  1. Mar 27, 2018 at 7:35 AM
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    12" King Triples on TommyGun Fab shock relocations, TC King 2x2 bumps, Archive Hammer Hangers with 3.6 shackles and custom Deaver U402s
    taco 16, AzDevil, Ayeele and 13 others like this.
  2. Mar 27, 2018 at 7:39 AM
    920special
    920special Active Member
    Josh
    Los Angeles
    2017 DCLB TRD OR
    Popped in Mesos turn signals before work!
    SilverII, cshrum, Miraclejoe and 6 others like this.
  3. Mar 27, 2018 at 7:41 AM
    bernk-80
    bernk-80 Member
    bern
    2018 sport double cab short bed.super white
    pro wheels,debadged and removed stickers.
    anywhere to buy oem off road matte black flares at reasonable price ? my local dealer wants $900 for set.
  4. Mar 27, 2018 at 7:42 AM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
  5. Mar 27, 2018 at 7:52 AM
    Jon8251
    Jon8251 Well-Known Member
    Jon
    Southern MD
    2017 Quicksand DCLB Off-Road
    TRD Pro suspension HS Progressive AAL 255/85-16 DC Extreme Country TRD Pro grille Softopper Internal LEDs Other misc crap
    You could see if someone wants to trade with you. But you will need more posts and time to be allowed to post on the B/S/T thread.
    RobP62 likes this.
  6. Mar 27, 2018 at 8:06 AM
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Used to visit there too. Nothing like wall-to-wall Kenworths and the smell of that bean-pulp paper plant.
    2ayne[QUOTED] likes this.
  7. Mar 27, 2018 at 8:22 AM
    Keith_Stone
    Keith_Stone INFERNO-COMA OWNER
    IG: @KCUN_11
    CINCINNATI, OHIO
    2016 INFERNO-COMA 4X4 SPORT
    WHERE'D YOU GET THE VINYLS FOR YOUR STOCK WHEELS?
  8. Mar 27, 2018 at 8:27 AM
    Keith_Stone
    IG: @KCUN_11
    CINCINNATI, OHIO
    WHERE DO I PURCHASE? ID LIKE TO RID THE CHROME FROM THE INTERIOR LIKE THIS RATHER THAN BLACKING IT OUT. LOOKS GOOD. NICE JOB MAN.
  9. Mar 27, 2018 at 8:31 AM
    JRH_Tacoma
    JRH_Tacoma Well-Known Member
    Charlotte, NC
    2017 BBP Tacoma TRD Sport 4x4
  10. Mar 27, 2018 at 8:41 AM
    Keith_Stone
    IG: @KCUN_11
    CINCINNATI, OHIO
    WHERE DO WE GET THOSE GETS ? ARE THERE OTHER OPTIONS ? I LIKE IT. GOOD JOB .
  11. Mar 27, 2018 at 8:43 AM
    SpeySquatch
    2016 TRD OR DCSB
    Thanks good to know. Also, isn't the T-case only really enabled using the oil when in 4WD? Can this change gas mileage?
  12. Mar 27, 2018 at 8:54 AM
    Mugsy7
    Mugsy7 Well-Known Member
    Mugsy
    Delco, PA
    2021 Cement TRD OR DCSB
    Truxedo Pro X15 tonneau, front tinted windows
    Proof that every Taco is built with love.
  13. Mar 27, 2018 at 9:09 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Tcase is always spinning. There’s no bypass to the rear driveshaft. It's engine -> transmission -> transfer case (the center differential - it's a "transfer case" because it has a low range gear set) -> driveshaft -> axle(s).
    Synthetic gear fluids can slightly increase gas mileage especially in rear diff, but it will probably be unmeasurable just in the Tcase. It says trans fluid, you can use it in your Tcase, it’s GL4 too which is what you want. Keep 75W90 GL5 that has more sulphur and phosphorous in your diffs, there’s no soft metals in your diffs.
    Also, I just found that Redline makes GL4 75W80 which is almost straight 75W, so this would work perfect in your Tcase.
    https://www.summitracing.com/parts/...MI9MiT--2M2gIVCEwNCh0TTwXMEAQYASABEgLdb_D_BwE
  14. Mar 27, 2018 at 9:10 AM
    SpeySquatch
    2016 TRD OR DCSB
    Is GL-4 ok for T-case, I thought it had to be GL-5. I have an Auto tranny
  15. Mar 27, 2018 at 9:20 AM
    Grossomotto
    2017 4WDV6LB6MT
    The Tcase is after the transmission on both manuals and auto. From everything I’ve read, Toyota changed the spec in 2015 to GL4, a lot of people are using 75W90 GL5 in both diffs and Tcase, which is perfectly fine. But long term like 100k+ miles I’m not so certain for your Tcase.
    You have an auto trans so definitely use ATF. Do not use MTL or any other gear oils in your auto trans.
    SpeySquatch[QUOTED] likes this.
  16. Mar 27, 2018 at 9:25 AM
    SpeySquatch
    2016 TRD OR DCSB
    OK cool, i change every 15k-30k anyways
  17. Mar 27, 2018 at 9:28 AM
    Grossomotto
    2017 4WDV6LB6MT
    That’s good maintenance might be excessive, but perfectly fine if you’re doing it yourself, it’s just the cost of the fluid.
    I’ve always changed gear fluids including tranny at 60k intervals using synthetics since it’s fairly expensive fluid.
  18. Mar 27, 2018 at 9:29 AM
    Argo98
    Argo98 Well-Known Member
    Argo
    2017 Toyota Tacoma TRD-Sport 4x4
    Rough Country 3" spacer lift w/ shocks 285 KO2's wrapped around 16' ProComp Series 7069 Misc. bibbidybob lights
    I'm not really sure what your referring to... But if its a real SwitchPro 9100 for $425 then yes, that a steal... (I haven't had my coffee yet)
  19. Mar 27, 2018 at 9:35 AM
    SpeySquatch
    2016 TRD OR DCSB
    I am going to do some measuring of MPGs with the Mobile-1 75w-90 I put in the rear diff and compare it to the old mpgs with stock fluid.If it still sucks I am going to switch out the mobile-1 for this Redline stuff:
    https://www.amazon.com/gp/product/B000J3G8KE/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
  20. Mar 27, 2018 at 9:35 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Just dropped the truck off to have the 4.88's put in. Can't wait to drive it
    honey, ToyoDrew, ibanez314 and 21 others like this.
