  1. Jan 1, 2020 at 4:54 PM
    WreckedRooster
    WreckedRooster Well-Known Member
    Jake
    Oklahoma
    2020 MGM DCSB
    MR E30, CXYyuppie, Dor and 4 others like this.
  2. Jan 1, 2020 at 4:58 PM
    Frsh2df
    Frsh2df Well-Known Member
    2017 MGM TRD Off Road 4x4
    Custom job. They are very time consuming to make.
    @20tacoma17 may be able to give you some pointers if you decide to tackle the job yourself.
    CANYONERO and 20tacoma17 like this.
  3. Jan 1, 2020 at 5:13 PM
    Superhulk LB
    Superhulk LB Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    I installed them a couple nights ago and feel like mine are super dim compared to the oem. Just changed the alignment on them. Hoping that helps.
    bcgill likes this.
  4. Jan 1, 2020 at 5:24 PM
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    I'm looking at this too and there's a kit someone sells just for the scoop. I'll see if I can find it later.
    CANYONERO likes this.
  5. Jan 1, 2020 at 5:29 PM
    ncosper
    ncosper Active Member
    Nick
    Flagstaff, AZ
    2017 Tacoma
    Check my this thread. Has more pics. The tweeters are 1 3/8” which are really big tweeters. I wanted plenty of volume without driving them too hard. I could adjust them to most any size though with some fairly simple tweaks. https://www.tacomaworld.com/posts/22358537/
  6. Jan 1, 2020 at 6:18 PM
    rdsaal
    rdsaal Well-Known Member
    2018 Black Tacoma SR5
    That looks great. One hint, I plasti-dipped the logo on my wheel hubs (blue for my LEO son). Videos I watched showed people using a toothpick to easily pick the unwanted Plasti-dip from the logo or lettering. I found this "T" logo is rounded and the toothpick wouldn't work. I used an exacto knife to trim around the "T" edges.
    Nito, Tullie D, CXYyuppie and 2 others like this.
  7. Jan 1, 2020 at 7:43 PM
    ARNIE R
    ARNIE R Well-Known Member
    Arnold
    Leesburg, VA
    2019 Tacoma White SR5 4D ShortBed
    Fender gravel guards; Side step bars; Bug shield; Vent shades; Body side door moldings; Door edge trim; Tonneau cover
    Added my Subaru tweeters today. The difference in sound is very obvious. Sounds more like it is sharper and cleaner sounding than before.
    MR E30, CANYONERO and 20tacoma17 like this.
  8. Jan 1, 2020 at 7:59 PM
    Surferzac
    Surferzac Well-Known Member
    Zac
    Moncks Corner, SC
    16 TRD OR
    Hard to see without a POV shot, pause, but they are a noticeable difference. I live on the edge of country living and maybe it's more of a difference without all the street lights
    Superhulk LB[QUOTED] likes this.
  9. Jan 1, 2020 at 8:43 PM
    18Tacos
    18Tacos Well-Known Member
    New Port Richey, Florida
    18’ Tacoma SR5 DCSB Silver Sky
    3” lift, 265/70/16 Wildpeak ATs on stock dipped SR5 wheels (for now). Meso stuff (puddle pods, Gasshole, stage 1 taillights) Pro grille, 5% tint, some other stuff
    that’s awesome. I had the same seat for my son until he outgrew it
  10. Jan 1, 2020 at 8:45 PM
    Outlwd
    Outlwd Member
    Rob
    2020 TRD Off-road
    Made the first personalized touches to my cement grey 2020 today. Not very grandeous but the bigger items will follow after I study up on this forum.
    Nito, Ol'gray mare, ARNIE R and 8 others like this.
  11. Jan 1, 2020 at 8:47 PM
    roadie
    roadie Well-Known Member
    Forest Falls, CA
    2017 SR5 4x4 DCSB
    I'm not a fan of ditch lights either, I use my roof lights as ditch lights.
  12. Jan 1, 2020 at 8:52 PM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    I pulled the entire grill and surrounding bezel out to change the grill and discovered there is a flat plastic part inside that helps direct the air into the rad so I used this air dam as a mounting surface. But in order to firm up the plastic I attached a steel bar on the underside of the plastic and then fastened the lights through the plastic and into the steel. Here is a pic of the type of steel I used. It is bar that you use for mounting shelving brackets on. I just cut it to length and fastened it to the plastic with about 6 small SS bolts.
  13. Jan 1, 2020 at 8:56 PM
    Superhulk LB
    Josh
    Oregon
    Nice use of those brackets.
    CXYyuppie likes this.
  14. Jan 1, 2020 at 9:14 PM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Did you put the older style tails on? Looks so much better. Nicely done.
    Tullie D and nathan298[QUOTED] like this.
  15. Jan 1, 2020 at 9:27 PM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    What wheels are those? I swear they seem to look a lot like my OE wheels, but CHROME.
    Rodchester likes this.
  16. Jan 1, 2020 at 9:30 PM
    nathan298
    nathan298 Well-Known Member
    Nathan
    Bristol, VA
    '21 Voodoo Blue Off-Road 6MT
    Thanks! Yeah, I found a brand new set someone took off a 2019 Sport for $50 on Facebook Marketplace. The 2020 lights look okay on some colors, but I didn't care for them with the blue. I'm also having the rear bumper painted blue this week to finish off the rear of the truck.
    TacoBuffet[QUOTED] and Tullie D like this.
  17. Jan 1, 2020 at 9:32 PM
    Tullie D
    Tullie
    Wilson, NC
    Welcome to the forum from Eastern North Carolina. Enjoy the new truck !
  18. Jan 1, 2020 at 9:33 PM
    Tullie D
    Tullie
    Wilson, NC
    PM sent.
  19. Jan 1, 2020 at 9:45 PM
    TacoTim85
    TacoTim85 Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    Bye bye chrome....
  20. Jan 1, 2020 at 9:45 PM
    Rodchester
    Rodchester Well-Known Member
    Baton Rouge
    2017 Quicksand SR5 DCSB V6
    Weather tech mats, LED interior lights and reverse lights, tube steps, bed extender, bed mat, folding bed cover, TRD Pro grill, blacked out badges and wheel center caps. Kicker speakers(all 6). Front bed rail header. Under hood LEDs. Tufskinz door and interior foam inserts. Chrome interior door handles. Fumoto drain valve. Aluminum oil filter canister. Rear view mirror with Homelink. Quick charge USB charging ports. TRD badge on grill. MESO fuse box cover. Redline Tuning hood struts. Ceramic coating. Pop & Lock auto tailgate lock. LED bed lights. Lower bumper LED light that bar. MESO coin holder. TRD cat back exhaust. Hikari Ultra LEDs high and low beams. 2020 TRD Sport wheels and TRD center caps. RSC Nano dashcam. DSM from the Taco Garage. Blue Sea dual USB outlet on back of center console. KDMax7.0
    If you look you could probably find someone near you that has a sport that would love to swap you for the black ones you have
    PapaRee likes this.
