  1. Feb 5, 2018 at 4:47 AM
    atebit
    atebit What's all this, then?
    The basement of the Alamo
    18 Inferno TRD OR 4x4 AC
    Ceramic coated a few days ago.
  2. Feb 5, 2018 at 5:12 AM
    CoastieRon
    CoastieRon Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
    Yes. We have a large camper we are dowsizing from but will still require a brake controller.
    RobP62 likes this.
  3. Feb 5, 2018 at 5:17 AM
    RivetNutBob
    RivetNutBob Right Ain't Wrong and Left Ain't Right.
    New England
    2017 MGM ORDC MT SB
    Won't work with the MX4 in the open position unless you move the box away and or down from the back of the cab. The lid would hit the cover
  4. Feb 5, 2018 at 5:23 AM
    RivetNutBob
    New England
    2017 MGM ORDC MT SB
    Mind if I ask what dealers price was for the parts?
    Hate the chrome bumper on my Off Road and don't have the coin for a real (Fab4) bumper right now.
  5. Feb 5, 2018 at 6:50 AM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    Be careful where you put it. There are airbags in the A pillar.
    RobP62 likes this.
  6. Feb 5, 2018 at 6:55 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It was in a PM, but here you go:
    The interior panels are only held in with clips:
    -- Pull off the head unit trim piece with the two vent outlets.
    -- Pull off the right side of the panel under the steering column. You need this one partially out since the HVAC controls have a little return on the left side that captures it.
    -- Pull out the HVAC controls. There is a tab at the top that interferes with the head unit. I was able to wiggle it out and back in without loosening the radio, but that is only four 10mm (I think) bolts that only have to be loosened a bit. I disconnected all the harnesses to give me more space to work.
    -- From there, you can reach around to the back side of the power port. The harness just pulls off towards the front of the truck.
    -- Looking inside the power port on the metal part, you can see a black square on the bottom. There is a similar one on the upper side. With a small screwdriver, gently push on that black tab while pushing the metal part toward you (toward the back of the truck). Do the same with the upper tab. The metal part will come out toward you.
    -- Once the metal part is out, you can remove the black plastic piece by pulling it toward you also.
    From there, you can pull the harness though the open hole and release the plastic connector, if you need to.
    To do that:
    -- Open the two small snap covers on the front side.
    -- With a small, flat screwdriver, release the tabs under the connectors on the back side of the connector.
    -- The metal connectors will then slide out. They are two different widths, so there is no worry about which is which.
    I had to trim off a small amount of the sleeving to expose the crimped joint.
    Soldering on to the power port connectors is a great place for switched power. The amperage listed on the power port cover (that you can't see until you remove it) is pretty high.
    The third pic in this post shows all the pieces:
    https://www.tacomaworld.com/threads...-3rd-gen-today.399305/page-3702#post-16846660
    ChadsPride likes this.
  7. Feb 5, 2018 at 6:56 AM
    Doogle
    Doogle Well-Known Member
    Jonathan
    2017 Black Tacoma Dbl Cab
    Anyone else having condensation issues with the 2in1 DRL/Fogs ? Pretty sure it’s from the CAI in passenger side wheel well but they’re supposed to be sealed units. Dealers going to replace but trying to get them to switch it to the Rigid fogs.
    SilverII, RobP62 and ChadsPride like this.
  8. Feb 5, 2018 at 7:17 AM
    odinsbro15
    odinsbro15 Well-Known Member
    Eric
    LOS ANGELES CA
    2016 Gray Tacoma trd offroad DCSB
    ROUGH COUNTRY FRONT 2 INCH LEVEL KIT, TINT, DIPPED RIMS, DITCH LIGHTS, CUSTOMER REAR FACING LIGHT, INTERIOR MATS
    DONT DO REAR BLOCKS!!! go for an add a leaf. rear block if you had to do it should never get more than 1.25" otherwise they get unstable.
    RobP62 and chuckman4112[QUOTED] like this.
  9. Feb 5, 2018 at 7:21 AM
    pete37
    pete37 Well-Known Member
    peter
    Toronto Canada
    2008 trd offroad aclb 2016 trd sport stolen 2019 TRDORSB
    I found a couple pics
    SilverII and Geeder48 like this.
  10. Feb 5, 2018 at 7:22 AM
    h5863emtmatt
    h5863emtmatt Well-Known Member
    San Diego
    17' TRD OR 4x4 DCSB
    Method Vex311, Toyo Open Country AT, 2.0 Fox Performance Coilovers/Reservoir, Total Chaos UCA, Pelfreybilt, Prinsu Cabrac
    Yep tha man once again hand in my pockets
  11. Feb 5, 2018 at 7:35 AM
    odinsbro15
    Eric
    LOS ANGELES CA
    got my ECG grille installed the other day! looks great and already got a bunch of complements from other taco owners on the street. also got a W for our mens upper Softball tourney. lastly im gonna sell my 3rd gen grille with color matched surrounding (no chips or scratches on the color matched part the black grille will need to be touched up.)..
    SilverII, RobP62, honey and 4 others like this.
  12. Feb 5, 2018 at 7:35 AM
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    what about a 1" block? Or better to just get 2 more bilsteins for the back?
  13. Feb 5, 2018 at 7:39 AM
    arnette64
    arnette64 Well-Known Member
    Amos, QC (Canada)
    2016 Inferno TRD Sport Double Cab 4X4
    '16 Inferno TRD sport DC
    Hey I really like this little Mountains decal, where did you bought it?
  14. Feb 5, 2018 at 7:40 AM
    odinsbro15
    Eric
    LOS ANGELES CA
    1" ok but get a good one like TOYTEC.
  15. Feb 5, 2018 at 7:52 AM
    BT17
    BT17 Well-Known Member
    B
    17 Tacoma TRDORDCSB 4x4 AT KDmax SLT/Reg
    a few...
    Here’s a mod’s I did to my Tacoma OR.
    Completed a project this week on the ‘17 Tacoma. Installed Rigid Industries Tacoma grille with their SR-Series Pro 20” Spot/Flood...lumens 34,585 ⚡️
    I’ve had the Rigid Industries 30” SR spot/flood light on the truck since last February - lumens 13,500
    Added a new Optima yellow top battery.
    Plus added the 3 switch plate and the appropriate switches for the current RI lighting. I’ll add the 6 pack of RI Rock lights at a later date in the springtime.
    CFED78A5-1729-4F5A-AC5C-C34C3472F4F1.jpg 64970B88-5B30-4F5B-8345-EC0706753E0F.jpg 7AD2DF88-F5FC-4F50-95C7-791D0D5C964D.jpg
  16. Feb 5, 2018 at 8:13 AM
    WrongWay
    WrongWay Well-Known Member
    South Carolina
    2017 Tacoma TRD Off-Road AC 4x4
    Keeping the TRD stickers? I kept mine for a few months after debadging, but finally decided to pull them off as well. Totally clean now.
  17. Feb 5, 2018 at 8:20 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Way better with those large stickers gone, IMO.
  18. Feb 5, 2018 at 8:29 AM
    itsdug
    itsdug Well-Known Member
    Doug
    Fentress County
    2018 DCSB 4x4
    Would be the first to go for sure.
    tonered likes this.
  19. Feb 5, 2018 at 8:30 AM
    Daddy_Firebird
    Daddy_Firebird Well-Known Member
    Colorado
    2016 TRD Off Road DCSB MGM
    -Toytec Aluma 2.0 -SPC UCAs -Icon RXT Leaf Pack -Front & Rear Durobumps -Cooper ST Maxx Skinnies on Methods -RCI Skids -Leitner Rack -Custom Billet Shift Knob (7r41lbr34k3r) -Stromung "Tucker" Exhaust -Expedition Essentials TTM
    I agree!
    tonered[QUOTED] and Bridge4 like this.
  20. Feb 5, 2018 at 9:00 AM
    dwill913
    dwill913 Active Member
    Dustin
    17 Off Road DC MT
    Bone Stock
    Probably gonna end up ditching them too.
