  1. Aug 23, 2025 at 11:52 AM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    I forgot to mention another fun thing on the beach was I got to recover a person stuck in some deep soft sand.
    An old guy, who is out there regularly picking up trash, got stuck. A couple other people were trying to help but couldn't get close enough to pull him and didn't really know what they were doing so I got to show off my recovery skills.
    So I got to off road giving the Bilstein 6112/8100 a good workout, have a quiet peaceful lunch, walk the beach and see some sea turtles swimming, and rescue a vehicle while sharing how to properly recover vehicles to the people there.
    It was a great time, I would 100% go again and recommend Padre Island as a great Texas beach trip.
    I grew up in the Houston area and we would always go to Galveston. Galveston is a dump compared to Padre.
    playdixie, DavesSR5 and iLLFadedBowl like this.
  2. Aug 23, 2025 at 12:52 PM
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    It seems the LCAs will clear at full droop but it would be easy enough to cut a little more out of it until it does clear. Benefit of building things myself
    DavesSR5 likes this.
  3. Aug 23, 2025 at 12:53 PM
    Arjeepguy501
    Arjeepguy501 Member
    Joshua
    Arkansas
    2021 TRD OR DC 4x4
    OTT Tune medium/spicy, Rough Country 3.5 lift, interior and exterior chrome delete, Katskin leather interior with heated and cooled seats, interior LED upgrade, custom back glass graphics Dark window tint, Fuel Beast wheels, Mickey Thompson Baja Boss tires, Westin stubby bumper with light bar and 12k warn winch, Tackform Assault dash mount. Toyota OEM Led headlights and foglight.
    Just got the OTT tune done.
    spin180, playdixie, DavesSR5 and 2 others like this.
  4. Aug 23, 2025 at 1:06 PM
    ssd2k2
    Keith
    Minnesota
    I used the wash. It has new card readers at it so I didn't need a stack of quarters. It is a really nice wash, I assume it got new management because the older reviews are pretty bad.
    I spent about 8 minutes solid with the pressure washer getting all the sand off the frame, and I still missed some. It was caked on thick, I did splash the ocean water a few times so that might have been a contributing factor lol.
  5. Aug 23, 2025 at 1:40 PM
    Palomar Taco
    Palomar Taco Well-Known Member
    Aaron
    So FL
    '23 Taco SR5 2wd Street Truck
    I didn't figure this one out until you posted. Thx
    Brilliant!!!
    DavesSR5[QUOTED] likes this.
  6. Aug 23, 2025 at 1:52 PM
    CLOUDL1GHT
    CLOUDL1GHT Well-Known Member
    Garrett
    North Houston
    2023 Tacoma SR
    Did an oil change on both vehicles. Ignore the fact my garage looks like a hoarders house. Got a shit ton of wood for free that will become a shiplap wall for all my tools.
  7. Aug 23, 2025 at 1:53 PM
    rtn_1911
    rtn_1911 Member
    Auburn CA
    2022 TRD OR DC 6MT
    Changed coolant. Used a vacuum refill for the first time. So fast! No more burping the coolant for me.
    spin180 and DavesSR5 like this.
  8. Aug 23, 2025 at 2:34 PM
    DougE
    DougE Well-Known Member
    Don't know if we're talking about the same place. My place has a hoop (actually several for several lanes) that you drive the car back and forth through as long as it keeps spraying. It looked quite ancient when I used it (within the last year). A pressure washer and a nice appearance would be a total rebuild of what I have been using through the years.
    ssd2k2[QUOTED] likes this.
  9. Aug 23, 2025 at 2:58 PM
    ssd2k2
    Keith
    Minnesota
    This is the one I went to. They did have under spray rinsers.
    https://maps.app.goo.gl/yJfzp1iVYXCvKVep6
  10. Aug 23, 2025 at 3:50 PM
    bmg88201
    bmg88201 Well-Known Member
    Brian
    Quitman, AR
    2022 Tacoma Limited
    I have a coolant question. How much coolant is in the block of 3.5 V6 vs the radiator/recovery tank. Every vehicle I have ever owned I’ve always just drained the radiator and recovery tank @ 50,000. I put 100’s of thousands of miles on my rides over the years and have never had an issue with the cooling system. Yes, I know the coolant in the block is not being drained out. But I figure the new coolant I put in mixes with the engine block coolant and it seems to work for me. Your opinions please.
  11. Aug 23, 2025 at 4:32 PM
    K9tacoma
    K9tacoma Well-Known Member
    Austin
    Central Ohio
    2023 Tacoma TRD Off Road - Lunar Rock
    about 3-4 qts come out of the block drain, usually around 7 qts total between the rad and the block drain. Idk I would say you're fine to just do the rad and skip the block drain but that's me. Either way doing the coolant change in some capacity is better than not doing it
    bmg88201[QUOTED] and DavesSR5 like this.
  12. Aug 23, 2025 at 6:05 PM
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
    50k maintenence
    *Oil & filter
    *Engine air filter - pulled the TRD filter after 50k, going back to oem paper for now
    *Coolant drain and replace- radiator and reservoir only, don't want to mess with the block
    *Power steering fluid extract and replace- did it 6 times
    *Brake fluid reservoir- extraction and fill
    *Cabin air filter
    *Tire rotation
    *Brake check- ok
    *Tire pressure reset to 41- seems to be my sweet spot for the ko3
    *Rear diff fluid check- all good
    That took some time, now I know why dealer charges so much!:anonymous:
    Shout out to Soft Taco at Team Oil Drop for the maintenence links and info. Always makes it eeasier and boosts confidence
    :cheers:
    Next, got to get ready for the 60k and the :censored: spark plugs.
    I'm thirsty.
    :burp:
  13. Aug 23, 2025 at 6:15 PM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    Don't forget the transmission drain and fill at 60K (if automatic)...;)
  14. Aug 23, 2025 at 6:17 PM
    hwntaco20
    Thanks, yup, I see that in the list too. I may look for help on that 1. Gotta watch the vids and see what's involved.
  15. Aug 23, 2025 at 6:18 PM
    DavesSR5
    Dave
    Scotfree and hwntaco20[QUOTED] like this.
  16. Aug 23, 2025 at 6:36 PM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    Hand wash and Aero Cosmetic Wash Wax All. Sometimes I can get away with using the AC by itself but I got a little behind and vehicle was pretty dirty. AC WW does a god job cleaning and conditioning the paint but I definitely need to clay bar or polish before winter.
    Grocery store parking lot.
  17. Aug 23, 2025 at 6:37 PM
    bmg88201
    Brian
    Quitman, AR
    2022 Tacoma Limited
    Thanks for your input. I think that some of the block coolant drains from bottom radiator hose. And it sounds like about half is in the block and half in the radiator. Unless there is something different about a Toyota that I’m unaware of, I’ll just keep doing the same coolant drain I have always done.
    K9tacoma[QUOTED] likes this.
  18. Aug 23, 2025 at 6:47 PM
    tractorfarmer123
    tractorfarmer123 Well-Known Member
    2020 Tacoma
    I got Toyo Open Country A/T 3 tires and they are all shiny and smell like fresh rubber. And they drive super smooth and just hum a little bit.
    spin180, iLLFadedBowl and hwntaco20 like this.
  19. Aug 23, 2025 at 6:47 PM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    Rear diff is easy. When you do the plugs, just pull the plenum. So easy.
    hwntaco20[QUOTED] likes this.
  20. Aug 23, 2025 at 7:44 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    If you have a front differential, Consider buying from a Lexus dealer plugs 90341-24016 and 90341-18060. They have outside hex-heads instead of internal 10mm holes that can strip. I paid $28 for the pair.
    artvarck, RCrumb, 5Sport and 4 others like this.
