  1. Aug 5, 2025 at 5:56 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    Some lessons were learned and reverse drop hitch number 2 has been built.
    I think my issue with the first one was the steel. I bought a prebuilt powder coated hitch, cut it up, and rewelded it together. And despite belt grinding it then wire wheeling it then acetone cleaning it I couldn't get good welds on it. The new one, while not TIG dimes pretty, has solid welds for only my fourth time welding using flux core.
  2. Aug 5, 2025 at 5:59 PM
    ssd2k2
    Keith
    Minnesota
    Mine has squeaked for years, I just accept it as part of life. I have so many other rattles that a clutch squeak is pretty low priority.
    Evostaco[QUOTED] likes this.
  3. Aug 5, 2025 at 6:20 PM
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    That Griots looks to be decently better/longer lasting than the Turtle Wax (I was a big fan of it) and it’s only $22. It’s also 6oz more than the Turtle Wax.
  4. Aug 5, 2025 at 6:26 PM
    OldSaltyDog
    OldSaltyDog Well-Known Member
    Hampton Roads VA.
    2022 DCSB Limited Nightshade Edition in Magnetic Grey
    None to speak of, just enjoying it for the moment.
    Honestly don't know a thing about tinting but have been reading up and it seems like ceramic is the way to go and there's also different quality and the need to do all glass even if just a clear film on the windshield if you want maximum heat reduction, not a miracle but helps quite a bit. If that is in fact true I will probably invest in some for my Tacoma and see if I can gain some benefits. Thanks for your insight.
  5. Aug 5, 2025 at 6:37 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    grinding down all the stock mount welds absolutely sucks. i see some guys leave it there but that looks hack imo. i already had a cmc done that cleared my tires but i couldn't stand to watch these rust in a box any longer after i paid so much to get them shipped to canada...
  6. Aug 5, 2025 at 6:39 PM
    devinzz1
    devin
    2023 aclb trd or mt
    theres been multiple tsbs about this issue over the years. mines never squeaked on my 2023 tho
  7. Aug 5, 2025 at 6:42 PM
    devinzz1
    devin
    2023 aclb trd or mt
    your supposed to lie on your back and pump the little thread on soap dispenser nozzle 700 times. each time leaking a little more gear oil down your forearm
    NightProwler[QUOTED] likes this.
  8. Aug 5, 2025 at 6:43 PM
    m0d4h5
    m0d4h5 Well-Known Member
    New to me 2023 Tacoma v6 base
    The real beauty of that product is next time you wash your truck, dry it with the towel and the existing wax resets and it fucking sparkles for like 1/4 the effort of your original application. You can wet it and spray more on lightly and dry it off with a good quality towel, and it’s like it got a full exterior detail. I was just raving about that stuff in an earlier post here.
  9. Aug 5, 2025 at 6:44 PM
    devinzz1
    devin
    2023 aclb trd or mt
    get whatevers cheapest at the time. they are virtually the same product
  10. Aug 5, 2025 at 7:07 PM
    StinkFu
    StinkFu Well-Known Member
    Pacific Northwest
    2022 Tacoma TRD Pro MT
    AJT Design Tacoma 4x4 Knob AJT Design Tacoma Climate Rings AJT Design Tacoma Door Handle Covers All-Pro Off-Road HD Rock Sliders Alu-Cab Tilting Fridge Slide Aluminum Radio Knobs Android Auto Cable ARB Twin Air Compressor AWE 0FG Exhaust with BashGuard - No Tips Badland Jack Mounts Badland Off-Road Jack Baja Design Rock Lights / Scene Pods Black Door Handle Covers Bolton Velocity Off-Road Kit Cali Raised AC Drip Relocation Cali Raised Center Console Molle Panels Cascadia 4x4 45W Panels & Controller Ceramic Coating CourseMS Phone Mount Desert Does It Seat Blocks & Panel Diode Dynamics Ditch Lights Diode Dynamics Stealth Light Bar Kit Dual Circuit Breaker Battery Tie-Down Expedition Essentials Panel Bracket Factor 55 HitchLink Flag Stickers Glove Box Letter Inserts GloveBox Organizer Hella Supertone Horn Kit Icon 1.5 Inch Lift Rear Expansion Pack Interior LED Light Kit Interstate AGM 24F Battery KC Hilites Under Hood Light Krazy Beaver Shovel and Cover License Plate Frames Magnuson Supercharger MAXTRAX Xtreme MAXTRAX Xtreme Mounting Pin Meso Customs Gasshole Meso Customs Vent Ring Kit MESO Overhead HexRack - Sunroof Mishimoto Radiator MMRAD-TAC-16 Nilight 3PCS 60 Inch Bed Light Strip Nitto Ridge Grapplers 285/70R17 Quick Charge 3.0 Dual Charger Socket RedArc Dual Input + 40 Amp Fuse Kit Rhino Rack Stow It Utility Holder Rhino Rack Stow It Utility Holder Rhino Sunseeker 2.0m Awning Rhino USA D Ring Shackles Rhino USA Trailer Hitch Lock RSI SmartCap Evo Sport RSI SmartCap Platform Rack SDHQ Battery Terminal Kit Seven Sparta Grill Led Lights Shift Knob Adapter SmartCap EVO Security Screen - v2 Smartcap MOLLE Panel Steering Wheel Cover Steering Wheel Emblem SumoSprings Front SumoSprings Rear Supreme Suspensions Front Tow Hooks Switch-Pros 9100 Switch-Pros Power Tray Wiring Bundle Tacoma Door Clean Up Kit Tacoma Door Sills Tacoma Lifestyle Sequential Turn Signals Tacoma Tailgate Inserts Tail Gater Tire Table Total Chaos Bed Stiffeners Toyota Cargo Net Toyota TRD Pro Shift Knob TRD PRO 17 Matte Black Alloy Wheels TRD PRO CAI Box & Accelerator TruckVault - Utility Height Uptop Alpha Rack - 38" Extreme LEDs Uptop TracMOUNT Vinyl Letter Decals for Tailgate Handle Vinyl Letter Decals TRD Pro Bedside Vinyl Letter Decals TRD PRO Grille VLEDS Dual Output Front Footwell Kit VLEDS VTAILS Taillight Conversion Kit WeatherTech Bug Deflector WeatherTech Rain Guards Wescott Tacoma Fox TRD PRO Lift Kit
    Finally wired up and installed my Redarc 1225D and lithium battery in my Smartcap to power my IceCo JP50. Lucked out and was able to modify some random panels I got in the clearance bin at Rack Attack to mount the whole thing against the sliding window.
    PXL_20250803_052244128.jpg PXL_20250803_052255927.jpg PXL_20250803_052306113.jpg
    skyking3 likes this.
  11. Aug 5, 2025 at 7:40 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
