  1. Mar 4, 2017 at 4:10 PM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    Well at least you know chrome doesn't work. Looks good the way you did it.
  2. Mar 4, 2017 at 4:10 PM
    NO51
    NO51 Well-Known Member
    Pittsburgh, PA
    2016 Tacoma TRD Sport 4x4
    Pro suspension Fox Black TRD Pro Sema wheels Pro Grille Black Hood Scoop Black Mirror Covers BHLM Pro Tail Lights Rigid industries fog light kit (not pro) Raptor Light Kit Rear camera anytime mod
    Thanks!
  3. Mar 4, 2017 at 4:12 PM
    mrproduxn
    steve
    Retired DoD SE VA
    Just gave me a reason to play with microsoft paint
    NO51[QUOTED] likes this.
  4. Mar 4, 2017 at 4:13 PM
    CaptainAwesome
    CaptainAwesome Well-Known Member
    Calgary, Alberta
    There's 6 bolts, undone them, placed the new box in. It hung up a bit at first, it fits tight, checked under the truck to ensure it had space and forced it in a little.
    The bottom three bolts were challenging especially the center bottom bolt, I hand tightened it and then finished with plyers.
    There's weather stripping that needs to be applied after its mounted. That took me a minute to figure out how to do as it doesn't go into specifics in the instructions.
    I know people have talked about these things rusting a bit. I would have hit it with some anti rust stuff but I can still access the bottom of the box under the truck.
    I like the additional space though!
    OBXPaul and KTJO 4x4[QUOTED] like this.
  5. Mar 4, 2017 at 4:14 PM
    CaptainAwesome
    Calgary, Alberta
    It goes deeper into the side well if the truck. Essentially doubling the storage space.
    TSki[QUOTED] likes this.
  6. Mar 4, 2017 at 4:17 PM
    CaptainAwesome
    Calgary, Alberta
    I literally just installed it. It's 16 gauge steel and has a 10 tumbler lock on it. There's weather stripping you apply so essentially is should be tight. I mean it would be safe to transport a firearm in there but I wouldn't leave one in there at all times. The door locks over the bolts so it's pretty safe. I'm not sure what I plan on using it for yet.
    sparker[QUOTED] likes this.
  7. Mar 4, 2017 at 4:31 PM
    oliver1539
    oliver1539 Well-Known Member
    Kentucky
    2022 Pro/2016 Off Road
    Took some pictures of the trucks today!! 2nd and 3rd generations,so....
    Siblue, Tommyb08, 69TACO16 and 8 others like this.
  8. Mar 4, 2017 at 4:35 PM
    Doogle
    Doogle Well-Known Member
    Jonathan
    2017 Black Tacoma Dbl Cab
    Big thanks to DB Customz for the grill insert!!! Also added another 20" RGB light bar while I was at it. Have to get 2 more black flathead bolts and she's done.IMG_6513.jpg IMG_6508.jpgIMG_6512.jpgIMG_6509.jpgIMG_6489.jpg
    16 trd or, Tommyb08, 69TACO16 and 4 others like this.
  9. Mar 4, 2017 at 4:37 PM
    Jajones Man
    Jajones Man One of the few "Southpaw's" still around.
    Jake
    Eastern Oregon
    2017 Quicksand DCSB M/T
    Portland, Oregon?!
  10. Mar 4, 2017 at 5:52 PM
    R.Shaw
    R.Shaw Well-Known Member
    2016 Tacoma 4X4 TRD
    Someone opened their door and did this at the gym. Walked out to it.
    Went to Toyota in orange Ca and they said I have to purchase the complete set up at $444. It's a 6 inch plastic peice that snaps of and I have to buy the complete housing with gears and all WTF! It's not even color matched.
    This part should be sold separate and parts is stating that's not the case.
    Getting over replacing little things on this truck like this part that should cost no more than $50.
  11. Mar 4, 2017 at 6:21 PM
    an-T1
    an-T1 Well-Known Member
    Ant
    2017 Silver TRD Sport 4x4 DCSB
    nice! I just put some Method Grids on yesterday too!
    TacoMan619[QUOTED] likes this.
  12. Mar 4, 2017 at 6:32 PM
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    A big bump may send that under your brake pedal
  13. Mar 4, 2017 at 6:35 PM
    SandyTRD
    SandyTRD Well-Known Member
    Bobby
    Buford, GA
    '17 Q'sand TRD OR DCSB
    I rear ended someone in my previous vehicle using the same magnet only I had a Glock 19 on it and it didn't move.
  14. Mar 4, 2017 at 6:36 PM
    allVOLfan4LIFE
    allVOLfan4LIFE Well-Known Member
    Mathew
    Charlotte, NC
    17' TRD-PRO-Cement
    Honestly I didn't drive the truck long enough before getting the tires to record an avg mpg so not sure. That being said I haven't seen anything above 17 since getting the truck, so. Not great but tires are too good looking to care.
  15. Mar 4, 2017 at 6:37 PM
    wat0023
    wat0023 Well-Known Member
    Kendra
    Tri-Cities, WA
    03 DC 4x4
    Replaced the interior lights with LEDs. I have some for the license plate but I didn't get that far today!
    69TACO16, 99kx250, SilverII and 3 others like this.
  16. Mar 4, 2017 at 6:41 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Check this out and see if it helps looks like you can them color matched for $40 bucks...
    http://parts.olathetoyota.com/auto-...l-v6-gas-engine/body-cat/outside-mirrors-scat
    Lakeboy and OBXPaul like this.
  17. Mar 4, 2017 at 6:45 PM
    pyankura
    pyankura Well-Known Member
    17 TRD SPORT QUICKSAND
    Changed the oil with Mobil 1 Advanced Fuel Economy 0W20 at 2300 miles. I trust the engineers on most things and I know the 0w20 is what they say to use but man that stuff is like water. I will be changing again at 5k then Toyota will at 10k so I will change oil at 5k intervals.
    The metal particles were very, very small almost like powder. Nothing I'm concerned about but don't want this floating around and grinding shit up for 5k.
    Lakeboy likes this.
  18. Mar 4, 2017 at 7:07 PM
    AgeGuy
    AgeGuy Well-Known Member
    Jim
    2018 Super White TRD Pro
    Lakeboy, Blazingbluesport and R.Shaw like this.
  19. Mar 4, 2017 at 7:09 PM
    IPNPULZ
    going to be fun!
    If it was me I would get the part and go back too the dealer and call them out on there bullshit!
    Toyota wonders why they're getting a bad reputation with dealers.....
  20. Mar 4, 2017 at 7:11 PM
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    Rather harsh. I'm sure it's $40 for the part and $400 for labor. Maybe :)
    2GSPointers likes this.
