  1. Apr 9, 2020 at 6:55 AM
    HeyWannaTaco
    HeyWannaTaco Well-Known Member
    Dan
    Ontario
    2019 Red DCLB SR5
    OVTuned, OKX Skids, AVS In-Channel, N-fab Predators
    Right on, thanks. I have my box of assorted clips, and my trim removal kit. I still have enough Noico foam, I would just need another 18 sqft box of deadener. Gonna be home for a while anyway...
    Edit: Same question, any tips or discoveries made while doing it that would be helpful to know about?
  2. Apr 9, 2020 at 7:01 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Kitty didnt fit the end design, so ill have her up in the forsale section later today.
    Tullie D[QUOTED] and shane100700 like this.
  3. Apr 9, 2020 at 7:06 AM
    mwaterous
    mwaterous Well-Member Known
    Mark
    Western Slope, CO
    2016 TRD OR
    Buy More Things
    This isn't the right place, but I'm going to vent anyways. I really abhor customer support systems that ask you what your issue is > you enter it > we can't find a solution! contact us? > yes > what is your issue? > enter it again > entering chat > Hi! I'm Billy Bob, what can I help you with today? > :mad::confused::mad:
  4. Apr 9, 2020 at 7:10 AM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    #, #, 0, 0, 0, 0...0...0...00...00000
    OPERATOR... No, OPERATOR!!!
  5. Apr 9, 2020 at 7:17 AM
    KingTacoRey
    KingTacoRey Well-Known Member
    Rey
    DFW, TX
    2018 DCLB TRD-OR QS
    Bed Mat Black Out: Emblems & Wheels Pro-Grille
    Thetacogarage.com and yes it does, i have a 2018 and had to buy the garnish for TSS and so far no problems or errors.. Very easy to install, had my 5 year old work on it with me
    gabbo2112 likes this.
  6. Apr 9, 2020 at 7:55 AM
    RivetNutBob
    RivetNutBob Right Ain't Wrong and Left Ain't Right.
    New England
    2017 MGM ORDC MT SB
    Not sure what is more annoying that or a customer service department that was outsourced to another country that has a customer service agent with an accent and that can't talk slower than the speed of light! o_O
    shane100700[QUOTED] likes this.
  7. Apr 9, 2020 at 7:55 AM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    True. Until you try it with yours.
    Jeff Dartfrog likes this.
  8. Apr 9, 2020 at 7:57 AM
    TACAHOLIC
    TACAHOLIC Well-Known Member
    20 Cement DCSB TRD SPT
    Upgraded today. 2016 TRD Off-Road to 2020 TRD Sport. Pics soon.
    rdjr17, jeosbor1, Lpulford and 7 others like this.
  9. Apr 9, 2020 at 7:58 AM
    CaliRaisedLed
    CaliRaisedLed Well-Known Member Vendor
    Jake
    Texas (DFW)
    Now those are low profile :thumbsup::thumbsup:
  10. Apr 9, 2020 at 8:00 AM
    5nahalf
    Erik
    Minnesota
    When I sprayed my roof with sound deadener I just lowered the headliner and set it on the dash and seats. Covered it with a tarp and sprayed. While I didn't have a ton of space to spray, it was enough. I may remove it all the way when I add more sound deadener later this summer.
    shane100700 likes this.
  11. Apr 9, 2020 at 8:06 AM
    MDFM31
    Chester Co, PA
    16 DCSBOR
    Just basic stuff. Bag and tag bolts that come out. Pull the weatherstripping around the door openings because the interior trim panels slide under them. I broke a couple clips because I didn't know about that. The center dome light has a tab on each corner. I believe you push them inward towards the center of the truck to release them. Watch the corners of the headliner from resting on semi-detached panels around the front seatbelts. The corners are weak.
    I don't have any back seats so I think that made it easier.
    I applied the foam in one sheet. It would've come out cleaner if I had cut it up. I couldn't get the foam into all of these crevices of the roof supports and was worried the headliner might not fit because of it. There wound up being plenty of room. I don't know enough about it to say if it makes a difference if it's cut up or not in this case. Probably not.
    Second skin has a lot of good info on the why and where you need to apply what type of product.
    It took me about 2 hours to drop it. And definitely disconnect your battery.
    On the A pillars, disconnect the electrical connectors and unbolt the wiring from the pillar before dropping it and you may not need to reglue some of the wiring on top of the headliner. There is a similar situation with wiring at the passenger side C pillar.
    DM me if you have any problems.
  12. Apr 9, 2020 at 8:09 AM
    MDFM31
    Chester Co, PA
    16 DCSBOR
    Maybe it does. I'm not going to try it with mine or recommend anyone else try it. My headliner was replaced under warranty at a cost of $3k. Toyota removed the windshield to do it. These things are not strong. The less you can move it around, the better.
    shane100700 and RivetNutBob like this.
  13. Apr 9, 2020 at 8:12 AM
    5nahalf
    Erik
    Minnesota
    Yeah, thats why I just layed it on the seats. I dont need the edges getting all chewed up.
    20tacoma17 and shane100700 like this.
  14. Apr 9, 2020 at 8:20 AM
    BlueBurtTaco
    BlueBurtTaco Member
    Drew
    Camas Washington
    2016 Tacoma TRD
    3” lift, fogged out lights,
    Feels odd working on my truck when I can't really drive it with current circumstances in the PNW. That said I picked up some tools- Krazy Beaver shovel and Fiskar Axe along with mounts. I ended up picking up a back of the cab rail in order to mount under my tonneau cover. I like the results.
    Next project is to de-badge everything. Like the clean taco......
  15. Apr 9, 2020 at 8:44 AM
    Jeff Dartfrog
    Jeff Dartfrog Well-Known Member
    Jeff
    Chandler AZ
    2019 Cavalry Blue TRD Off Road
    Well done. I miss this feature from my BMW days.
    EagleUSMCRet likes this.
  16. Apr 9, 2020 at 8:44 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    265/75/R16 Falken Wildpeak AT3W's, Load Range E, installed on factory TRDOR Rims.
    [​IMG]Falken Wildpeak AT3W by Michael Rickerd, on Flickr
    Much more aggressive and they match the bumper and sliders much better than the purely road tire I removed.
    Gas mileage is down, but I don't drive much, so little worries.
    Minny Taco, TSAVO, Nomad26 and 6 others like this.
  17. Apr 9, 2020 at 8:51 AM
    pochoboy
    pochoboy Well-Known Member
    What made you opt for the "Sport" having had an "OffRoad" ?
  18. Apr 9, 2020 at 8:52 AM
    HeyWannaTaco
    Dan
    Ontario
    2019 Red DCLB SR5
    Thanks for that, I'll let you know. Well if I'm taking the front seats out I might as well take the backs out too, they're easier anyway, just need the seat bottoms out really. Battery for sure, the airbags scare the crap out of me. :eek:
    The Noico sound deadener and foam are in 11"x15" sheets basically +/-, so they are easy to handle and trim to fit. Butt joined together is plenty fine for the foam I think, and 90-95% is just fine leaving room for connectors and clips, whatever. It's not a recording studio. :rimshot::rockband: I'm looking forward to it now. It will be awesome when done, I know it's worth it.
  19. Apr 9, 2020 at 8:54 AM
    dal3_gribble
    dal3_gribble Well-Known Member
    Crew Cab SB TRD Offroad
    315/75r16s.
    Parras, VLTHNTR77, Shayne and 16 others like this.
  20. Apr 9, 2020 at 9:12 AM
    RivetNutBob
    New England
    2017 MGM ORDC MT SB
    Took my Tacoma shopping today since I haven't let my wife out of the house for the last four weeks. TOTALLY out of my wheelhouse. The shopping list went out the window. Adapt and overcome the name of the game. Headed to the package store later to buy grain alcohol since you can forget about buying Chlorox wipes or isopropyl alcohol.
    Can't wait for the country to get a handle on this. If everyone would just buy what they need instead of stocking up for a nuclear holocaust there would be plenty of everything to go around.
    No wonder I like dogs more than I like most (present company excluded) people!
