  1. Jul 14, 2020 at 9:28 AM
    ohcjam
    ohcjam Well-Known Member
    2018 TRDOR DCSB
    Eibach 2.0 Stage 1 Suspension Kit Headstrong Off-Road 1/4" spacer Deaver AAL Total Chaos Bed Stiffener BakFlip MX4 Tyger Running Board N2 12Volt Remote Start Pop N Lock Auxbeam Blue 8 SW Panel Blue Sea System Fuse Block Auxbeam H11 LED Headlight JDM ASTAR Fog Light CaliRaisedLED Ditch Lights 27W Hondo Garage: Un-Holey Dash Mount + Perfect Grip 12" RCI Adjustable Bed Rack (RotopaX and MAXTRAX mounts) Anytime Backup/Front Camera ME-SO Customs stuff..and more stuff..and more..stuff...
    I just got mine delivered. There is small amount of surface rust, but not as much as the one you got.
  2. Jul 14, 2020 at 9:38 AM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    It might be moisture problem. Did you see the moisture absorber packet in the package? If not, that's why. They should put one or two in the package and place on the shelves waiting to be shipped out.
  3. Jul 14, 2020 at 9:47 AM
    TAZMINATOR
    2017 Tacoma
    That sucks... Hope you get it sorted out and that company pay for the repairs.
  4. Jul 14, 2020 at 9:54 AM
    RivetNutBob
    RivetNutBob Right Ain't Wrong and Left Ain't Right.
    New England
    2017 MGM ORDC MT SB
    Some WD40 saturated 0000 steel wool should clean that up no problem.
    gabbo2112 likes this.
  5. Jul 14, 2020 at 9:55 AM
    RivetNutBob
    New England
    2017 MGM ORDC MT SB
    Oops late to the party.
  6. Jul 14, 2020 at 9:57 AM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    I'd use steel wool and just a drop of 3 in 1 or similar oil.
  7. Jul 14, 2020 at 9:58 AM
    RivetNutBob
    New England
    2017 MGM ORDC MT SB
    Either will work as well as PB Blaster or just about any other penetrating oil in conjunction with the 0000 steel wool.
  8. Jul 14, 2020 at 10:34 AM
    JimResnikoff
    JimResnikoff Well-Known Member
    JIm
    Tacoma
    Rockford / Focal Audio upgrade
    I noticed mine did not come with a front bed rail.. Are they just removing them ? Did the dealer provide or was the cost on you?
    RivetNutBob likes this.
  9. Jul 14, 2020 at 10:38 AM
    RivetNutBob
    New England
    2017 MGM ORDC MT SB
    It is now an accessory item, anything to squeeze another dollar ftom you. It's actually good business on their part.
  10. Jul 14, 2020 at 10:39 AM
    JimResnikoff
    JIm
    Tacoma
    Thank you for the update.. I just tapped out an email to the dealer asking the same question. At least there are still the front two tie down points...
  11. Jul 14, 2020 at 10:41 AM
    Alamo72
    Alamo72 Well-Known Member
    2020 Tacoma SW TRD OR DCSB Tech & Prem+LED
    Mostly Stock
    Apparently Toyota stopped adding including the front bed rail around 2016, but the bolts are still there. Easy install.
    EagleUSMCRet and RivetNutBob like this.
  12. Jul 14, 2020 at 10:41 AM
    RivetNutBob
    New England
    2017 MGM ORDC MT SB
    But now they get to sell you the two rear tie downs that used to be standard equipment. All about the bottom line.
  13. Jul 14, 2020 at 10:42 AM
    RivetNutBob
    New England
    2017 MGM ORDC MT SB
    And another $50 or so dollars.
  14. Jul 14, 2020 at 10:44 AM
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    This got me wondering how steel wool is made.
    https://www.youtube.com/watch?v=nkR-naEnswQ
    Shayne, Bratworx, CXYyuppie and 11 others like this.
  15. Jul 14, 2020 at 10:46 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    For anyone following this, hopefully, @Mr.Pink Taco will give us an update on his experience, but I personally reached out to John at Overland Equipped to voice my concerns...
    He asked that I let everyone know that, "he's aware and working up a solution .. customers should check to make sure the bracket doesn't touch the wiring before fully tightening down the bracket .. more action will be taken" :thumbsup:
    Jeff Dartfrog, Shayne, C41n and 3 others like this.
  16. Jul 14, 2020 at 10:49 AM
    RivetNutBob
    New England
    2017 MGM ORDC MT SB
    FYI. Should you decide to add the accessory rail it's recommended that you loosen by hand and then back out the rest of the way if using a drill/driver. Failure to break free by hand could result in snapping off the head of the torx screw. It's happened.
    rcooper likes this.
  17. Jul 14, 2020 at 10:51 AM
    RivetNutBob
    New England
    2017 MGM ORDC MT SB
    Shayne and Rottencotton[QUOTED] like this.
  18. Jul 14, 2020 at 10:52 AM
    Ruminator
    Ruminator Chairman of the Bored
    Mark
    Northern Illinois, USA
    2017 Red TRD-Sport, ACLB, MT!!!
    Alright doll-face, c'mon and bore me!
  19. Jul 14, 2020 at 10:54 AM
    TAZMINATOR
    2017 Tacoma
    I watch that show all the time. Interesting how they are made. Such as so tiny stuff and big stuff.
    Shayne, RivetNutBob and Tacospike like this.
  20. Jul 14, 2020 at 10:57 AM
    RivetNutBob
    New England
    2017 MGM ORDC MT SB
