  1. Jul 15, 2020 at 7:24 PM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
  2. Jul 15, 2020 at 7:31 PM
    JRLYON
    JRLYON Well-Known Member
    Portland, OR
    2020 Cement TRD Off Road DCSB
    KDMaxx Tuned Bilstein 6112/5160 set at 2” w/ 1.5” Icon AAL 2020 TRD Pro Shocks and Struts (no longer installed) 2020 TRD Pro 16" Wheels Goodyear Wrangler Duratrac 265/75/16 tires Alpharex LUXX Series LED Taillights Black/Red (no longer installed) 2020 TRD Pro Taillights TRD Performance Air Intake TRD Performance Exhaust TRD Front Skid Plate Tyger T3 Soft Fold Tonneau Cover TacoGarage Pro Grille w/OEM sensor garnish Taco Garage DSM w/ magnetic phone mount Runnin4Tacos Smoked Amber Grille Lights (CURRENTLY NOT INSTALLED) Runnin4tacos amber grille lights) Runnin4Tacos Lower Control Arm Skid Plates Katzkin Black Leather Interior with red stitching and TRD logo in seat back TRD Pro Shift Knob TRD Oil Cap TRD Radiator cap TRD Off-Road Special Tailgate badge JLT 3.0 Oil Separator Catch Can Demon Brackets w 3/4" red/black Autmatch D-Ring Shackles Black Emblems and Tailgate badge OEM Bed Lights OEM Predator Tube Steps AVS In Channel Window Visors MESO Total Tail Stage 1 MESO Ultimate Map Lights (Dual Color) (CURRENTLY NOT INSTALLED) MESO Ultimate Map Lights (White) MESO Ultimate Dome Light V2 (Dual Color) MESO Chrome Delete Kit Red MESO Customs Red Start/Stop Ring MESO Customs Red 4x4 Select Ring MESO Customs Red Start/Stop Button (Small Letters) MESO Customs V5 Ultimate Turn Signals (Reverse Sequential) MESO Customs TRD Stearing Wheel Emblem cover MESO Customs red door handle chrome delete (CURRENTLY NOT INSTALLED) MESO Customs black door handle chrome delete TVDVinylDecal red door sill protector letters TVDVinylDecal red glovebox letters Redline Tuning Hood Struts Diode Dynamics SS3 Pro Fog Lights (White) (CURRENTLY NOT INSTALLED)Diode Dynamics LED 194 HP5 Map Lights (CURRENTLY NOT INSTALLED) Diode Dynamics LED HP6 29mm Festoon Dome Light Bulb (CURRENTLY NOT INSTALLED) Diode Dynamics LED 28mm Fuse Vanity Bulbs Diode Dynamics LED 194 HP3 License Plate Bulbs Taco Vinyl TRD Grille Badge Black/Red Cupholderhero cupholder/door/pocket rubber liners Front Tinted Windows to match rear OEM tint OEM Tacoma Rubber Bed Mat OEM Tacoma Bed Extender Tacos4Cheap TRD Coin Box JDMCAR Glove Box Organizer Insert JDMCAR Center Console Organizer Insert CeramicPro 9h Lifetime Ceramic coating
    Any ideas on how to fix this other than replacing. The black wrap on the doors got jacked up
    Any sort of a rubbing compound or wax for that vinyl that might fix it?
    Or has anyone paid to have a piece replaced. If so what was cost?20200715_191953.jpg 20200715_192115.jpg
  3. Jul 15, 2020 at 7:33 PM
    BGXtobe
    BGXtobe Well-Known Member
    Central Valley, CA
    2016 MGM TRD Sport 4x4
    303 or taking off the black plastic vinyl.
    JRLYON[QUOTED] likes this.
  4. Jul 15, 2020 at 7:42 PM
    DLRIII
    DLRIII Well-Known Member
    David
    Baton Rouge
    2018 Quicksand SR5 DCSB V6
    Shims correct the angle of the rear portion of the drive shift which changes when you lift the rear of the truck because you're adding height difference between the rear drive shaft portion and the carrier bearing. Whether you get 1 leaf or 3 leaf aal, the height you gain is the main factor in needing shims or not. You can always try without and see if you're getting vibrations and if so you can go back and add the shims, not a big deal if you're doing the work yourself. If you want to play it safe, go ahead and get some shims and install them with the aals because i think most people need them to avoid drive vibrations.
    opeesha likes this.
  5. Jul 15, 2020 at 7:55 PM
    Pistol Pete
    Pistol Pete Go Pokes!
    Eric
    Oklahoma
    2016 MGM DCSB OR 4x4
    Clazzio leather seat covers, CBI T3 front, SOS sliders, SCS Ray10s, 285/75/16 Duratracs, debadged, extra bed D-ring tiedowns, Advantage TorzaTop, OEM bed mat, custom center console organizer, Husky liners, remote start.
    Well I need airbags and a brake controller for sure
  6. Jul 15, 2020 at 7:57 PM
    BGXtobe
    Central Valley, CA
    I’ve used this one before I’m not 100% sure that it will take the scratches off but they don’t look very deep so I think this will still make less noticeable . 303 (30382) Products Automotive Protectant - Interior And Exterior - Ultimate UV Protection - Helps Prevent Fading And Cracking - Repels Dust, Lint, And Staining - Non Greasy Finish, 16 fl. oz. https://www.amazon.com/dp/B0185PU38A/ref=cm_sw_r_cp_api_i_jh8dFbJ69TS30
  7. Jul 15, 2020 at 8:05 PM
    Caudizle
    Caudizle Member
    2017 White Tacoma TRD Off Road
    Sorry for the late reply. I can't open the Diamondback SE cover with the rack on. But it's four bolts (with lock washers) to remove from the mounting brackets that I leave in place. Right now I need a second set of hands to remove and put on, but I'm planning on hoisting it up from the ceiling in my garage. Especially when it has an RTT on it.
    Rottencotton likes this.
  8. Jul 15, 2020 at 9:01 PM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    New grille. And it's not a pro grille!
    TnTHicks, C41n, TSAVO and 9 others like this.
  9. Jul 15, 2020 at 9:08 PM
    oostroma
    oostroma (Boomer)
    Ontario
    It's good to be different. Any change in engine temp after replacing the grill?
  10. Jul 15, 2020 at 9:13 PM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I really didn't look into it.
  11. Jul 15, 2020 at 9:21 PM
    Goatfrog
    Goatfrog Well-Known Member
    Bill
    Pittsburgh, PA
    2020 Red DCLB TRD Off Road
    dunno why, but something about that grill screams zombie apocalypse escape vehicle to me... very cool :thumbsup:
    Jeff Dartfrog and C41n like this.
  12. Jul 16, 2020 at 12:09 AM
    BGXtobe
    Central Valley, CA
  13. Jul 16, 2020 at 3:23 AM
    Cappy
    Cappy Well-Known Member
    Georgia
    Thanks for the explanation. I just dont believe I've heard of that before until recently, never done suspension work before. I'm looking at a 1.5" 3 leaf install and read where one person used 2° and another used 3°. Do you have a recommendation? Thx
  14. Jul 16, 2020 at 4:38 AM
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    Put a couple of chickens in there and you'll have fresh eggs.
    VB25, stopfive, Sandy94 and 5 others like this.
  15. Jul 16, 2020 at 4:43 AM
    TacoNesian
    TacoNesian Well-Known Member
    Alex
    Fort Smith, AR
    20 WHT Taco TRD OR DCSB Tech/Prem 4x4 AT
    5.29 gears, front E-locker, CMR, OTT & ProCharged.
    Installed my first tonneau cover, a Retrax Pro XR retractable cover. Very durable and love the look, well worth the lifetime warranty. Now waiting for my Yakima crossbar set and bike rack to come in prior to a cross country trip.
  16. Jul 16, 2020 at 4:44 AM
    Chief 4x4
    Chief 4x4 Well-Known Member
    Tim Dean
    Mississippi
    2017 TRD 4WD
    TRD GRILL WET OKLOE SEAT COVERS RAPTOR GRILL LIGHTS NEW OFF ROAD BED DECALS SCS Ray 10'S 16x8 Gunmetal OVTune
    That's awesome!! The JSTAR crews definitely get allot of deployments to those undisclosed locations, I have been to allot of the places my self.
    Cappy[QUOTED] and Brownie_Man like this.
  17. Jul 16, 2020 at 5:06 AM
    DLRIII
    David
    Baton Rouge
    I cant say for sure, but 1.5" is what I gained with my aal and it included 3 degree shims and I have had no vibrations or issues at all.
    Cappy[QUOTED] likes this.
  18. Jul 16, 2020 at 5:25 AM
    Ashyr
    Ashyr Active Member
    2020 Army Green Tacoma TRD Pro
    Did this a while back when I first got the truck. I don’t think I’ve seen people change the pedal covers. My feet would slip on the stock rubber and plastic when I wore my dressy boots.
    Vegeta7, VB25, TnTHicks and 16 others like this.
  19. Jul 16, 2020 at 5:33 AM
    sallad4x4
    sallad4x4 wubba lubba dub dub
    dallas
    PDX, OR
    2017 ACLB sr5 v6 4wd
    that looks great. you are giving me some great ideas. can i ask, what else did you add? i also have an access cab and am trying to figure out how to add subs.
  20. Jul 16, 2020 at 5:35 AM
    Ruminator
    Ruminator Chairman of the Bored
    Mark
    Northern Illinois, USA
    2017 Red TRD-Sport, ACLB, MT!!!
    Alright doll-face, c'mon and bore me!
    Pistol Pete[QUOTED] and oostroma like this.
