  1. Jan 7, 2020 at 9:36 AM
    Jamesr913
    Jamesr913 Well-Known Member
    2019 Cement Tacoma offroad
    If I already removed the chrome cupholder trim would I have to pull the whole center console for the meso trim?
  2. Jan 7, 2020 at 9:57 AM
    LSUfan1975
    LSUfan1975 Well-Known Member
    Eric
    Washington NC
    2019 SR5 Dbcb MGM
    To each thier own. But does anyone else think the red cabin lights make it look like a brothel?
    Geaux Tigers
  3. Jan 7, 2020 at 10:05 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    It looks like hell. I get the reasons for some red illumination. But aesthetically as viewed from the outside isn't one of them IMHO.
  4. Jan 7, 2020 at 10:09 AM
    roadie
    roadie Well-Known Member
    Forest Falls, CA
    2017 SR5 4x4 DCSB
    Did some exploring in Joshua Tree, trimmed a bit more, still some slight rubbing in reverse with 33's installed. :thumbsup:
  5. Jan 7, 2020 at 10:17 AM
    norcalXninja
    norcalXninja Well-Known Member
    Evan
    2018 TRD Sport DCLB
    I am. I just found some pre drilled aluminum brackets at my station. I used the bolts that go through the cover into the bed rail. I got some 1” wood blocks to put behind the brackets to give a little more stability to it. Maybe not the cleanest but it’s stuff I had on hand
    Shveet[QUOTED] likes this.
  6. Jan 7, 2020 at 10:26 AM
    Mugs
    Mugs Well-Known Member
    Doug
    Pacific North-Wet
    2019 Tacoma TRD Off-Road
    Nitro Gear 5.29's, ARB locker, 3in OME Lift, ARB Leaf Springs, TRD Rims, Nitto Ridge Grapler 285/75/17, TRD skid Plate, CBI Rock Sliders, , ARB Compressor. Total Chaos bed stiffeners. Lots more to come.
    If you plan on doing bed stiffeners I would stay away from the bed extender install. Depending on the stiffener you get, you will have to drill in the same area as where the bed extender clips go. I know with my Chaos Fab full length stiffeners I had to drill a center hole though the middle of the extender clip holes. This did two things. A: It is now a weak point of where the center of the stiffener is. B: you will need to rust proof the old holes and seal them up so that no rain water, etc can get behind or through them. I noticed a week after doing mine that the hole that was still exposed from the extender clip was beginning to rust and now I have to go back in there and remedy the issue. I have also found that I never really use the extender so it has become a mute point. YMMV.
    Nito[QUOTED] and gtdad66 like this.
  7. Jan 7, 2020 at 10:27 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    I have mine mounted more or less the same way, though i'm using a flat bar of aluminum to extend downwards a bit, same as you - using what i happened to have on hand and there aint nothing wrong with that.
    The wooden block idea sounds useful, i might need to see if i can do something like it. Cheers!
  8. Jan 7, 2020 at 10:32 AM
    norcalXninja
    Evan
    2018 TRD Sport DCLB
    yea it was the best idea I could come with. I didn’t particularly feel like drilling into the bed and the weight of one of my other tools would probably bend the bracket so that was the best solution I could thank of.
  9. Jan 7, 2020 at 10:35 AM
    Box_of_Rocks
    Box_of_Rocks Well-Known Member
    Jordan
    Denton, Texas
    2017 Black Tacoma TRD OffRoad
    It looks like the inside of a submarine about to get hit with a depth charge. BATTLE STATIONS TACO CREW!
  10. Jan 7, 2020 at 10:39 AM
    Box_of_Rocks
    Jordan
    Denton, Texas
    Looks great! I have one too. Words of wisdom for ya. Do NOT slide anything across the top. It WILL scratch the top. Also be gentle unfolding it for the same reason. My top has some scratches and its just a nice silver color underneath that pretty matte black... its a great top tho! Keeps stuff dry.
    paspalarid1[QUOTED] likes this.
  11. Jan 7, 2020 at 11:06 AM
    B619
    B619 Well-Known Member
    2020 DCSB OR Premium VooDoo Blue Tacoma
    Installed my Meso gasshole today along with my stage 1s on 2019 tail lights/black housing. I’m getting hyper flash so I will contact Meso for a resistor.
    Maxcustody, Nito and TacoTim85 like this.
  12. Jan 7, 2020 at 11:27 AM
    freedivr2
    freedivr2 Active Member
    Myke
    Castle Rock, Colorado
    2002 Tacoma TRD Off road 4 x 4
    Mud flaps, paint protection, color cement, glove box compartment organizer, RCI engine skid plate, Snugtop Rebel topper, Bedrug
    so, need your help here......please.....mats look great, but when I go to their site the only Toyota mats they have are for a Toyota Sienna, no Tundra, no Tacoma listed as an option. Correct or ?????
  13. Jan 7, 2020 at 11:42 AM
    TacoTim85
    TacoTim85 Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    Every morning at work my in the parking lot my buddy says Red Light District to me.
    RivetNutBob likes this.
  14. Jan 7, 2020 at 11:53 AM
    wh11
    wh11 Well-Known Member
    2020 Cement OR
    Hey guys, what would be the steps towards touching up my rock sliders? I guess I'd need to sand down these rust areas and just re apply primer/paint? Should I just use sandpaper or get a wire brush? Or would a paint over rust option be better?
    Think I've learned my lesson, will be putting on my front mudguards when I go to snowy areas.
    Steveclark1579 and RivetNutBob like this.
  15. Jan 7, 2020 at 12:03 PM
    Hiebster
    Hiebster Well-Known Member
    Andrew
    Long Island, NY
    '19 TRD OFFROAD
    04EBFEDD-E52D-47D9-9B62-74A89FAA802C.jpg I’m not a big fan of the chrome rear bumper. Eventually I’d like to replace the bumper entirely. Until then, I purchased Bumpershellz from Ecoological. They fit right over the factory chrome bumper and change the look entirely. I purchased the Textured Black, in order to match the wheel well trim, for just around $100.
    rrt49, RivetNutBob, honey and 4 others like this.
  16. Jan 7, 2020 at 12:13 PM
    1992SR5V6
    1992SR5V6 Well-Known Member
    2018 TRD Sport 4x4 Cement
    Bolt on only...
    Nice setup! What do you think of the hitch hauler?
  17. Jan 7, 2020 at 12:26 PM
    hellfire0480
    hellfire0480 Well-Known Member
    Long Island
    2019 TRD OR Quicksand
    Eibach Pro lift, MR701, 285/70R17 AT3W, SOS Sliders, Sherpa RR
    On my last truck (RAM 1500) I had them in the foot wells on either side. It was subtle but it looked good. Always gone with cool white for the LED replacements up top. That much red light is too much for me but to each their own.
    I had to remove the geaux tigers from the quote....sorry
  18. Jan 7, 2020 at 12:31 PM
    FlywtrJoe
    FlywtrJoe A Secular Humanist Tacoma Owner
    Joe
    San Luis Obispo, Ca
    2018 TRD Pro Tacoma
    I installed the MESO red map lights with the MESO white dome light. When both are on the White tends to wash out the red 8n a good way. I use the red map lights to read or look for something at night to save my night vision. Good combination and as with all things MESO, great product.
  19. Jan 7, 2020 at 12:32 PM
    hellfire0480
    Long Island
    This seems like a good combination. Got any pics like the recent poster?
    TacoTim85 likes this.
  20. Jan 7, 2020 at 12:36 PM
    Recondite
    Recondite Well-Known Member
    NCWA
    2018 MGM DCLB TRD OR
    He lives in WA, it's a mobile grow shop
