  1. May 18, 2019 at 10:32 PM
    Gunner123
    Gunner123 Well-Known Member
    2018 TRD OR
    Thought some of you may enjoy this video.
  2. May 18, 2019 at 10:40 PM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    met up with @N2DesignsInc to test out his remote starter for my 6MT.
    Had to do a few fancy shots
  3. May 19, 2019 at 5:16 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I have had my seat defenders for 3 years now. Works for me too! :thumbsup:
    rgljr831 likes this.
  4. May 19, 2019 at 5:42 AM
    SUZETACO
    SUZETACO Member
    F5’s are on.
    HoboInNV, Atl_taco_, r6chan and 11 others like this.
  5. May 19, 2019 at 7:08 AM
    AustinMada
    AustinMada Thinking About Tacos
    WA.
    19 DCSB OR
  6. May 19, 2019 at 7:09 AM
    SUZETACO
    SUZETACO Member
    Dip or paint?
    StayinStock and rgljr831 like this.
  7. May 19, 2019 at 7:09 AM
    AustinMada
    WA.
    19 DCSB OR
  8. May 19, 2019 at 7:22 AM
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    Literally never heard of that kind. I was thinking if I glue in a piece of vinyl then I can stick the stickers to that
    CXYyuppie and rgljr831 like this.
  9. May 19, 2019 at 7:50 AM
    COS_TACO
    COS_TACO Well-Known Member
    Colorado
    2018 SR5 ACLB V6 4x4
    https://www.clazzio.com/
    Research the threads here for more info, plenty of discussion around. Sometimes they have your kit in standard colors in stock (which was my case). So I got lucky and ordered Monday and had them Thursday. For popular kits or custom kits, some folks wait anywhere from a few weeks to a few months. Just depends. They have great customer service, call them up with any questions.
    During install, just take your time and have a beer while you're doing it.
    For the seat bottom, the hardest part is tying off the white string under the seat (without removing the seat from the truck, which I wanted to avoid). There are two black straps with buckles that run front/rear to help hold the bottom piece snug. These are easy to tighten by reaching underneath. The white string you cinch and secure underneath which runs perpendicular to the black straps - I wish they'd find a way to use the same buckle for that -- it would be WAY easier to tighten and secure. Like I said if you remove the seat you can tie it off very easily, but with the seat installed its tricky to get under there with hands to properly and tightly tie off the knot.They include a dull plastic "knife" to help you push and tuck the cover into and behind some of the seats plastic.
    The seat back wasn't too bad either. The booklet tells you (and I think it helps a little) to turn the cover inside-out about half way and slide it on this way first, and work it onto the top of the seat as far and as snug as you can. THEN, you kind of unroll the rest down over the lower portion of the seat. It would be much harder if you just take the fully unfolded cover and try to work it down over the seat in one shot, you'd be doing a lot of scrunching.
    The headrest covers were probably the trickiest, although you wouldn't think so. Mostly because they are such a glove tight fit, so it takes effort to work them on. They point out in the booklet to be careful not to pull hard on a specific section on the cover, due to chance of ripping it -- heed this advice! I slightly put a small tear in the one corner (you cant see it when install is done) when pulling too hard on a specific portion of the cover without being too careful. So, be careful! My tip for the headrest covers is to first start to slide the cover on the top, and make sure it is straight (later on, if its rotated left or right a little, it is much harder to straighten so that the stitching looks). Then work it down a little at a time, alternating left side then right side. As you work each side, pinch and compress the headrest itself real hard, then slip the cover down a little. Alternate sides and eventually it'll go on. I started with the headrest still installed, until the cover was about 85-90% on, then I popped it off and pulled it the rest of the away on and this seemed a little easier.
    Oh yea, dont forget to take sips of the aforementioned beer during the whole process. ;)
  10. May 19, 2019 at 8:05 AM
    Cappy
    Cappy Well-Known Member
    Georgia
    Do you know of a list of these service roads in our area that are open to the public? Don't do any extreme off road driving but would enjoy some of these and may be able to convince the wife to go as well.
  11. May 19, 2019 at 8:09 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    I washed the key fob by accident. I hope it still works
  12. May 19, 2019 at 8:34 AM
    johnnyroid
    johnnyroid Well-Known Member
    Vine Grove (Fort Knox) Kentucky
    2017 Black Tacoma Sport TRD
    Looks like you need to push that right one a little further in a the top, looks misaligned. Just trying to look out....Bright AF....
    Castle 4[QUOTED] and rgljr831 like this.
  13. May 19, 2019 at 8:43 AM
    johnnyroid
    Never heard wonderful and IL in the same sentence. You must have a hell of a spot!
  14. May 19, 2019 at 8:47 AM
    Tallgrass05
    Tallgrass05 Well-Known Member
    I did the Kicker speaker upgrade in the dash, it was definitely worth the 80ish bucks. Definitely a clearer sound. But after I put the driver side pillar cover back on, I noticed a bit of felt cushioning on the floor, it must have come out of the pillar cover. I took pillar off again but can't figure out where this little cushion goes. Anyone have an idea?
    BlasterJoe, Dammit Evie and rgljr831 like this.
  15. May 19, 2019 at 8:52 AM
    jasperkat
    jasperkat Business cat
    2021 Cement TRD Offroad DCSB
    That looks like the felt in the door handle pocket
  16. May 19, 2019 at 8:54 AM
    Tallgrass05
    You nailed it, thank you mucho. Now I won't obsess over not getting things back correctly.
  17. May 19, 2019 at 8:55 AM
    Onemorodeo
    Onemorodeo Well-Known Member
    OC SoCal
    ‘18 dclb TRD Sport 4wd Cement
    I'm with @jasperkat looks like the door handle felt.
    rgljr831 and RivetNutBob like this.
  18. May 19, 2019 at 9:18 AM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    After 10 years of PCS's, deployments to shit holes, etc. IL which is my home, sounds wonderful. Lol.
  19. May 19, 2019 at 9:41 AM
    Castle 4
    Castle 4 Well-Known Member
    Dan
    Richmond, VA
    2018 TRD Sport DCSB
    Bilstein 6112 / 5160, Icon RXT Stage 3, JBA UCAs, SmartCap Evo Sport, Falken Wildpeaks 275/70R17s; TRD Pro wheels
    Thank you! I had noticed it... I had a wire caught on the one side. Pulled, reinstalled, and good to go.
    MAS, rgljr831 and johnnyroid[QUOTED] like this.
  20. May 19, 2019 at 9:47 AM
    Jessrin
    Jessrin Oh, okay...
    Jesse
    Upper Michigan
    24 Tacoma Double Cab TRD Off Road 4X4
    Stock
    The white was my first choice for the Tacoma. But, I ended up with the black because it was the one on the lot with the options I wanted. Now, putting on an awesome hood vinyl like you did. Little out of ideas. Thought of doing it in magnetic gray metallic.
