  1. Apr 27, 2020 at 7:54 AM
    TACAHOLIC
    TACAHOLIC Well-Known Member
    20 Cement DCSB TRD SPT
    Mine come over the edge on my 2020 as well
  2. Apr 27, 2020 at 8:01 AM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    The wireless unit works from about 75' feet away with the hood closed which surprised me. It is very cool to be able to turn on the off road lights while standing away from your truck. Note, these are Amazon.ca links. I'm sure there is a parallel unit at Amazon.com.
    https://www.amazon.ca/gp/product/B012RHTOU0/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    https://www.amazon.ca/gp/product/B01NCA4QA7/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
    shane100700 likes this.
  3. Apr 27, 2020 at 8:09 AM
    narkicu187
    narkicu187 Instagram @foe_pro
    Andrew
    New Mexico
    2016 White AT OR DCSB
  4. Apr 27, 2020 at 8:15 AM
    TacosConTodo
    TacosConTodo Well-Known Member
    Cement 2020 TRD Sport 4x4 DCLB
    It looks like they have a pic on that. link that. shows the non hoop plate, and the light bar still above the bumper.
    Did you go with Aluminum for less weight?
  5. Apr 27, 2020 at 8:45 AM
    TacosConTodo
    Have any pics of them shining on something at night by chance?
    Link to purchase please as well.
  6. Apr 27, 2020 at 8:57 AM
    Ajax24
    Ajax24 Member
    Nick
    2018 WHITE SR5 4x4 DBL CAB TACO
    -Full OME 3” lift -Avid Off-road front bumper guard -ARE CX Classic Topper w/ Windoors -RIGID leds -CaliRaised leds -CaliRaised bed stiffeners
    It was a big week! Upgraded tires from the standard 245/75/r16 to 265/75/r16 Falken Wildpeak AT3Ms. Looks like a whole new truck, and really fills out the wheel wells better with the OME 3" lift. Then we finally got around to installing Yakima tracks and Prinsu Top Rack on the ARE topper. Ecstatic right now! Cheers!
  7. Apr 27, 2020 at 9:05 AM
    Jeff Dartfrog
    Jeff Dartfrog Well-Known Member
    Jeff
    Chandler AZ
    2019 Cavalry Blue TRD Off Road
    "Adhesive bulb type weatherstrip?" Please elaborate
  8. Apr 27, 2020 at 9:09 AM
    greg8765
    greg8765 Well-Known Member
    Greg
    Utah
    2023 Tacoma TRD Off-Road
    Tuff Country Lift, Smart Cap, Tint, Pop & Lock, Door Sill Decals, Rooftop Tent
    those look like second gen door still protectors
    NaYoung[QUOTED] and rotus like this.
  9. Apr 27, 2020 at 9:21 AM
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
  10. Apr 27, 2020 at 9:22 AM
    Rottencotton
    Stinkin Rincon
    So do door locks.
    usmc2msu and NaYoung like this.
  11. Apr 27, 2020 at 9:28 AM
    rotus
    rotus Well-Known Member
    Cypress, TX
    2020 White DCSB TRD OR
    I believe they are. Loose order finger on my part.
  12. Apr 27, 2020 at 9:31 AM
    Rottencotton
    Stinkin Rincon
    Hell hath no fury like a woman with a tude.
    Shayne and blam827 like this.
  13. Apr 27, 2020 at 9:34 AM
    NaYoung
    NaYoung Well-Known Member
    Florida
    2020 TRD ORDC
    I’ve seen that look before. But it was right before having a glass vase thrown in my direction
    Rottencotton[QUOTED] likes this.
  14. Apr 27, 2020 at 9:41 AM
    Mugs
    Mugs Well-Known Member
    Doug
    Pacific North-Wet
    2019 Tacoma TRD Off-Road
    Nitro Gear 5.29's, ARB locker, 3in OME Lift, ARB Leaf Springs, TRD Rims, Nitto Ridge Grapler 285/75/17, TRD skid Plate, CBI Rock Sliders, , ARB Compressor. Total Chaos bed stiffeners. Lots more to come.
    Finished coating the RTT rack in POR15 and then put a couple of coats of textured paint on it. Had a friend 3D print me some spacers to go in between the rails and the bed. That way it forms a compression point that doesn't over extend the rails passed the bed, and also provide a rub buffer between the rack and the bed. Had to make some custom washers to fit the way I wanted them to. Came out pretty good. Now to get the RTT on it, and work out how I'm going to mount the awnings. Hopefully the tube clamps come in soon.
    Ezw0rkz, TnTHicks, markram and 8 others like this.
  15. Apr 27, 2020 at 10:05 AM
    gabbo2112
    gabbo2112 Well-Known Member
    New York
    2020 TRD Off Road
    Looks nice man! I was wondering with the lift did you add the carrier bearing drop rear shims? Any driveline vibes? Almost ready to pull the trigger in Dakar’s and 885’s.
    Ajax24[QUOTED] likes this.
  16. Apr 27, 2020 at 10:05 AM
    SCQTT
    SCQTT Well-Known Member
    Scott
    Mikes Sky Rancho
    Super Cracker Tacoma
    Bigfoot air freshener
    Its not like the $20 is a big deal, but as anal and over-thinking as Toyota is in most cases how can this be overlooked?
    Meso Design is good, but I think the gas cap fit is weirdly tight necessitating two hands to insert the cap. It does not need to be tight to work. Would function better if the hole were 1mm larger. Even if the cap were sloppy loose it would still stay put. I'll probably remove and Dremel larger.
    TnTHicks and NaYoung like this.
  17. Apr 27, 2020 at 10:12 AM
    Ajax24
    Ajax24 Member
    Nick
    I had some driveline vibes after install. I actually have a thread on here that says how I fixed them! I'd buy them again for sure. Driveline angles are key, ended up having to install the CB drop and 3* shims on rear axle to make them stop. The fix seems to be pretty common between everyone, just minor differences. Hope this helps!
    gabbo2112[QUOTED] likes this.
  18. Apr 27, 2020 at 10:12 AM
    crossrifles
    crossrifles Well-Known Member
    2020 TRD 4X4
    Bed lighting kit and Total Chaos stiffeners.
    OEM running boards
    MESO chrome delete in red on air vents and start, and 4WD switch.
    Snugtop Rebel won't be in till May 11th. Don't know how I feel about Snugtop as a company. I ordered March 17th with a promise date of no more than 3 weeks so first or second week of April, understandable with the Covid 19. However they are filling orders to people that ordered after I did. Seems shady to me.
    Intrepid, honey, TnTHicks and 16 others like this.
  19. Apr 27, 2020 at 10:14 AM
    Coolfinedonewicked
    Coolfinedonewicked Well-Known Member
    Kaua’i, Hawai’i
    2019 Cement Tacoma TRD OR DCSB
    Jeff Dartfrog[QUOTED] likes this.
  20. Apr 27, 2020 at 10:23 AM
    oostroma
    oostroma (Boomer)
    Ontario
