  1. Feb 20, 2018 at 9:15 AM
    mrretep
    mrretep Well-Known Member
    CA
    2017 TRD OR DCLB
    Dang, hopefully that does it. Be careful when installing the hardware that came with the bakflip their screws are made of butter.
  2. Feb 20, 2018 at 9:16 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    Awesome! Can't wait to see everything installed. Thanks for the support!
    -Bailey, Baja Designs
    www.bajadesigns.com
  3. Feb 20, 2018 at 9:18 AM
    dynamicweight
    dynamicweight Well-Known Member
    I got my exhaust reroute done this weekend. $83 out the door and he took me as a walk-in on a holiday! Babes and Lightning Muffler in San Jose. Everyone else in the Bay Area I called (who were even willing to do it...) were 120+. The work looks good to me. No rattles or codes. I got the first skid on but was lazy about the other two. I'm nervous about drilling holes in the frame for the cross member. I want to make sure I protect them from corrosion. Does anyone have a suggestion for what paint or whatever I should use?
    BYE FELICIA
  4. Feb 20, 2018 at 10:15 AM
    cshrum
    cshrum Well-Known Member
    CO Springs, CO
    17 blue TRD sport DCLB
    Better have lights, or is it really an approved "meso" product?
  5. Feb 20, 2018 at 10:45 AM
    cshrum
    CO Springs, CO
    I stripped out one of mine installing my Bak Revolver. Ended up using one of these bad boys to get the stinking thing out:
    https://www.amazon.com/dp/B01NGTLM4...t=&hvlocphy=9029023&hvtargid=pla-318198613386
    Definitely takes some effort to get them out. I ended up using a good torx socket bit, that way I could put one hand pressure directly onto the bolt head, and use the other for loosening them. Toyota wasn't messing around when they installed these bolts! Good luck! The others should come out better since you've already put penetrating spray on the others.
    Bridge4[QUOTED] likes this.
  6. Feb 20, 2018 at 12:06 PM
    ZekeR7
    ZekeR7 Well-Known Member
    2018 TRD Off-Road 4x4 Quicksand
    Bought new recovering/camping gear that’ll fit in the Plano case I got:
  7. Feb 20, 2018 at 12:16 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    You are absolutely not supposed to use anything but hand power to loosen them, and to finish the tightening. You, sorry to say, found out the hard way. :frusty:
    On the upside, you will be able to buy more when you do get those stripped bolts out.
  8. Feb 20, 2018 at 12:37 PM
    Daddy_Firebird
    Daddy_Firebird Well-Known Member
    Colorado
    2016 TRD Off Road DCSB MGM
    -Toytec Aluma 2.0 -SPC UCAs -Icon RXT Leaf Pack -Front & Rear Durobumps -Cooper ST Maxx Skinnies on Methods -RCI Skids -Leitner Rack -Custom Billet Shift Knob (7r41lbr34k3r) -Stromung "Tucker" Exhaust -Expedition Essentials TTM
    Have the same hatchet.. That thing is shaaarrrrrpp!
  9. Feb 20, 2018 at 12:51 PM
    tomgru
    tomgru Well-Known Member
    Thomas
    PNW
    2021 TRD Pro
  10. Feb 20, 2018 at 12:54 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    You're welcome.
  11. Feb 20, 2018 at 1:13 PM
    Shermyota30
    Shermyota30 Well-Known Member
    Bay Area
    17 sport 2wd doublecab
    Finally got my diamondback cover!
    Installed pop and lock at the same time.
  12. Feb 20, 2018 at 1:37 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    1 year old today :).
  13. Feb 20, 2018 at 1:50 PM
    HellinaHelmet
    HellinaHelmet Well-Known Member
    Nick
    N GA
    2017 SSM DCLB TRD OR 4x4
  14. Feb 20, 2018 at 1:57 PM
    DubfromGA
    DubfromGA Well-Known Member
    Greg
    2017 Black SR5 4WD
    I use a foam cannon filled with 2 oz of Chemical Guys V07 car soap & warm water. Even with my wimpy 1,500psi pressure washer it makes decent foam. When this one wears out I'll definitely go with a more powerful model.
    Chemical Guys makes some outstanding products.
  15. Feb 20, 2018 at 2:08 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Too funny. I'll remember mine, 'cause It's the day after my Birthday! :thumbsup:
  16. Feb 20, 2018 at 2:17 PM
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    I ended up getting it with the pb buster, but one more from the side rail had to be screwed out.
    I have that same kit! I had to use it on one of the side rail bolts that wouldn't come. Ruined two t30 bits trying to get it even with a lot of pb buster. Oh well, got some new ones and it's all set.
    I tried the power tool AFTER it had already been messed up from hand turning attempt. With the bakflip bolts that you use for the side rails making the OEM ones useless, I ended up being just fine and didn't need extras as I just re-used the toyota bolts in the two I needed to replace.
  17. Feb 20, 2018 at 2:30 PM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    Installed the Meso V2 Ultimate Red Map LEDs :thumbsup: like always an Awesome Product.
    SilverII, raykru, DubfromGA and 5 others like this.
  18. Feb 20, 2018 at 3:03 PM
    EastVanTaco
    EastVanTaco Well-Known Member
    2017 super white Trd Sport DCLB
    What size rim and tire did you get stuffed under ..im wondering if a 275/70//17
    would fit. Just curious why you purchased another rim instead of a steelie or watever?
  19. Feb 20, 2018 at 4:06 PM
    TacoDoc1898
    TacoDoc1898 Well-Known Member
    Live Oak, TX
    2017 Black DCSB
    Got new shoes.
    SilverII, Bridge4, Miraclejoe and 3 others like this.
  20. Feb 20, 2018 at 4:44 PM
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    9TRDTCO, Koitz and tacotroy17 like this.
