  1. Apr 4, 2016 at 10:12 AM
    bpl81
    bpl81 Member
    Brent
    2016 Quick Sand TRD Off Road AC
    Anyone know if these are the same for the access cab?
  2. Apr 4, 2016 at 10:26 AM
    BunkKryptonite
    BunkKryptonite Member
    Another lessened learned by me is to not push too hard. I tried too hard to get the pointed ends into the brackets perfectly and ended up pushing too hard and broke one of the ends. Replacing this bulb alone was half the cost of the full package.
  3. Apr 4, 2016 at 10:40 AM
    easbaysav
    easbaysav Well-Known Member
    Eddie
    Central Valley, CA
    2019 TRD Off Road AC Cement
    As another member stated, use some split loom tubing.
    I picked up some 1/4" split loom from Pep Boys when I did my install. Might not be necessary, but I did it anyway. I covered the harness from beneath the tailgate all the way up to the firewall in the engine bay. I ran it alongside the OEM wire loom and zip tied it to the plastic brackets the OEM loom was taped to. The part where the loom was covered with the heat shield, I zip tied the P&L harness behind it and ran it above the frame to avoid it being exposed to heat.
    opentang[QUOTED] likes this.
  4. Apr 4, 2016 at 10:40 AM
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    Howdy and welcome to the forum. Are you laying the first deck down on the second deck before trying to release the second deck?
  5. Apr 4, 2016 at 10:44 AM
    Z-MAN
    Z-MAN Well-Known Member
    2016 TRD Off Road 4X4
    BFG KO2 265/75/16 Bilstein 5100 Shocks Katzkin Leather
    Yes was talking about these map/dome bulbs. After taking the cover off I just cant seem to get the tiny bulbs out. Nothing to grab and pull except the tiny glass bulb. I didn't want to break the bulb and have to take the whole assembly apart. Thanks for the help!
  6. Apr 4, 2016 at 10:45 AM
    HARLEY410
    HARLEY410 Active Member
    Darren
    How the F did you get 24.5 ave? do you have to go into a new trip and reset it to get a new ave?
  7. Apr 4, 2016 at 10:45 AM
    BunkKryptonite
  8. Apr 4, 2016 at 10:45 AM
    hastingsrussell
    hastingsrussell Well-Known Member
    Russell
    Allen, TX.
    2016 Tacoma TRD Sport
    Pretty stock for now
    All you have to do is grab that entire plastic housing and pull it down, it will just pop out then you can replace the bulbs from the top instead of the bottom.
    Man of Steel TRD and Cam308 like this.
  9. Apr 4, 2016 at 10:48 AM
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    That's the trip mpg, left work, drove to customer. It actually hit 25 but went back down to 24.5
  10. Apr 4, 2016 at 10:49 AM
    keone
    keone Active Member
    2016 Tacoma Limited
    I used tweezers to get it out, put a piece of paper towel to increase grip, came out easily.
    Z-MAN[QUOTED] likes this.
  11. Apr 4, 2016 at 10:50 AM
    HARLEY410
    Darren
    Ok. I must try that. I always been in just the Odometer page, Thanks for the quick response and on the way home Im trying this out. lol
  12. Apr 4, 2016 at 10:50 AM
    laggz
    laggz Well-Known Member
    2016 Tacoma TRD Sport 4x4
    I'd suggest Truxedo Truxport. I love it.
    smugly likes this.
  13. Apr 4, 2016 at 10:52 AM
    KnoxTaco44
    KnoxTaco44 Member
    Josh
    Knoxville, TN
    16 DCSB TRD Sport BBP
    IMCO Dual Exhaust, K&N Drop-In, Front tint to match the back
    My 5000 mile maintenance reminder popped up the other day and since then I've noticed some issues with my screen. The radio is still playing, but the screen will be black. If I turn the volume up then the volume bar will slide down from the top like normal. I have to tap home before anything else will show up. I've also had half of the home screen go black but the other half still show up.
  14. Apr 4, 2016 at 10:53 AM
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    Rubber tipped tweezers
  15. Apr 4, 2016 at 10:55 AM
    whopper
    wayne
    north carolina
    On going
    It can be done didn't get over 55mph used cruse and flat ground_20160309_134136.jpg
    iancaz and HARLEY410[QUOTED] like this.
  16. Apr 4, 2016 at 10:58 AM
    smugly
    Doug
    that doesn't sound good
    iancaz likes this.
  17. Apr 4, 2016 at 11:03 AM
    Cam308
    Cam308 Well-Known Member
    2016 Tacoma TRD Sport 4x2
    This is definitely the way to go with the map lights. Super easy, the whole console pulls out easily for access to the bulbs, pops right back in.
    Z-MAN likes this.
  18. Apr 4, 2016 at 11:14 AM
    MrSmithsTaco
    MrSmithsTaco Well-Known Member
    Oklahoma City, OK
    2016 Super White Tacoma TRD OR
    Me in the driver seat.
    ugh, that sucks. I was afraid of cracking the dome light cover. Which by the way, has a spider crack in it. Very hard to see but i have a very bright flashlight which illuminated the problem. I tried to take a picture but it doesn't show very well. I'm hoping that is covered in my Toyota Care stuff.
  19. Apr 4, 2016 at 11:17 AM
    MrSmithsTaco
    Oklahoma City, OK
    I guess there is no better time for that to happen than right before a trip to the dealership. I would just leave it alone so that way they can actually see the problem rather than it turning out to be one of those issues where you know it happens but the mechanics can't reproduce it "mysteriously".
  20. Apr 4, 2016 at 11:19 AM
    MrSmithsTaco
    Oklahoma City, OK
    I have no idea how any of you are doing these insane MPG numbers. I drive 4.1 miles to work every day, ginger throttle, no passing and only 3 stoplights/signs. The best I can get is 16.8!! What the french toast!?
    TacomaMike32 and whopper[QUOTED] like this.
