PPF and ceramic coat inspection, fallout removal and wash.
  7. May 10, 2025 at 6:23 PM
    MGMDesertTaco
    I've run 2 sets. They're garbage tires. :duel:
  8. May 10, 2025 at 6:30 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    they are very quiet for an mt. quieter than many ats ive had experience with. they wear like iron and wear evenly on both trucks ive ran them on without even rotating them. ride quality is also up with the best of them. basically the only flaw with these tires is they suck in the winter but pretty much all mud terrains do. i swap to general grabber atx for my winter setup.
  9. May 10, 2025 at 6:37 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Awesome! Thanks for the info. I had the Grabber ATXs a couple years ago and loved them. Then I went to the Yokohama g003s. I always feel like maybe I should have tried the X3s instead. I’m still considering them but I do a lot of highway miles.
  10. May 10, 2025 at 8:12 PM
    nds0000
    nds0000 Well-Known Member
    It heats the engine block and by that the oil and the water in the block. There is a receptacle hole in the block already, the heater just gets pushed in it and tapped with a mallet a few times. No fluids or oil contact during install.
  11. May 10, 2025 at 8:29 PM
    Quadfxther
    Quadfxther Well-Known Member
    2021 Tacoma DCSB
    265/70R17 Cooper Rugged Trek OEM TRD Pro SEMA Wheels Yotaverse V2 Pro Grille Softopper w/ Custom Rack Toyota OEM Bed Mat Rokblokz Mud Flaps
    I appreciate that. I really wanted a MGM or Silver Sky Tacoma but I got a good deal on this one. Fingers crossed my paint doesn’t start peeling
  12. May 10, 2025 at 8:34 PM
    Polythemus
    B.C. Canada
    And white is easier to keep clean!
  13. May 10, 2025 at 9:10 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Care to expand at all? :rain:
    Did I miss this conversation along the way somewhere?
  14. May 10, 2025 at 9:48 PM
    MGMDesertTaco
    It was covered in the dedicated Toyo at3 thread.
    1. My second set rides out of round like a bias ply until warmed up. They're been road force balanced twice, so I'm calling tire defect. I'm not the only one with this issue in that thread.
    2. The tread life is 30k at best and they really lose traction and performance at 20k. Mine were trash after 25k miles, but I drive like I'm formula 1 and AZ is very hot in the summer.
    3. They howl and make a lot of road noise which sucks for long distance drives. Did I mention they're noisy? Yeah they're loud.
    4. Tire pressure swings wildly with temps and constantly needs adjusting (mine balloon from 31-37 in AZ). (SL tires do from what I've been told.)
    5. They ride a little spongy and the 265/70/16 SL versions are slightly under correct payload capacity for these trucks.
    Aside from the out of round until warmed up issue they're great for the first 15k. No issues hauling arse 85mph across the country for 4-8 hours at a time. I did a big cross country trip last summer with them. AZ to NC and back then all around the west and PNW. CA, OR, WA, ID, CO, UT, NV and back to AZ. I'm not sure why I came back to AZ. :facepalm:
    https://www.tacomaworld.com/threads/new-toyo-open-country-a-t-iii-tire.655094/
    I'm going with BFG K03's next.
    Dmesser92, 17taconut, Tcoma16 and 2 others like this.
  15. May 11, 2025 at 3:10 AM
    TacoCatalyst
    TacoCatalyst Member
    Scott
    Halton, On.
    23 Access cab.
    Beauty weather, so I started on my insulation on the inside of my rear door skin's. At the same time, I swapped out the super tiny speakers.
    dleriche, 17taconut, Tcoma16 and 12 others like this.
  16. May 11, 2025 at 4:39 AM
    jericho777
    jericho777 Well-Known Member
    2023 TRD Off Road
    What should be the normal tire pressure swing? I'm getting 4lb + swings on my factory original Goodyear's.
  17. May 11, 2025 at 5:40 AM
    nds0000
    Installed the footwell lights in the rear. Used protective tube again to ensure the wires do not crack or get damaged when moving the seat. Now I have front and rear and very happy with the new lighting.
    MAS, MrMustacho, alwaysHI and 9 others like this.
  18. May 11, 2025 at 5:58 AM
    wcoffman
    And, as time goes on, there is less to keep clean as the white paint detaches itself from the primer - which is an army green color.
  19. May 11, 2025 at 8:11 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Hmm, nice. I want to get this one done myself, because, stock, ALL those footwells are so dark.
  20. May 11, 2025 at 8:41 AM
    musicisevil
    Alaska
    2019 TRD Sport
    Appreciate you recapping your experience with them! You’re a reasonable guy and I figured I missed something…
    MGMDesertTaco[QUOTED] likes this.
