  1. Apr 16, 2020 at 7:16 AM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    I like those little LED light pods. Here is where I used 4 of them recently.
  2. Apr 16, 2020 at 7:48 AM
    RallySOP
    RallySOP Well-Known Member
    Tom
    2018 Tacoma OR DCSB
    Thank you for that picture. I had a very short thought about using these as scene lights on the sides of my eventual roof rack but worried they wouldn’t have enough throw. They are a lot more impressive than I expected from license plate lights.
  3. Apr 16, 2020 at 8:18 AM
    1992SR5V6
    1992SR5V6 Well-Known Member
    2018 TRD Sport 4x4 Cement
    Bolt on only...
    Took an overhead shot today.
  4. Apr 16, 2020 at 8:27 AM
    oostroma
    oostroma (Boomer)
    Ontario
    I also installed a pair under my tailgate and tied them into my reverse lights. This helps to illuminate the hitch at night.
    TnTHicks and Tacoma-toy like this.
  5. Apr 16, 2020 at 8:36 AM
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    I loved mine. huge improvement! butttttt now they don't touch!:annoyed:
    ANTupLIFE[QUOTED] likes this.
  6. Apr 16, 2020 at 8:47 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    I thought you had a bike rack mounted on your roof rack before my brain caught up and realized it was hitch mounted on the Subaru.
    :anonymous:
    1992SR5V6[QUOTED] likes this.
  7. Apr 16, 2020 at 8:51 AM
    MountainFox13
    MountainFox13 Active Member
    Brandon
    Colorado Springs, CO
    2024 TRD Off Road Hybrid
    Installed door sill protectors.....crazy how these things are not stock. They were on my 2011. Anything to save a few dollars I guess. :cheers:
    rotus, CXYyuppie, TnTHicks and 5 others like this.
  8. Apr 16, 2020 at 9:09 AM
    oostroma
    oostroma (Boomer)
    Ontario
    The sill protectors did come stock on my 2017 TRD OR.
  9. Apr 16, 2020 at 9:16 AM
    MountainFox13
    Brandon
    Must be new for 2020.
    gabbo2112 likes this.
  10. Apr 16, 2020 at 9:19 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    They are generally a dealer or port installed item. Some trucks have em, some dont.
  11. Apr 16, 2020 at 9:30 AM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    Honestly it sounds like the "isolator" feature failed allowing the house battery to discharge the truck battery. I've been over on the MFG's site and talked to the owner and they are still selling the system with no warnings. Have or did you try to resolve the issue with the company?
    Zim
  12. Apr 16, 2020 at 9:33 AM
    barretta
    barretta -
    San Clemente, CA
    '18 White TRD OR 4x4
    I haven't bolted it down fully yet as I'm waiting to stain and seal it but I suppose it could be a good idea to run a bead of silicone around it once it's bolted in place. I also used 1/2" plywood which is way too thick (and a little heavy) but it's what I had laying around. It still goes down slow when I open it so I guess it's not an issue.
    Tiny's Taco[QUOTED] likes this.
  13. Apr 16, 2020 at 9:38 AM
    dand
    dand Blood and tears
    Dan
    Newport News VA
    2021 DCSB TRD Sport Army Green
    Came on my 2020. :eek:
  14. Apr 16, 2020 at 9:52 AM
    Maxcustody
    Maxcustody Looking for answers, Refer to the EAD manual.
    Scott
    Berkeley Springs, West Virginia
    I sent you a PM
    Tacman19[QUOTED] likes this.
  15. Apr 16, 2020 at 10:11 AM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    Pedal Commander device review: So I installed it yesterday and it does improve the throttle lag. I still notice a tiny bit of lag but it is shortened greatly and when past the lag the truck responds nicely. I am running Sport +3 at the moment. Left it out so I could try different settings. It has made me not frown every time I push the accelerator down now.
    Ranger357, TRD4X4TOY and Lpulford like this.
  16. Apr 16, 2020 at 10:23 AM
    MountainManGuy
    MountainManGuy Well-Known Member
    Colorado
    2019 Toyota Tacoma TRD Off-Road DCSB
    For sure, I think it's definitely important to make people aware of the way our alternators work on the 3rd gen and what that means for running agm batteries.
    I'm a bit curious about your setup though. Do you have 2 identical batteries of the same age and size or are they different? Also, do you have any accesories in your truck that may be sipping on power? The reason I ask is, 2 identical batteries of the same age wired in parallel would balance each other out and sit at the same voltage.
    If you have your accessories (like a fridge) wired to the auxillary battery, and that auxillary battery is not being properly charged, then when the 2 batteries get linked it's going to pull charge from the starter battery to try and balance things out. This could lead to you not being able to start the truck if that balance gets too low. In your case though it sounds like you were able to link the aux battery back to the starter battery and start your truck, which means it was your starter battery not being fully charged.
    The point I'm trying to make is, no matter if you have a single or dual battery agm setup, you'll need to top it off periodically or install solar or a dc to dc charger.(Might also be able to replace the alt with an aftermarket one but don't quote me on that) It's not really a problem of having a dual battery setup, but just having agm in the first place with these alternators.
  17. Apr 16, 2020 at 10:42 AM
    TheTacoAdventurer
    TheTacoAdventurer Well-Known Member
    Boston, MA
    2018 DCSB TRD OR
    Forever modding!
    Same for my 2018 TRD OR
    Jeff Dartfrog and Tacoma-toy like this.
  18. Apr 16, 2020 at 10:42 AM
    Maxcustody
    Scott
    My issues were back in 2019 and I ripped everything out in November 2019. When I installed the system in 2017, I had 2 group 35 Odysee PC1400 purchased new at the same time. Yes, I did have a fridge wired to the Aux battery but was not running other then when I was out camping or on trips...........as you stated "In your case though it sounds like you were able to link the aux battery back to the starter battery and start your truck, which means it was your starter battery not being fully charged." This is correct, starter was being drained.................
    I have nothing else on the truck, No winch, no LED's no crazy stereo or any other additional electronics or accessories.
  19. Apr 16, 2020 at 10:44 AM
    1992SR5V6
    Bolt on only...
    That old Thule T2 rack is the best ever, unfortunately the Taco won't fit in the garage with it attached. Tight squeeze for the long bed.
    Fargo Taco[QUOTED] likes this.
  20. Apr 16, 2020 at 10:48 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Rims, Pro Comp 069
    Tires, 265 75 r16,
    stock height
    ETBA, 4waresnowcone, Burns and 11 others like this.
