  1. Jan 14, 2020 at 8:16 AM
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    MT I'd prolly go 4.88's Dig into it and ask a lot of questions that's what i did. did all my math to calculate my rpms at different speeds and what not. also, glad to hear you like the harrops, I can't wait to lock em up!
    Trim taco[QUOTED] likes this.
  2. Jan 14, 2020 at 8:33 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    You'll be OK. Sleep is over rated. :rofl::rofl::rofl:
    johnnyroid[QUOTED] likes this.
  3. Jan 14, 2020 at 8:35 AM
    ishootaround
    ishootaround Well-Known Member
    2020 SW Tacoma TRD Pro M/T
    That's awesome! They do amazing work, and Heather is so nice. I'm glad I picked a good spot! Will definitely be sending everyone here.
    corgimas and IMXPLRN[QUOTED] like this.
  4. Jan 14, 2020 at 9:24 AM
    glantzy
    glantzy Well-Known Member
    David
    2020 Cement Grey TRD Off Road Premium DCSB
    @jbroke2 They're not advertised on his page, but @rrentrop (TVD Vinyl) sells vinyl overlays for the grille emblem. Just text him the year, and they fit perfectly (not solid, but rather a chrome-delete.). I ordered mine in cement grey to match my truck, and am just waiting for warmer weather to place it. Will post pics when I do.
  5. Jan 14, 2020 at 9:52 AM
    Ezw0rkz
    Ezw0rkz Active Member
  6. Jan 14, 2020 at 10:11 AM
    SmileyGuy
    SmileyGuy Well-Known Member
    Darrin
    Nova Scotia
    20 Tacoma Off Road Voodoo Blue DC SB TRD Premium CAN
    When you do the install you want the adapter cable connector on the inside (dry side) with the door panel. You can feed the ends that connect to the speaker through the small hole in the mounting bracket. You dont want the adapter cable connector inside (wet side) where the window is. This also reduces the extra wire inside the door.
  7. Jan 14, 2020 at 10:50 AM
    norcalXninja
    norcalXninja Well-Known Member
    Evan
    2018 TRD Sport DCLB
    Added some tool mounts, and collapsible crates to keep my fuel cans from sliding around. All done for now unless anyone has any cool ideas
  8. Jan 14, 2020 at 10:51 AM
    norcalXninja
    Evan
    2018 TRD Sport DCLB
    Haven’t yet, ill shoot you a PM tho with a down and dirty
  9. Jan 14, 2020 at 11:09 AM
    Tullie D
    Tullie
    Wilson, NC
    I envision this being blindingly bright inside the cab of the truck. I recommend doing a temporary test hookup.
    shane100700 and SD_Taco like this.
  10. Jan 14, 2020 at 11:37 AM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    This is my solution for such a situation.
  11. Jan 14, 2020 at 12:53 PM
    Trah
    Trah Licensed Class C Driver...
    San Diego
    2017 Barcelona Red TRD Sport ACLB
    stuff and things...
    I put these in a few weeks ago and couldn't be happier...and they're 50% off now...
    https://www.vleds.com/closeout/led-bulbs/7443-6-hv-a.html
    Edit:
    Also these for the front side marker...because why not...
    https://www.vleds.com/shop-application/sidemarker-front/194/194-14-hva.html
    Jeff Dartfrog and CANYONERO like this.
  12. Jan 14, 2020 at 1:23 PM
    SD_Taco
    SD_Taco Well-Known Member
    San Diego
    2017 Sport DCLB
  13. Jan 14, 2020 at 1:25 PM
    Tullie D
    Tullie
    Wilson, NC
    The 7443 that you linked has the following warning:
    WARNING! This bulb is for use in parking and turn signal applications only. These should not be used in vehicles equipped with DRL systems that run on the high circuit. Using this bulb in a DRL application will void your warranty. For DRL applications we recommend our V6 Triton system.
    Almost every Amber 7443 LED seems to have a similar warning. :confused:
    shane100700 likes this.
  14. Jan 14, 2020 at 1:30 PM
    Trah
    San Diego
    stuff and things...
    No Hyperflash, but I have meso's side markers (built in resistor), and his stage 1 total tails (no resistor installed)
    yeah...it's for the turn signal...the DRL is a separate strip.
    Edit: I see you have a SR5 which uses the turn signal bulbs as DRLs. I would probably not use those bulbs then.
  15. Jan 14, 2020 at 1:36 PM
    Kevin8se7en
    Kevin8se7en Well-Known Member
    2017 Inferno OR
    I may add some sort of... Not sure what to call them.. blinders? Like in horse racing. Something to focus the light to ensure its it's not being in the cab.
    Tullie D[QUOTED] likes this.
  16. Jan 14, 2020 at 1:46 PM
    connerclan97
    connerclan97 Southern Xpeditions
    Steven
    South MS/Northeast TN
    2018 Black Tacoma TRD Off-Road 4x4 DCLB
    List of mods in build thread
    added some BD Squadron ditch lights and a Softopper. Going to change the lenses to clears, just haven’t ordered them yet. Rack for my tent/awnings will be added soon.
  17. Jan 14, 2020 at 1:53 PM
    LSUfan1975
    LSUfan1975 Well-Known Member
    Eric
    Washington NC
    2019 SR5 Dbcb MGM
    What does an engineer do when he questions the common belief to a question? He asks more engineers. Asked two more today at separate times about the bed weight question. Both had the same answer. Any weight applied to the bed behind thecenter of gravity and not large enough to overcome the moment of the engine weight forward will carry almost entirely on the back axle.
    The points made about the lever and fulcrum as well as the trailer are both correct. But you aren't comparing apples to apples in either of those scenarios. The lever fulcrum thought doesn't take into account the second fulcrum being the front axle. The front axle will always be the pivot point until the moment of the engine weight is overcome. The trailer thought is applying a weight greater then the sand at a moment greater than the sand at the tailgate. It also adds in several other variables like angular momentum one the load is moving that doesn't apply to the sand.
    Short answer is that it really doesn't matter where you put it theload is almost the same on the rear axle. Still going to go to the scales on my next weekday off to prove it. The ISTP in me has to have the facts. Lol
  18. Jan 14, 2020 at 1:56 PM
    Tullie D
    Tullie
    Wilson, NC
    That could work.
    Emergency vehicles use a shield around dash mounted strobes.
    Kevin8se7en[QUOTED] likes this.
  19. Jan 14, 2020 at 1:59 PM
    Cappy
    Cappy Well-Known Member
    Georgia
    Added some bling :D
  20. Jan 14, 2020 at 2:08 PM
    Tiny's Taco
    Tiny's Taco The Wanderer
    Shenandoah Valley
    2018 Inferno TRD Sport
    That's a horrible idea. What time?
    My first truck was a 2WD MT DCLB Ranger. Put a cap and boards on it. Three tubes of sand in the bed over the axle. In 200k miles of Michigan winters, I got stuck once. That was an awesome little truck.
    Burns and shane100700[QUOTED] like this.
