  1. May 23, 2025 at 4:35 PM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    That looks good on that color truck!!
  2. May 23, 2025 at 4:41 PM
    MGMDesertTaco
    Oil and filter change, car wash, gas. Inside of the truck is still dirty. :anonymous:
  3. May 23, 2025 at 5:15 PM
    roadie
    roadie Well-Known Member
    Forest Falls, CA
    2017 SR5 4x4 DCSB
    Local trusted shop religiously, no leaks no issues. 0W20 full synthetic.
    thomasburk[QUOTED] and CrashZone like this.
  4. May 23, 2025 at 5:46 PM
    BobbyTacoTRD
    BobbyTacoTRD Skewps Ahoy!
    2021 TRD Off Road
    Been a minute since I've been on...I dunno why I never started a build thread. Anyhow, I've done a lot recently...
    SSO front bumper & Smittybuilt winch:
    Modified a molle panel to fit my HD bedrack to attach some Rotopax:
    Added a 10lb propane tank mount to the tire carrier:20250412_193213.jpg
    A buddy gave me his old platform he used in his back seat with his fridge slide. I carpeted it and added some recessed D rings to strap down the battery box I made topped off by a solar panel:
    Then I decided I wanted a little drawer to keep straps and such in. :rofl:
    JDSmith, drizzoh, VLTHNTR77 and 22 others like this.
  5. May 23, 2025 at 6:29 PM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    There is a lot of rubber between the edge of that tire lug/tread and the air inside the tire... Run it as is...
    OldSchlPunk likes this.
  6. May 23, 2025 at 8:28 PM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    I've taken bigger chunks out of my arm and fixed it with duct tape.
    It's fine.
  7. May 23, 2025 at 8:43 PM
    yotamafia07
    yotamafia07 New Member
    Raleigh
    Seattle
    07 Double Cab TRD Lifted
    6 inch fabtech w/ bilsteins, rbp grille, fuel wheels, bfg all terrains
    Meso Customs V2 knob with the @oostroma kit to make it a toggle on off versus momentary. Highly recommend!
    oostroma likes this.
  8. May 24, 2025 at 6:08 AM
    CLOUDL1GHT
    CLOUDL1GHT Well-Known Member
    Garrett
    North Houston
    2023 Tacoma SR
    Yesterday I went ahead and installed ARP 7718s. These are intended for a Toyota Celica however they fit our trucks perfectly. No need to drill a hole in the backing plate of the drum brakes or trim the stud to make them fit in the rear.
    I also removed the very crappy dealer installed vinyl wrap on the rockers. It’s a year old and already turning yellow.
    drizzoh, usmc2msu, chris5887 and 7 others like this.
  9. May 24, 2025 at 6:28 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    I copy you on the "very crappy dealer installed vinyl wrap on the rockers.", mine is 4.5 years old and it's so dirty. Oh, I think I have painted on rocker protection...
    Where did you have all that wrap? (Rockers...) I've only got it forward and rear of rear wheels.
  10. May 24, 2025 at 6:33 AM
    CLOUDL1GHT
    Garrett
    North Houston
    2023 Tacoma SR
    I had it forward and aft of the rear wheel. I did leave the small pieces inside the door handle and on the door edge. They seem to actually be holding up so far.
    Yank it off! I did not need any heat and did not leave any residue. Just a dirt line that came off with spray detailer.
    thomasburk[QUOTED] likes this.
  11. May 24, 2025 at 6:41 AM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Got it, I've still got some on lower door edges as well, took it off already on the door handles and upper door edges. It reminded me of someone with really, really, nasty, grungy, dirty, fingernails. I didn't even want to touch it.
    Anyway good post, and good to know you got it off without a heat source.
    Rocket23 and CLOUDL1GHT[QUOTED] like this.
  12. May 24, 2025 at 6:42 AM
    Gamehenge
    Gamehenge Well-Known Member
    Gunshine State
    2023 MGM TRD-OR DCSB
    Bilstein B8 5100 - Front and Rear. ICON AAL KIT 1.5", ARB/OME 2887 Coil 2", JBA std UCA., FN Wheels F/X Pro 17x8 +0mm, TOYO OPEN COUNTRY A/T 3 - LT265 /70 R17 121S E1 BSW, Overland Tuned,
    Rocket23 and thomasburk[QUOTED] like this.
  13. May 24, 2025 at 6:54 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Those wheels (and the tires) look awesome, great choice with the color of your truck :thumbsup:
    Rocket23 likes this.
  14. May 24, 2025 at 7:02 AM
    Gamehenge
    Gunshine State
    Went from a 2.25"/1.25" Bilstien 5100 and AAL, to a 3"/2" Dobinsons IMS with heavy duty leaf springs.
    Installed Cat shields and a steel front skid plate.
    Upgraded 265/70/17 to Toyo OC ATIII 285/70/17. Zero rubbing under normal use, no trimming needed.
    Added 5 inch strip of 5% tint to top front windshield. Here in South Florida and our UV "12" index, this helps alot. Shields my Garmin mini 2 cam nicely, now doesnt overheat and restart.
    drizzoh, chris5887, Imbored and 17 others like this.
  15. May 24, 2025 at 7:25 AM
    dand
    dand Blood and tears
    Dan
    Newport News VA
    2021 DCSB TRD Sport Army Green
    Are you missing a lug?
  16. May 24, 2025 at 7:25 AM
    DavesSR5
    Dave
    I'm sorry for being a dumbass on the subject, but would anyone care to explain this post?? :confused::confused:
    MagicToolbox and Rocket23 like this.
  17. May 24, 2025 at 8:04 AM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
  18. May 24, 2025 at 8:26 AM
    CLOUDL1GHT
    Garrett
    North Houston
    2023 Tacoma SR
    I like to keep things interesting.
    No that was in the middle of the process. Had one new installed and one old removed in that photo
  19. May 24, 2025 at 8:50 AM
    DavesSR5
    Dave
    That's a shitty job... :crapstorm:
    :thumbsup:
  20. May 24, 2025 at 9:07 AM
    rotus
    rotus Well-Known Member
    Cypress, TX
    2020 White DCSB TRD OR
    Finally got around to installing the stealth bumper I bought 2 years ago. PXL_20250524_154959082.jpg
