  1. Sep 11, 2020 at 12:08 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I'm curious on the bracket in your cubby and the parts list for that stuff, it looks nice. Now that I have my molle panel I think I could make better use of the cubbies for things I want accessible but semi protected. I had planned for a compressor in the driver's side and wasn't sure yet what I might do with the passenger side cubby but I like the idea of electronics there, perhaps a 12v port, usb charger ports, a switch for bed lights, etc. That emblem at the front of the bed looks really nice!
    Did you consider using the top rail for wires? Are they just temporarily looped like that?
  2. Sep 11, 2020 at 12:09 PM
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    Mounting hardware provided is different.
    OEM are class 8.8 (lower grade) 17mm M12-1.25 SEMS and 12mm M8-1.25 SEMS bolts, full threaded. The OEM bolts also have tapered ends for easier install. They also come with metal bolt retainers.
    Faux are class 10.9 (higher grade) 15mm M12-1.25 and 10mm M8-1.25 flange bolts, partial threaded. Not being SEMS means they don't have built in washers. Also plastic bolt retainers...
    Spacers are the same quality.
    Now the Skidplate is almost exactly identical, EXCEPT for the jack point.
    (Faux)
    (OEM)
    If you noticed OEM has a bulge on the Jackpoint, while the Faux is smooth. That is because there is no extra reinforcement on the Faux TRD Skidplate.
    I have jacked it up, and seems okay. Best to used some sort of padding though, to not scrape the powercoating and distribute the weight.
    The faux Jackpoint is right under the trucks original Jackpoint, so I think it is okay.
    Edit: Another note on the jack point for the Faux TRD Skidplate. If you are running extra weight, you may want to becareful. You will still be able to raise the truck, but I am pretty sure even 1/4" aluminum will start to bend and give. OEM TRD Skidplate is reinforced with about 1/2" at the jack point.
  3. Sep 11, 2020 at 12:17 PM
    Khoadattran
    Khoadattran Well-Known Member
    Khoa
    Thanks a lot for the detailed perspective. I am down to buy 1 if there is 20 people or more.
  4. Sep 11, 2020 at 12:25 PM
    Khoadattran
    Khoa
    Any issue with getting to the oil filter?
  5. Sep 11, 2020 at 12:30 PM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Some say that Mobil1 charged their formula for their regular "Mobil1 synthetic" so if you choose Mobil1 it's better to go with their Extended Service type .
    Tacorific[QUOTED] likes this.
  6. Sep 11, 2020 at 12:34 PM
    Rainoffire
    I guess the same difficulty as with the OEM TRD Skidplate. The access panel is the same.
  7. Sep 11, 2020 at 12:37 PM
    Khoadattran
    Khoa
    Good to know
  8. Sep 11, 2020 at 12:39 PM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    The Toyota emblem I found on E-bay and purchased 6 months before I got around to installing along with the other bed lighting. I have a dual USB with voltage readout and a 12v outlet for my Koolatron.
    I mounted the plugs in a piece of black plexiglass which I also used for the Toyota lighted emblem at the front of the box. There is a 4x fuse panel to the left mounted inside the cubby as well. I used an L bracket to mount the panel and fuse block. Al this was pre-wired and tested on my workbench. I pulled the cubby, mounted all the hardware and then re-installed the cubby after I connected the main power from the battery and ground to the fuse block.
    daveeasa[QUOTED] likes this.
  9. Sep 11, 2020 at 12:39 PM
    Alamo72
    Alamo72 Well-Known Member
    2020 Tacoma SW TRD OR DCSB Tech & Prem+LED
    Mostly Stock
    Ditto.
  10. Sep 11, 2020 at 12:40 PM
    Rainoffire
    He has only mentioned UPS. Slow boat is a Hong Kong own carrier. Idk if they have used DHL.
  11. Sep 11, 2020 at 12:43 PM
    oostroma
    oostroma (Boomer)
    Ontario
    Hook me up please. I'm sure I can get a few local TW members to go in a group buy/ ship to me deal.
    Bratworx and Jakedawgy like this.
  12. Sep 11, 2020 at 12:52 PM
    Rainoffire
    PM me your address, and I will forward it to him.
    Once I get a shipping quote, I will inform you, then you can talk with interested parties if you agree with the group price. Minimum of 5 orders is necessary for slow boat option.
  13. Sep 11, 2020 at 1:05 PM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    I took a picture today for lightbar.
    Before:
    After:
    Sorry for odd color in the 'after' picture. There was no sun. Just cloudy.
    I will take another picture when the sun is up.
  14. Sep 11, 2020 at 1:07 PM
    Rainoffire
    Also, finally got around to cleaning the bed of my truck. Traces of last year's Christmas... Not the presents I wanted.
    TnTHicks, Burns, honey and 4 others like this.
  15. Sep 11, 2020 at 1:08 PM
    blam827
    blam827 Well-Known Member
    Brent
    Peachtree City, Ga
    White 2019 TRD Sport 4x4
    TRD Shift knob TRD gun metal wheels w/ 265/65-17 BFG LED fog lights K&N Cold Air Intake Redline Hood Struts Morimoto XB Headlights MBRP Dual Cat Back Exhaust Toyota Mud Guards LED interior light kit ( blue ) Meso Stage 2 tail lights Meso Puddle lights Meso chrome delete interior Meso Gas Hole Meso Ultimate turn signals Front Anytime Camera Mod Supreme Suspension 3”/2” lift Roll up Tonneau Cover Southern Styje Off-road Slim-line front bumper Warn 10000lb winch with synthetic rope Matt Gecko LED Blue Bed lights / front white hood light De-badge and De-vinyl Tinted front windows. TRD Pro Skid Plate Bed rug Auxiliary fuse block bracket Blue Sea aux 6 circuit fuse block w/50amp circuit breaker JLT oil separator Remote starter mod KTJO bowl lights. ( blue ) Cali raised ditch lights w/brackets Winch shut off switch. Still to do: Rock sliders.
    :facepalm::facepalm:
    Well now that I’m about done buying shit for my Taco, she has asked when am I gonna start buying shit for her 4Runner Trail Edition. :confused:
  16. Sep 11, 2020 at 1:11 PM
    Tacospike
    Two Trucks
    LOL, I've been looking at that exact one for my lady. She digs the cement color. She said she has to approve all the things I would want to do to it first before I do it though.. might slip in some extra and just say sorry, it's because I love you. Can't go wrong right?
  17. Sep 11, 2020 at 1:13 PM
    gurneyeagle
    gurneyeagle Well-Known Member
    Saint Augustine, FL/Houston, TX
    2008 Tacoma SR5, 2018 Audi TT RS, 2018 Tacoma TRD Off Road (Cement), 2019 MDX
  18. Sep 11, 2020 at 1:14 PM
    TeardropTaco
    TeardropTaco New Member
    '17 SR5, DBL, LB
    Victory 4x4 Racks, concealed ammo cans behind fenders, fumoto oil drain valve, LED lights
    Bought Rear/Front Diff fluid at the dealership today. Owner's manual says 75W85 but the guy behind the parts counter said they use (and sell) 75W90 instead. Is this OK?
  19. Sep 11, 2020 at 1:26 PM
    meats
    meats superwhite MT taco meats
    Justin
    Grapevine, TX & Cushing, OK
    '20 Super White DCSB 6spd MT 4x4
    Lots--
    pic from @CaliRaisedLed maybe they can tell us?
  20. Sep 11, 2020 at 1:50 PM
    BokerTov
    BokerTov Well-Known Member
    The Rockies
    3rd Gen DCSB
    Could I ask a favor? If anyone out there has a stock 2020 TRD Pro, could you measure the height from the floor to the top of the cab, including the fin antenna? The Toyota site says 71.6 but it does not mention if this includes the antenna or not. I'm trying to figure out if I can get a Taco + a RTT into my garage and the local dealer didn't have any TRD Pros in stock for me to measure.
    markram likes this.
