  1. Aug 5, 2020 at 8:12 AM
    Nomad26
    Nomad26 Well-Known Member
    Escondido, CA
    '16 MGM OR Access Cab, ‘16 MGM RAV4 Hybrid
    I don't block my license plate, because why? If anyone were too look up my plates, they are registered to a mailbox anyway, not my physical address. I still wouldn't block them even if it wasn't set up that way. There are bigger things to worry about. Like @Ruminator said, you took the photo with your phone most likely, so it's already out there for the world to see! There is no such thing as privacy anymore.
    Shayne, gabbo2112 and RivetNutBob like this.
  2. Aug 5, 2020 at 8:29 AM
    Tacoma BC
    Tacoma BC Well-Known Member
    2024 Silver Tacoma TRD OFF Road
    How's the wind noise with the Prinsu? I just put a shell on my 2020. I'm putting the Prinsu on the shell for sure, debating on the cab. I hate wind noise. Haha thanks.
  3. Aug 5, 2020 at 8:34 AM
    HeyWannaTaco
    HeyWannaTaco Well-Known Member
    Dan
    Ontario
    2019 Red DCLB SR5
    OVTuned, OKX Skids, AVS In-Channel, N-fab Predators
    Same. I work for the city dispatching fire trucks, we love our digital map!!
  4. Aug 5, 2020 at 8:36 AM
    HeyWannaTaco
    Dan
    Ontario
    2019 Red DCLB SR5
    Too many TLA's... ?!?!;)
  5. Aug 5, 2020 at 8:40 AM
    johnnyroid
    johnnyroid Well-Known Member
    Vine Grove (Fort Knox) Kentucky
    2017 Black Tacoma Sport TRD
    And tell us if there is any rubbing when you do.....:rofl:
  6. Aug 5, 2020 at 8:42 AM
    HeyWannaTaco
    Dan
    Ontario
    2019 Red DCLB SR5
    Yup. That's the way to do it. :thumbsup:
  7. Aug 5, 2020 at 9:10 AM
    WyoRoadDog
    WyoRoadDog Well-Known Member
    2018 TRD OR
    If you hit the website, there’s an option to sign up for email when they’re back in stock.
    playdixie[QUOTED] and Shayne like this.
  8. Aug 5, 2020 at 9:11 AM
    johnnyroid
    I too am an end user, we use it a lot with range operations.
  9. Aug 5, 2020 at 10:53 AM
    SubCultureNM
    SubCultureNM Well-Known Member
    Brian
    Houston, TX
    2017 DCSB
    Thanks for the compliment!
    I'll be more than happy to, if you'll bear with me. My friends at a local fab shop are going to make a bracket for it next week. I envision setting the solenoid pack upright (Warn logo facing driver) with the plug for the controller facing straight up (if that makes sense). It will be on the passenger side of the center bracket that holds the hood latch. Even though the winch has a controller that can be used wireless, I'd like to have easy access to the plug, just in case.
  10. Aug 5, 2020 at 11:27 AM
    Fatmonk8
    Fatmonk8 Did anyone ever tell you you're my hero?
    Paul
    Delco, PA
    2019 SR5 Barcelona Red Taco 3.5 V6
    Installed a Backflip MX4.
    Actually reinstalled it, since the last rain showed this thing didn't hold out water at all..
    TnTHicks, ohcjam, RivetNutBob and 3 others like this.
  11. Aug 5, 2020 at 11:29 AM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    None of them do, even the OEM, still prefer the bakflip enough that I even sold my OEM.
    tehkei90 likes this.
  12. Aug 5, 2020 at 11:38 AM
    Fatmonk8
    Paul
    Delco, PA
    My older cover from Extang didn't leak this much, I get it will never be waterproof and I expect leaks, but so far this thing has performed worse then the older Extang, hopefully it was operator error and not the product.
  13. Aug 5, 2020 at 11:40 AM
    TacoBuffet
    AL
    Huh, I've had one on my 19 and 20, only leaks a trace amount towards the front of the cab and runs under my bet mat (even in AZ monsoons) and I didn't bother to install the drain hoses either. Ya maybe just check how its sitting in the rails.
    Fatmonk8[QUOTED] likes this.
  14. Aug 5, 2020 at 11:41 AM
    littletacomalover99
    littletacomalover99 Member
    Which ones did you end up going with?
  15. Aug 5, 2020 at 11:49 AM
    lukeoct8
    lukeoct8 Well-Known Member
    2017 TRD Sport Black
    Leer HF350M tonneau is a non-leaker. A couple dribbles by the tailgate corners, but that's it. I've never had anything inside get wet, even through car washes.
    RivetNutBob and Fatmonk8 like this.
  16. Aug 5, 2020 at 11:55 AM
    TacoBuffet
    AL
    My bakflip same just some dribbling towards the front where the drain tubes should be, I prefer the flush look over the Leer and some of the other bulkier ones, my stuff stays dry no prob, is it 100% waterproof, no, but don't need it to be.
  17. Aug 5, 2020 at 11:59 AM
    Mix
    Mix Member
    2020 6A SB TRD Off RD Premium
    Added a BakFlip!
  18. Aug 5, 2020 at 12:16 PM
    Danactive
    Danactive Instagram: xxdanactivexx
    Dan
    Upstate New York
    2016 MGM TRD Sport 4x4 DCSB
    Check Out My Build Thread :)
    one of my favorite sliders right there!
  19. Aug 5, 2020 at 12:18 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    I got my 15k oil change. Does that count?
  20. Aug 5, 2020 at 12:25 PM
    Fatmonk8
    Paul
    Delco, PA
    Yeah, that's why i took it off and tried to reinstall and add more gasket where i think it needed it. I probably installed it wrong. But the other day we had a heavy storm come thru and is was leaking heavy around the rails all along the sides. its like my bed wasn't even covered in a sense.
    TacoBuffet[QUOTED] likes this.
