  1. Sep 21, 2018 at 2:32 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Well when you're overloading i think on the swing-out vertical would be good. Easy access when/if needed without unloading a bunch of stuff.
  2. Sep 21, 2018 at 2:55 PM
    My Name is Rahl
    Got MY fob from AJT Designs today. Today was also the day I got my 10k service done and had the 0058-18 flashed. My stealership did it with no questions asked. I think it helped that I had the paperwork AND spoke with the Service Manager about it.
  3. Sep 21, 2018 at 3:04 PM
    El Latigo
    El Latigo Well-Known Member
    Anaheim CA
    2017 MGM TRD OR Double Cab Short Bed
    Can you post more pictures.. I am interested as well
    thank you,
  4. Sep 21, 2018 at 3:10 PM
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    Whatever is going to get you to that 7ft height of clearance in cities and drivethrus
  5. Sep 21, 2018 at 3:12 PM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    New custom bed decals, courtesy of @CBoy808:
  6. Sep 21, 2018 at 3:31 PM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    Lol I already can't fit with the tent and antennas
    Gotta walk through the drive thrus
  7. Sep 21, 2018 at 3:41 PM
    solscooter
    Brian
    Minnesota
    Now you got me worried about a rtt. Crap! Got a quick disconnect on the antenna
  8. Sep 21, 2018 at 3:55 PM
    Rodchester
    Rodchester Well-Known Member
    Baton Rouge
    2017 Quicksand SR5 DCSB V6
    Weather tech mats, LED interior lights and reverse lights, tube steps, bed extender, bed mat, folding bed cover, TRD Pro grill, blacked out badges and wheel center caps. Kicker speakers(all 6). Front bed rail header. Under hood LEDs. Tufskinz door and interior foam inserts. Chrome interior door handles. Fumoto drain valve. Aluminum oil filter canister. Rear view mirror with Homelink. Quick charge USB charging ports. TRD badge on grill. MESO fuse box cover. Redline Tuning hood struts. Ceramic coating. Pop & Lock auto tailgate lock. LED bed lights. Lower bumper LED light that bar. MESO coin holder. TRD cat back exhaust. Hikari Ultra LEDs high and low beams. 2020 TRD Sport wheels and TRD center caps. RSC Nano dashcam. DSM from the Taco Garage. Blue Sea dual USB outlet on back of center console. KDMax7.0
    Not a junkyard within 100 miles of me had a 2nd gen. Had to order one through the stealership for $45.
    Wicker24[QUOTED] likes this.
  9. Sep 21, 2018 at 3:55 PM
    Bulldogs129
    Bulldogs129 Don't find fault, find a remedy
    Malcolm
    Mississippi
    2018 TRD, OR, 4wd, Dblcab, 3.5l, & 2002 Tacoma 4wd, SR5, TRD, 3.4L, auto
    Which size square tubing? & length of the 1/4” grade 8 bolts
    Thanks
  10. Sep 21, 2018 at 3:58 PM
    Wicker24
    Wicker24 Well-Known Member
    2018 TRD Off Road
    Damn. Mine has stacks of them, mostly in bad accidents with a ton of beer cans in the bed...
  11. Sep 21, 2018 at 4:10 PM
    MK212MX
    MK212MX Well-Known Member
    2022 Tacoma TRD Sport
    Installed a brake controller, thanks for the tips from the towing bible!
  12. Sep 21, 2018 at 4:13 PM
    Wsteven
    Wsteven Well-Known Member
    2018 Tacoma TRD Pro
    Working on them
    Yes that I can Understand, I spend 5 days a week 10 plus hours a day working designs and modifying them that many times involve high risk to people if not properly researched and applied correctly around industrial equipment you learn to question and inspect everything multiple times, I have seen welds with bubbles in them or just looked more like they were not penetrated right on steel staircases that would be 3 to 4 floors up (small platform at each floor level) that had to be rejected and resulted in entire structure being torn down and built again <---- and oh man that pissed people off but technically this location is earth quake prone zone so the degree of standards are really watched out for. and one thing people miss is when bolting things together is they will say "Oh grade 8 that will be good" that is not always true a grade 8 bolt side shear can be lower than a properly installed grade 6 bolt!
    NMTrailRider likes this.
  13. Sep 21, 2018 at 4:36 PM
    KYMTBer
    KYMTBer Member
    Bob
    2016 Magnetic Gray Tacoma TRD Sport
    good point, I too assume just because it's grade 8 it should be the strongest. but like you said, its the shear strength in this application that's important, not the pull strength.
  14. Sep 21, 2018 at 4:39 PM
    KYMTBer
    KYMTBer Member
    Bob
    It's one inch square and the bolts are 2 1/2 inches I think. Two inches would work better though. Or just cut off the excess.
    Bulldogs129[QUOTED] likes this.
  15. Sep 21, 2018 at 4:46 PM
    Tora
    Tora Well-Known Member
    Jamie
    Vancouver, BC
    2018 TRD Off-road
    Smittybilt seat cover, black tailgate insert, Bakflip and rear Weathertech window visors (Amazon sent the wrong fronts). My first few mods.
    703D82C4-1576-41F6-BA62-301B07CC7118.jpg F57A5125-6608-4995-9AC7-05E7826535D4.jpg
  16. Sep 21, 2018 at 6:10 PM
    Teton Tacoma
    Teton Tacoma Well-Known Member
    Wydaho
    2016 Off Road M/T
    20180921_153906.jpg got OME lift finished. Washed it.
    JDSmith, SilverII, Jmac2408 and 16 others like this.
  17. Sep 21, 2018 at 6:20 PM
    RockyTop_Tacoma
    RockyTop_Tacoma Well-Known Member
    Drew
    Tennessee
    2016 TRD Off Road
    King 2.5 Suspension with Reservoirs Dakar Leaf Springs ARE Z Series Shell Method Grid 16x8 Wheels TRD PRO Grill 285/75r16 BFG KO2 Tires WeatherTech Floor Mats Pelfreybilt Aluminum Skid Plates Pelfreybilt Sliders with top plate Front Runner Cab Rack Front Runner Canopy Rack Timbren Active Off Road Bumpstops Timbren Ubolt Flip Dakar Add A Leaf CVT Mt. Rainier Pioneer Extended CVT Summit Series Awning
    My wife and I went to CVT Chattanooga and picked up our new Mt Rainier Extended Pioneer to go with the Summit Awning. Hopefully gonna put it to use soon.
    SilverII, Greg767, Jmac2408 and 20 others like this.
  18. Sep 21, 2018 at 6:49 PM
    RunawayCow2
    RunawayCow2 Well-Known Member
    Las Vegas
    2018 Sport DCLB 4x4 White
    Finally finished putting vinyl on the wheels and took it to the mall to flex
  19. Sep 21, 2018 at 6:51 PM
    RJwildcat
    RJwildcat Well-Known Member
    RJ
    2021 and 2025 Tacoma Off Road DCLB 4WD
    Installed some 4x4 and TRD black emblems in the tailgate. Removed the V6 emblem but I am thinking of painting it black and putting it back on but in the lower right side corner of the tailgate. Will post pictures if I put it back on.
  20. Sep 21, 2018 at 6:54 PM
    Inferno75
    Inferno75 Well-Known Member
    Massachusetts
    2016 Trd sport double cab (premium and tech)
    K&n intake, full led replacement, interior custom orange carbon fiber kit, led roof bar...ditch pods...lower grill bar, meso add ons, custom raptor lights, bpf trd skid plate, trd shift knob, shift sense pro, redline triple reverse/brake/running lights strip on rear, custom switches, Tyger armor step sides, in Channel vent visors, strike plate covers, hood vinyl, custom American flag trailer hitch cover, graphite door sill vinyls, custom Tacoma dash insert(not vinyl), trd seat belt pads
    Detailed in and out and then used her as a truck.9D7D943E-1464-4EB2-AE64-9104EB16B6AB.jpg
