  1. Dec 18, 2017 at 6:45 PM
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    Those are 18's in the first? Do you have to be lifted to go with the first set?
  2. Dec 18, 2017 at 6:47 PM
    doubletap
    doubletap Well-Known Member
    Los Angeles
    2017 Tacoma TRD Offroad MGM
    The first picture is 16's. 265/75/r16 BFG KO2 AT. and no you dont have to be lifted to run 265/75/r16
    DubfromGA likes this.
  3. Dec 18, 2017 at 6:55 PM
    Canadianguy91
    Sean
    2016 Limited
    Oh the post says 18. So basically you just went wider? Wgat differences do you notice ?
  4. Dec 18, 2017 at 7:04 PM
    doubletap
    Los Angeles
    My bad that was a typo. Yea just went wider and about half inch taller. Honestly I cant tell a difference in power loss. My mpg is the same and I tested today. All four 285/75/r16 tires weigh a total of 20lbs more than my previous tires. Very small difference.
    DubfromGA and ChadsPride like this.
  5. Dec 18, 2017 at 7:08 PM
    Canadianguy91
    Sean
    2016 Limited
    Right on. I was looking into 275 65 18 not sure if I need to lift tho
    ChadsPride likes this.
  6. Dec 18, 2017 at 7:19 PM
    El Taco Blanco
    El Taco Blanco Well-Known Member
    2017 White Tacoma SR5 4x4 DCLB
    Stock (for now)
    I had to get a little creative but made it work. I saw on the thread for the bracket that another 3rd gen user had made it work. So I gave it a shot and I'm glad I did.
  7. Dec 18, 2017 at 7:25 PM
    doubletap
    Los Angeles
    I am not sure about that size. You may get a little rub because of the 18 inch wheels but cant say for sure if you need a lift.
  8. Dec 18, 2017 at 7:32 PM
    Tricky Taco
    Tricky Taco Well-Known Member
    Kyle
    Colorado
    '17 DCSB OR M/T
    Ran some power to my small storage bin in the truck bed. Put a bead of silicon around it to keep the weather out. Works great and lets me know when the battery is running down. Got the Blue Sea part from Off-grid Engineering web-site.
  9. Dec 18, 2017 at 7:34 PM
    flesheatingvirus
    flesheatingvirus Well-Known Member
    ABQ, NM
    2016 TRD-OR 4x4AT Access Cab - Magnetic Gray
    Tech Package
    Nice. Did you run a wire up to the battery, or tap into something? Does the power feed into the unused, bottom right terminal int the first picture?
    RobP62 likes this.
  10. Dec 18, 2017 at 7:42 PM
    Tricky Taco
    Kyle
    Colorado
    '17 DCSB OR M/T
    I ran it to my Blue Sea fuse box under the hood, then to the battery. Yes, the positive runs to that terminal. The negative terminal is hard to see, its on the next group of wires, one over...if that makes sense.
  11. Dec 18, 2017 at 7:46 PM
    COSD
    COSD Well-Known Member
    Denver Metro
    2017 MGM DCSB OR
    What did you have to do to make it work? Was it easy?
  12. Dec 18, 2017 at 8:07 PM
    R2D2
    R2D2 Well-Known Member
    2016 MGM DCSB 4x4 Limited
    Towing package
    Boricua! Did you get your power back yet?
  13. Dec 18, 2017 at 9:41 PM
    TRD Pro SoCal
    TRD Pro SoCal Well-Known Member
    2017 Cement TRD Pro
  14. Dec 18, 2017 at 9:48 PM
    Rbcb01
    Rbcb01 Active Member
    2017 TRD Offroad
    Let me know next time you want to go. I'm waiting on my fox resis to ship. Installing the skids this weekend.
    Maxcustody[QUOTED] likes this.
  15. Dec 19, 2017 at 12:13 AM
    Woot4ng
    Woot4ng Well-Known Member
    Nate
    Lone Tree, CO
    Black 2017 SR5 Tacoma
    I saw your post saying you’re about to do CMC, what else did you do to fit the 285’s?
  16. Dec 19, 2017 at 2:02 AM
    valdomero
    valdomero Well-Known Member
    Valdo
    2017 Tacoma TRD 4x4 Offroad
    Plasti Dip Grille and Emblems Removed V6 badge
    Here's my modified Level 8 MK6 16x8 0 offset black wheels...
  17. Dec 19, 2017 at 4:11 AM
    Maxcustody
    Maxcustody Looking for answers, Refer to the EAD manual.
    Scott
    Berkeley Springs, West Virginia
    will do. I am waiting on Kings..........last part of my lift still not here.
  18. Dec 19, 2017 at 4:30 AM
    El Taco Blanco
    Stock (for now)
    Wasn't too bad. I had to pop out the light/sunglasses panel. Once I got the bracket started over the rear view mirror button I had to tap the top of the riser bracket to push it past a metal panel that is right above the windshield and under the headliner. It was not hard to do, only took about 10 mins to install. But, because of the metal panel that it has to clear, I probably would never be able to take it back off if I wanted to. But, I won't need to. You could also probably cut 1/4" off of the top of the riser bracket and would not have any issue at all installing.
    COSD[QUOTED] and ChadsPride like this.
  19. Dec 19, 2017 at 4:41 AM
    RevivalOL
    RevivalOL Well-Known Member
    Pete
    Berkley, MI
    2017 TRD Off-Road DCLB
    I really like this. Been trying to figure out a removable way to mount traction boards, but still have them easy to reach. This is a great idea.
    mcharfauros and honey like this.
  20. Dec 19, 2017 at 5:10 AM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    It fits but I did break my windshield trying to put it on the first time....LEARN FROM MY MISTAKES
