  1. Jun 17, 2019 at 3:15 AM
    Watkinseli91
    Watkinseli91 Well-Known Member
    Eli
    Greenville, SC
    2021 LR PRO
    I have the exact same truck but in a MT. I love it, but have been debating which running boards to get. Those oem ones look good on yours!
  2. Jun 17, 2019 at 4:44 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I can see that.
  3. Jun 17, 2019 at 6:39 AM
    a_hol
    a_hol Well-Known Member
    Long Beach, CA
    2016 TRD Sport DCLB
    Where’d you get the center console cover?
    rgljr831 likes this.
  4. Jun 17, 2019 at 7:01 AM
    CaliRaisedLed
    CaliRaisedLed Well-Known Member Vendor
    Jake
    Texas (DFW)
    Thanks for choosing us! :thumbsup:
    Deathdealer and rgljr831 like this.
  5. Jun 17, 2019 at 7:49 AM
    Bigc2029
    Bigc2029 Well-Known Member
    Caleb
    2019 Midnight Black TRD Off Road 4x4
    RC 2' Level kit, TRD Pro Wheels, Bumper ends.
    I do not man i'm sorry. They were incredibly easy to find though.
  6. Jun 17, 2019 at 8:21 AM
    RetiredRedneck
    RetiredRedneck Well-Known Member
    Bruce
    Port Moody, BC
    2018 TRD Off-Road - The Grey Ghost
    Toyota Roof Rails/Rack Toyota front Skid Plate BAKflip Hard Tonneau Cover iBoard Running Boards AVS Hood bug/rock deflector AVS Window Rain Gutters Amazon Centre Console Tray Larsen 2m/70cm antenna QYT VHF/UHF Mobile Radio Auxting LED Reverse Lights Taco Garage DMM with RAM bits-n-pieces Toyota OEM Bed Mat Interior LED Light upgrade - SuperBrightLEDS.com Pop-n-Lock OG Fabrication Centre Console Molle Panels Decals and badges removed CaliRaisedLED Amber Fogs, Ditch Lights and bumper Light Bar MESO Switch Panels AirOnBoard Switches Home Brew Auxiliary Electrics Panel
    Still very much an ongoing effort, but I've finally gotten a chunk of the wiring out of the way. The goal was to do all of the onerous/less visible stuff so whenever I got my new lights and so on, things could be just plugged in.
    That little cubbyhole under the dash was of no use to me as it was....I figured it would ultimately become a sanctuary for every bit of hamburger and potato chip that I ever dropped, and eventually I would have to deal with the civilisation that would no doubt spawn there, likely about the time they discovered space flight, ergo the crafted panel. I stopped at the 12 volt plug and the USD sockets; if I am ever in need of additional switches or plugs and an am run down, tackled and pummelled to the ground by an unreasonable bout of ambition, I can add more....I know that the little CaliRaised three switch plate will fit perfectly in the remaining space. Drilling a hole to run wires has to be done carefully; I'm pretty sure that drilling into the bright yellow painted wire harness behind the cubby would be really bad.
    I mucked with the existing wiring only a bit...I ran a heavy fuzed lead from my auxiliary panel, and ran it through a relay powered off the factory 12 volt plug...that gives me as much amperage as I will ever need. I added a identical plugs in the rear of the centre console for those rare times when i have a teenager or two in the back seat, also powered off the same heavy lead. I tucked a third up under the dash, as well as the original factory plug, for anything I want to be 'hard' wired without actually having to play around with those tiny little wires. I've got a new tablet and RAM mount coming for off road navigation. I didn't need the voltmeter, but that particular plug was the only high amp USB available at the time and, besides, all that blue glow looks cool.
    Waiting on a replacement sticker for the Redarc control head, the one that is there is driving me daft. The Redarc brake controller was a little pricey, but worth every penny. If you fail to attach one of the connectors on the plug correctly, and then go through the OEM fuze panel to make sure that 'pop' sound was not fatal, make sure you replace all of the fuzes correctly. There is one little tiny 25 amp beast that powers all of your trailer lights....after you test it, if you put it back in the wrong spot, nothing works. And you panic.
    The molle panels for the console may not be for everyone, but they certainly work for me. Most impressed with Hector's efforts (OG Fabrications)
    After the better part of four decades listening to a disembodied voice under my dash send me places I really didn't want to go to deal with people I knew I wouldn't like, I haven't re-embraced Ham radio as much as I had hoped. Should I ever shed my grumpy, anti-social demeanour, I will upgrade the radio...for now, the little QYT will serve. I use it rarely, mostly off-road on simplex, and it serves adequately. When I have a need to hear unhappy voices, I'm good with Johnny Cash or Waylon or Colter Wall. A thumb drive into that little USB port is certainly an improvement over the 8 track player I had the last time I owned a pick up.
    As I was installing MESO's centre switch panel, I briefly hated him (when you think you have maybe cut too much dash away, do NOT call your local Stealership and ask how much a replacement centre console would cost...you won't like the answer. At. All), but with way more JB Weld than is probably recommended, I made up for my gross inadequacies with a Dremel. I gotta say, I am truly impressed with the switch panel; now waiting for a few more MESO creations to come available. The switches all came from Air-On-Board; the lamp colour in the small centre console switches is an exact match for the Toyota OEM, while the larger switches on the left are...close. But, back to my earlier comment about the soothing blue glow....
    The auxiliary electrics panel is a home brew effort with components from Bussmann, Blue Sea, Princess Auto, someone-anonymous-overseas-on-ebay and my local under-the-table metal shop. It is very much overkill for my current needs, but the last thing I want to be doing is adding extraneous bits n pieces down the road. I have it on good authority that MESO and OG Fabrications and others are working on a deflector screen and ant-gravity generator for the 3rd Gen (I watch Star Trek and The Orville, too!) and I want to be ready when these come available. Building this thing was a RRPITA* and not unlike the current landscape project in my backyard - or going to prison - I've deemed this a once in a lifetime experience.
    *We all know what PITA means. RRPITA is a couple orders of magnitude above that; RPITA is a "Right" Pain - - - . Not sure what the opposite of that would be...Left? Wrong? Who knows, it is a British Empire expression, meant to confuse the Colonials. RRPITA is "Right, Royal Pain - - -. I suspect that has something to do with one of Her Majesty's centuries dead ancestor's less desirable proclivities, but as I was cutting bits of plastic that should never have there in the first place, poking myself in the eye with a hot soldering iron and fumbling around with stupid little connectors, RRPITA seemed to be appropriate.
    And its pronounced like a Pirate would say it. A Pirate ordering bread in a Mediterranean restaurant.
  7. Jun 17, 2019 at 9:07 AM
    Silverbullet2017
    Silverbullet2017 Member
    Dan
    2017 Tacoma TRD sport
    Thanks man, I always liked the look of the 2nd generation running boards better than ours and they were a lot cheaper. Win+Win!
  8. Jun 17, 2019 at 9:21 AM
    DoggMan1163
    DoggMan1163 DoggMan1163
    Robert
    2020 Taco TRD off road
    :angrygirl::annoyed::argue:
  9. Jun 17, 2019 at 9:22 AM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    For the rattle?
  10. Jun 17, 2019 at 9:40 AM
    MyTacoma03
    MyTacoma03 MeMoZ-TRD-TakoMa
    Art
    San Antonio
    2017 Tacoma Trd DCSB Sport
    Fabtech 3" Uniball System w/Front Dirt Logic Adjustable 2.5 Coilovers & Rear Dirt Logic 2.25 Resi-Shocks. 285/70/17 Nitto Ridge Grappler Load C wrapped on 17x8.5 Jet Black SCS Ray 10's....
  11. Jun 17, 2019 at 9:45 AM
    5IR3MAN
    5IR3MAN Member
    18MGMDCLB
    Hey man I'm really interested in finding the high viz yellow for the DRL! Where'd ya get em!?
    wayyfarer1 and rgljr831 like this.
  12. Jun 17, 2019 at 9:48 AM
    CoastieRon
    CoastieRon Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
    yep.
    RangerComa[QUOTED] and rgljr831 like this.
  13. Jun 17, 2019 at 10:40 AM
    Comato$e
    Comato$e Well-Known Member
    Joshua
    Chicago,Il
    18' MGM OR DCSB
    Removed predators this morning .... now to find sliders.
    JediDad, shwokee, MAS and 10 others like this.
  14. Jun 17, 2019 at 10:49 AM
    SPYA
    SPYA Member
    19' Off Road Long bed 4x4
    None yet, but I'm hoping I can get some advice. It will be my daily driver, but also want it to be a capable over lander. Need help on which steps to do first, and how to do it in order that makes the most sense.
    Wow, that's a sweet Tacoma!!!
    I'm looking to try and replicate this.
    What lift did you use?
    Tire size?
    Awesome truck.
  15. Jun 17, 2019 at 10:54 AM
    IluvTaco
    IluvTaco Well-Known Member
    NorCal
    2020 DCLB OR
    Yeah, great looking truck. I’m curious what you did too
  16. Jun 17, 2019 at 10:54 AM
    Comato$e
    Joshua
    Chicago,Il
    18' MGM OR DCSB
    Fox suspension
    Ray10 17x9
    Nitto Ridge Grappler 295/70/17
    SPYA[QUOTED] likes this.
  17. Jun 17, 2019 at 10:55 AM
    Big_Country68
    Big_Country68 Active Member
    Clearwater Florida
    2017 DCSB SW TRD PRO
    [/QUOTE]
    Nice install. Looking to do something similar. How did you route the wiring for the accessories into the Qi opening?
    Cheers,
    B_C
  18. Jun 17, 2019 at 11:01 AM
    OregonTacomaMan
    OregonTacomaMan Active Member
    PNW
    2023 Tacoma TRD Off-Road
    How much lift did you get in the front with the 887s? I have heard that there is a difference between the newer and older 887s and 888s. Thanks
  19. Jun 17, 2019 at 11:17 AM
    mcharfauros
    mcharfauros IG: mcharfauros
    MO
    2017 Black TRD OR DC
    Dumb Truck Thangs
    Nice. You in CO, lucky you, a bunch of Fabrication Companies in your area to chose from.
  20. Jun 17, 2019 at 11:18 AM
    beergeek
    beergeek Well-Known Member
    RI
    2017 Black Tacoma Limited
    Perhaps the lowest bang-for-the-buck mod I’ve done:
    CE07B3AA-5EDB-4A2B-B0D0-672D51CE3022.jpg 8E972D3B-016C-49E8-B3A6-68AB66C82AEA.jpg
    (This is what happens after you have a few beers, then get on TW late at night.)
    shwokee, DeputyDawg245, MAS and 8 others like this.
