  1. Sep 18, 2020 at 8:26 PM
    shiwonhae
    shiwonhae Member
    Dan
    Indian Trail, North Carolina
    2019 Tacoma OR DCSB
    Added new wheels and tires on Thursday, TRD pro 17” 265/70 r17 and Changed out the chrome bumper with black end caps. Almost don’t with the mods
    JRH_Tacoma, ohcjam, dleriche and 7 others like this.
  2. Sep 18, 2020 at 8:39 PM
    Tamagotchee
    Tamagotchee Well-Known Member
    SWVA
    2019 TRD Off Road Tacoma
    Looks awesome! Can never be done with mods though. :spending:
  3. Sep 18, 2020 at 8:42 PM
    HeyWannaTaco
    HeyWannaTaco Well-Known Member
    Dan
    Ontario
    2019 Red DCLB SR5
    OVTuned, OKX Skids, AVS In-Channel, N-fab Predators
    I installed some new speakers in the front doors today. Rockford Fosgate The Punch Model 1692 6x9. I didn' take any pics, but just in case you're doing this, reuse the existing Toyota speaker frame to install these. Strip out all the old speaker guts, and wires, cut out all the "supporting crossmembers" leave the yellow foam ring and use the remaining frame to mount the new speakers too. You will need to drill four small holes on the edge on the plastic speaker frame to drive the mounting screws at a slight angle it works fine, and no chance of puncturing the new speaker. Keeps the speaker magnet away from the window in the down position, and lots of room behind the door panel. Reinstall using the factory 10 mm bolts. The new sound beats the factory set up by a mile.
    I used these wiring harnesses from Amazon for a plug and play experience.
    https://www.amazon.ca/gp/product/B01GEIP7RW/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    In the back doors I installed the Rockford Fosgate 6.5"round speakers with the same set of wiring harnesses. Super easy install, same thing, reuse the factory speaker frames as a mounting bracket for the new ones. About an hour each set to install. Way better sound for under $500 .
    Next will be the tweeters and maybe a sub woofer and amp.
  4. Sep 18, 2020 at 8:52 PM
    HeyWannaTaco
    Dan
    Ontario
    2019 Red DCLB SR5
    Same. Red one's are en route should have them Monday.
    Tacospike[QUOTED] likes this.
  5. Sep 18, 2020 at 8:52 PM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    I did exactly that 2 weeks after I brought the truck home except I installed Infinity all around. Recently I put some self adhesive sound deadening foam around the speaker on the door panel and it has improved bass response considerably.
  6. Sep 18, 2020 at 9:10 PM
    HeyWannaTaco
    Dan
    Ontario
    2019 Red DCLB SR5
    I sound deadend and insulated the whole truck, floors, doors, back panel, about a month after I got it. Only have the headliner left to do.:thumbsup:o_O
    RivetNutBob likes this.
  7. Sep 18, 2020 at 9:20 PM
    oostroma
    oostroma (Boomer)
    Ontario
    Great minds think alike.
    HeyWannaTaco[QUOTED] and meats like this.
  8. Sep 18, 2020 at 9:28 PM
    Londo-Cat
    Londo-Cat Well-Known Member
    Guy
    2020 SR5 4x4 v6 w/predator package & midnight black metallic
    TRD Skidplates (Front/Back) Predator XP package
    Well - it looks like my Truck... except yours is a TRD Pro... Same thing - SR5 with Yakima rack and Pinshu soon. Added Demon Brackets and red D-Rings with the AlphaRex LED Alpha Black headlights.
  9. Sep 18, 2020 at 10:10 PM
    not_tacomike
    not_tacomike Well-Known Member
    CA
    2020 Tacoma
    Where did you get that mount?
  10. Sep 18, 2020 at 10:32 PM
    Londo-Cat
    Guy
    2015-2020 Toyota Tacoma 4PCS Anti-dust Seat Bracket for Fixing Bolts Cover (Trims Accessories)
    https://www.amazon.com/gp/product/B07W1P11RL
    One of my biggest grips is the metal feet of seats in my Toyota's - they are ugly as hell. So - I had these on my Prius - so picked up some for my new Tacoma!
    Passenger Side (manual adjust chair) Before and After
    Drivers side (10-way Power Adjustable). Before and After.
    Only thing I had to do was cut the curve off at the end and sand it flat and it fit like a glove.
  11. Sep 18, 2020 at 10:38 PM
    Londo-Cat
    Guy
    I use Aluminum Anti-Seize - and then usually use a q-tip to smear it on the threads on the inside. Works like a charm every time.
  12. Sep 18, 2020 at 10:42 PM
    KlutchTaco
    KlutchTaco Well-Known Member
    Central IL
    2018 Trd Sport 4x4
  13. Sep 19, 2020 at 1:24 AM
    CWill
    CWill Member
    2019 TRD Sport 4X4
    Finally swapped over the factory tires to KO2s.
    Over the past 6 weeks; upgraded to the black Pro Wheels, Morimoto headlights, and pro grille.
  14. Sep 19, 2020 at 3:59 AM
    dave.h
    dave.h Well-Known Member
    SLC Utah
    2020 TRD Off Road DCLB
    @Beaver18 I’ve been planning this mod for a while. Just curious— some Amazon reviews talk about quality issues (stopped working, adhesive issues w “sticker” etc). Is this still going strong for you (and do you still like it?). Also— amazon says not compatible w 2020 Tacoma but I’m guessing that may just mean a harness adapter may be necessary. Was this plug and play for you? Sorry for all the questions at once and thx! Looks great!
  15. Sep 19, 2020 at 4:55 AM
    AbnMP13
    AbnMP13 Well-Known Member
    Shelby
    2020 TRD Crew Long Bed
    Pics or it never happened.
    Tacospike likes this.
  16. Sep 19, 2020 at 6:06 AM
    treyfive
    treyfive Well-Known Member
    Brandon
    New York
    2017 PEARL BLUE TACOMA TRD OFF ROAD
    Early morning road trip...arrived at destination & gave her a bath
  17. Sep 19, 2020 at 6:22 AM
    RivetNutBob
    RivetNutBob Right Ain't Wrong and Left Ain't Right.
    New England
    2017 MGM ORDC MT SB
    :anonymous: yup, deleted! :anonymous:
    -Rorschach-[QUOTED] likes this.
  18. Sep 19, 2020 at 6:29 AM
    RallySOP
    RallySOP Well-Known Member
    Tom
    2018 Tacoma OR DCSB
    :rofl::rofl::rofl:
    EDIT: I’m glad I didn’t miss the original post!
    RivetNutBob[QUOTED] likes this.
  19. Sep 19, 2020 at 6:35 AM
    RivetNutBob
    New England
    2017 MGM ORDC MT SB
    I used to get that wrong. Explained to me this way, "the stars lead the charge." Makes sense, easy to remember.
    Wish my avatar was politically correct but the intent is there.
  20. Sep 19, 2020 at 6:40 AM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    You got it!! :thumbsup:
    Passenger:
    Driver:
    honey, TnTHicks, DAS Taco and 10 others like this.
