  1. Feb 1, 2018 at 7:28 PM
    jptheriot
    jptheriot Meso Investor #5
    Jp
    St. Louis
    3rd Gen TRD Sport DCSB 4x4 / previously owned 1st and 2nd Gen
    Step Bars / BakFlip FiberMax Tonneau Cover /5% Tint Rear 20% Front / Reverse Cam Anytime / Coin Holder / LED Interior and reverse lights / Katzkin Leather Interior / Hondo knobs / TRD Pro Wheels / Black badges / Pro grille / @mesojdm designed Ultimate LED side mirror turn signals, BTLM, BD 3rd Brake Light, GASSHOLE, Ultimate Dome Light, Ultimate Map Lights, Custom Fuse Cover, Custom OEMeso Headlights / In-dash Universal Mount with iOmount
    @mesojdm I owe you one. Didn't have my sound on and scrolled past after about 10 seconds. Now I'm crying.
  2. Feb 1, 2018 at 8:04 PM
    vprgts
    vprgts Well-Known Member
    Walter
    Centreville, VA
    Tacoma TRD Off Road Hybrid
    285/70/17 Nitto Ridge Grapplers, RRW wheels 17 x 8.5, Wescott designs pre collar lift, rough country power side steps, Truxedo pro x15 soft roll up bed cover, OEM bed mat, OEM bed swing out box, OEM Trd pro front skid plate, aftermarket pro grill, diode dynamics led fog lights, OEM sport hood, PPF and tint,
    You’re welcome. Not really. Reach out to him.
  3. Feb 1, 2018 at 10:08 PM
    Imagesetc
    Imagesetc Shock Stormtrooper
    Monterey Park, 2nd Best City to live in USA
    2017 Sup White 4x4 TRD Sport LB
    Runner, Rola Rack,Front/Rear bed cam,Pop N Lock
    Had some free time today and just couldn’t wait for the video from Orion808 on how to pull the dash apart. So I started pulling it apart carefully.
    Actually it turned out to be quite easy.
    Starting with the side panel on the front passenger pry the panel out first. Then pull the lower panel off. You may have to also remove the lower kick panel by your feet as well.
    6C6263C6-F735-4445-A478-168D17451020.jpg Now that exposes the 3 lug nut screws and one screw by the glove box. Upper ones holds the glove box and the two lower on holds the lower air bag.
    Once you’ve removed the 2 air bag lug nutscrew there is one more on the lower left. Then pull it out. That will expose one stew more screw behind the air bag that’s holding the glove box. Inside the glove box are 2 screw on top.
    If you want to remove the panel above the glove box, you need to remove one screw.
    Remove the trim that surrounds the radio (head unit). That will give you access to pull the panel above the glove box off.
    You don’t need to remove the radio.
    Go to the driver side and remove the lower kick panel and then remove the screw on the lower panel under the steering. Without pulling it off just loosen a bit to get to the glossy panel with the emergency flash button.
    That also just pull straight off along with the engine start and AC controls.
    At this point you can disconnect the connectors to get access to the switches below. Just stuck my hand behind the panel to the removed connectors to the USB/Aux switch and cigarette lighter. The USB switch removes by squeezing down a tab in the back of the connector and push it out. There is no nut on the cigarette light to hold it in place which I thought there was. The cigarette lighter also come straight out.
    Thanks to Orion808. I connected a USB/Aux extension to inside my glove box. I will be putting in its place a double USB/voltmeter and on the round hole two more USB/voltmeter plug. Now I will have 4 usb plugs. They will be powered by the cigarette lighter connector. Until I decide to change it to something else.
    If you want to remove the panel holding the switches you will have to remove the side panels around the shifter. I can see two screws on each side that you will need to access. Since I don’t need to at this time, I have not gone that far. I may next time since I may want to install another USB plug on the back of the console so passengers in the back cab can also plug in.
  4. Feb 1, 2018 at 10:19 PM
    Lost In The Woods
    Lost In The Woods 4 out of the 5 voices in my head say go for it!
    Eric
    Buckley, WA
    21 Gladiator Rubicon Diesel
    An unusually high amount of pinstriping.
    My side hurts from laughing! The commentary was classic.:rofl:
    RobP62 and crashnburn80[QUOTED] like this.
  5. Feb 1, 2018 at 10:32 PM
    hellppy
    hellppy Well-Known Member
    Sean
    Phoenix, AZ
    2018 TRD Off-Road DCLB
    Stopped by @JerryTaco's house on the way home today and got the TRD fog bezels switched out for SR5 fog bezels. Thanks buddy!! The SR5 fog bezels really do flow better with the lines of the truck. They even match the shape of the bezel frame behind the bulky TRD bezels.
    Here are the part numbers if anyone is interested:
    Driver's Side: 52128-04020
    Passenger Side: 52127-04020
    TRD fog bezel
    SR5 fog bezel
    TRD on the left, SR5 on the right.
  6. Feb 2, 2018 at 3:46 AM
    NIU_Huskies
    NIU_Huskies Well-Known Member
    2017 Toyota Tacoma TRD Sport DCLB
    Still slowly coming along on the custom audio system.
    Here's the subwoofer boxes post-fiberglass and bondo.
    Here you can see the Arc Audio PS8 processor mounted above the passenger subwoofer box and the power distribution block mounted above the driver subwoofer box. You can see the Alpine PDX-V9 amplifier mounted in the middle between the two boxes as well.
  7. Feb 2, 2018 at 3:59 AM
    Auroraboy
    Auroraboy Well-Known Member
    Dave
    London, Ont., Canada
    2017 Quicksand DCSB Off Road
    Husky Weatherbeaters, BAK Revolver X2, front bedrail, Salex console tray, Predator Steps
    For whatever reason, Canadian TRD Off Roads come with the "SR5" fog bezels. Not sure what the SR5's come with.
    RobP62, KTJO 4x4 and hellppy[QUOTED] like this.
  8. Feb 2, 2018 at 6:03 AM
    hellppy
    Sean
    Phoenix, AZ
    Really? That's interesting. Probably because it looks better! :thumbsup:
    Stopmithering and RobP62 like this.
  9. Feb 2, 2018 at 6:21 AM
    khill007
    khill007 Active Member
    2018 Tacoma Double Cab SR, V6, Auto, 4x4
    Hello all! New here on the forum. I just traded in my 2018 Chevy ZR2 on a 2018 Tacoma SR Double Cab, 4x4, V6. Long story on why I got rid of the ZR2 but it was a lemon and GM REFUSED to help me?!? too bad...suspension was the best I have ever experienced on a off road vehicle. Anyway, got my wheels today....let the fun begin!
    RRW RR2-V, 17 x 8.5, 0 Offset! Wrapping them with 265/70/17 C load BFG KO2's. Should have my King RR/Adjuster coilovers Monday. Will post picks as I upgrade!
    SilverII, arnette64, dskakie and 18 others like this.
  10. Feb 2, 2018 at 6:40 AM
    WOOYANGCLAN
    WOOYANGCLAN Well-Known Member
    Isaac
    Orange County, CA
    2017 Black Tacoma TRD Off-Road 4x4
    Anybody in the OC area (714). My truck got broken into last night at about 4:11am. Heard an alarm but didn’t think anything of it. Luckily I live in a gated community so I’ll be checking up on who came in around that time. They didn’t get away with anything of value. However took my tire gauge and some other small car components so I thought I’d post this.
    RobP62, Daddy_Firebird and ChadsPride like this.
  11. Feb 2, 2018 at 6:48 AM
    YDCtaco
    YDCtaco Well-Known Member
    Alexandria, VA
    2016 DCSB TRD OR 4x4-Auto
    lol "tire gauge"
  12. Feb 2, 2018 at 6:49 AM
    9TRDTCO
    9TRDTCO Well-Known Member
    You should post this here
    https://www.tacomaworld.com/forums/southern-california.43/
  13. Feb 2, 2018 at 6:52 AM
    Ayeele
    Ayeele Well-Known Member
    Houston, Tx
    18 TRD Pro, 04 DCSB 4x4
    Added spidertrax spacers.. definitely looks better but makes my tires look skinny
  14. Feb 2, 2018 at 6:55 AM
    COdude3
    COdude3 Well-Known Member
    Colorado
    2017 SR5 Access Cab 4x4
    Pro Grille, Pro Whls, King Shocks, 265/75R16 A/T3
    Who makes the long cases?
    ChadsPride likes this.
  15. Feb 2, 2018 at 6:58 AM
    cshrum
    cshrum Well-Known Member
    CO Springs, CO
    17 blue TRD sport DCLB
    I think it looks GOOOOOOD!
    Maybe the tires would look better if they were half as shiny as your pretty truck? :boink:
  16. Feb 2, 2018 at 7:00 AM
    Ayeele
    Houston, Tx
    Never bothered me.. i only notice when people say that lol maybe i should shine them up. Any suggestions how? Simple tire shine?
  17. Feb 2, 2018 at 7:00 AM
    ZYBORG
    ZYBORG Let's roll...
    TX / S. FL
    3G TRD OR
    Truck tires look much better in their natural element. :boink:
    bls82261, RivetNutBob and Ayeele like this.
  18. Feb 2, 2018 at 7:01 AM
    ZYBORG
    TX / S. FL
    3G TRD OR
    Do NOT shine them up. Looks terrible. IMO.
    RivetNutBob likes this.
  19. Feb 2, 2018 at 7:16 AM
    cshrum
    CO Springs, CO
    He's got to go one way or the other though...make the rest of the truck match the tires and be "a la natural", or make the tires match the truck and give em a little love. I'm not a fan of the goopy wet tire look. They just seem to collect all the dust and everything anyway.
    Ironically, Stoner's More Shine does quite well. One coat does the trick for a clean and not looking like a poser mall crawler with that drippy, goopy look. Even 303 does a good job.
  20. Feb 2, 2018 at 7:32 AM
    pdenajim
    pdenajim Well-Known Member
    Jim
    Pasadena, MD
    2017 Inferno Tacoma TRD OR DCSB
    Black MBRP dual exhaust, aftermarket TRD Pro grille, AVS dark smoke hood deflector & dark smoke vent visors, BedRug, BAK Industries Revolver X2 bed cover, aftermarket TRD Pro Tail light assemblies (DEPO), orange vinyl decals on engine cover, door sills, and glove box, LED headlights & fog lights, KICKER speakers, piano black tailgate TACOMA inserts, center console organizer tray, black stainless steel licence plate frames, smoked license plate "protectors", ME-SO Customs Ultimate LED mirror turn signals, Ultimate Dome Light, V2 Map Lights & coin holder, Toyota bed extender, Pop & Lock Power Tailgate Lock, Fortin EVO ALL Plug & Play Remote Start, TRD PRO headlights, Redline Hood Struts, FJ Cruiser 2007-2014 TRD Pro SEMA 17" MATTE GRAY Alloy Rims, COOPER DISCOVERER S/T MAXX 255/80-17 Tires LR E, Gen 2 TRD Pro Suspension, 2" AAL, TRD Pro CAI, Mobtown sliders and full aluminum skids, ARB Safari snorkel. On deck waiting installation: under hood LED lights, bed, U-Bolt flip, Sport Hood, passenger door touch sensitive door handle. Future Mods: "Always On" console USB power mod, "Default On" ECT Power mod, LED lights strips inside the bed, diff vent extension
    Welcome. Nice wheels. :thumbsup:
    Looking forward to pics of the truck with the new wheels/tires.
