  1. Jan 3, 2021 at 5:01 PM
    crbr
    crbr Well-Known Member
    east TN
    18 Sport / 93 Mastercraft Prostar 190
    Easy enough to put hot on all six in a fuse box (or breaker box). As s7726 has stated, that will not drain the battery as long as there is no draw on the circuit. If you use a relay, if should fail open when away, thus no draw on the circuit/battery. If you use a switch it should be open/off when away, thus no draw on the circuit/battery. I will suggest a main on/off switch between the battery and the fuse box. Put it in the off (open) position and there will be no chance of drain. You can also use a relay switch that is tied to the ignition run and use that power source as the control for the isolation relay, i.e. when you turn the ignition to off, the relay gets no power and fails open. When you go to ignition run, the relay gets power and fails closed and you have the hot six circuits.
    This is a similar common setup with dual batteries in one machine.
    Hiebster[QUOTED] and rgljr831 like this.
  2. Jan 3, 2021 at 5:02 PM
    DLRIII
    DLRIII Well-Known Member
    David
    Baton Rouge
    2018 Quicksand SR5 DCSB V6
    I'm curious where you end up height wise in the back. I went with the same setup as you except with OME shocks about 2 years ago and it sits basically level, but a little lower in the back when I tow my boat or load it down. Im thinking of trying to find an AAL that will give me some more height or replacing them with a new leaf set.
    rgljr831 likes this.
  3. Jan 3, 2021 at 5:05 PM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    I recommend an RMAS kit if you tow frequently.
    https://activesuspension.com/
    PiryongS, rgljr831 and Jukeboxx13 like this.
  4. Jan 3, 2021 at 5:06 PM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    If this is on the truck battery I would have to ask why. The reason is hot all the time would be better maintained on a separate circuit without the risk of something draining the battery and leaving you stranded. In a perfect world it would not be a problem. This is not a perfect world. The truck's various modules already have parasitic draws on the truck system in ma's so why risk it?
    Just my .0002milicents.
    Zim
  5. Jan 3, 2021 at 5:06 PM
    Round the world
    Round the world Well-Known Member
    Andy
    Home's our Tacoma
    2019 Tacoma AC LB TRD Sport MT
    flatbed with 4WC Fleet with extensive mods
    ^second that thought
    rgljr831[QUOTED] likes this.
  6. Jan 3, 2021 at 5:07 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    I installed one with a breaker and a low voltage disconnect, but for some reason I have a parasitic draw. I'll start pulling fuses to see if the LVD is the culprit, or if it's one of my other accessories.
  7. Jan 3, 2021 at 5:18 PM
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    I have a lil bro lean since the cargo basket and gas. Empty though its level front and back.
    Im saving up for heavy duty dakars since I want to add a cap and rtt. Dakars would be great for towing too.
    DLRIII[QUOTED] and rgljr831 like this.
  8. Jan 3, 2021 at 5:21 PM
    RyanDCLB
    4/19 DCLBOR
    King makes a kit for the front:
    https://downsouthmotorsports.com/i-...ta-tacoma-2wd-pre-runner-4wd-20ab001-103.html
    And for the rear: And now Dirt King makes rear frame plate kit:
    https://dirtkingfabrication.com/collections/tacoma/products/rear-frame-plate-kit-dk-811851
    honey, TnTHicks, awwbugman and 2 others like this.
  9. Jan 3, 2021 at 5:28 PM
    CreekCrawler
    CreekCrawler Well-Known Member
    Erik
    2019 SSM TRD Sport
    Took her for a Sunday afternoon drive on some backroads...and got a little muddy.
    DDB8FC5F-B580-4EC2-81D7-A0D1C35AEB8E.jpg AEDA97E5-F6D6-4787-8C6B-CB3D769E1440.jpg
  10. Jan 3, 2021 at 5:28 PM
    rgljr831
    rgljr831 The less you bet, the more you lose when you win
    Ron
    Monterey/Pacific Grove
    2021 TRD Off Road 4x4 DCSB Not_Silver Bullet
    285/75/r16 Nitto Trail Grappler M/T’s, Extang 2.0 hard tonneau tri-fold. Billstein 5100’s front/rear with OME 886 coils and Headstrong off-road 3 leaf progressive AAL. All speakers replaced with Kicker CS Series. BulletPoint Taco Bar with stubby CB mic holder and two-way FRS/GMRS radio holder. Uniden PRO505XL 40 ch CB. RCI engine and transmission skid plates. RCI sliders. Garmin Mini Dash Cam 2. CMC by Milogen Fabrication.
    Nice setup. Is that a shim or spacer between the leafs and axle?
  11. Jan 3, 2021 at 5:31 PM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
  12. Jan 3, 2021 at 5:33 PM
    dleonard1122
    dleonard1122 Well-Known Member
    New Jersey
    2020 Cement SR5 Tacoma DCSB 4x4 2021 RAV4 Hybrid
    I really like this, how much did it cost you?
    Only thing I'd be concerned with is light output on the backup lights. Based on crashnburn's testing, LED replacements don't usually work well in halogen housings.
  13. Jan 3, 2021 at 5:33 PM
    RyanDCLB
    4/19 DCLBOR
    Ya, it's like landing on an air cushion compared to a piece of hard rubber. :notsure:
    Round the world and rgljr831 like this.
  14. Jan 3, 2021 at 5:34 PM
    Puppypunter
    Johnny
    2019 Black SR
    Cool, that makes sense. Thanks!
  15. Jan 3, 2021 at 5:36 PM
    DLRIII
    David
    Baton Rouge
    Thanks, ill consider that as well. I just want to get factory rake back
  16. Jan 3, 2021 at 5:37 PM
    Sand Dog
    Sand Dog Well-Known Member
    2018 SR, 4x4 DCSB MGM
    Thank you sir and thank you for your service.
    Tacman19[QUOTED] and rgljr831 like this.
  17. Jan 3, 2021 at 5:46 PM
    Grainger
    Grainger Member
    2019 Silver Tacoma Trd Sport & 1998 Tacoma SRT 2WD MT
    None yet
    I may be wrong but I thought his thread focused on headlamps. The reverse lights are insanely bright. Much brighter than the incandescents.
    This is the link I used. https://tacomabeast.com/products/tail-light-stage-1-conversion-kit
    I like amber turn signals because they are safer. I also prefer LED lights on signals, brake, etc.
    Rodchester and rgljr831 like this.
  18. Jan 3, 2021 at 5:47 PM
    oostroma
    oostroma (Boomer)
    Ontario
    Fyi, the RMAS system is adjustable so if you get a bigger boat you can can increase the spring tension accordingly.
  19. Jan 3, 2021 at 5:49 PM
    Mobi42
    Mobi42 Well-Known Member
    Rod
    2016 White Tacoma TRD Sport Access Cab 6MT
    Unit in freight, delivery from San Antonio ~April 8th
    I have that exact set up and did add relays and switches for each. So far it works, but I’ll be adding timers to each that will shut off power to the load in the even each or any is left on longer than 60 minutes, this is especially important for the bed lights if switched on by accident during the day light.
    edit here is a link to the timers I will be adding to each circuit.
  20. Jan 3, 2021 at 5:53 PM
    Tacman19
    Dave
    Mid Missouri
    19 Tacoma SOLD
    First question is if you disconnect the battery from the fuse box, how will the security module work? Remote start, key fobs, gps and heaven knows what else. You going to flip this switch each time you go to the truck?
    Zim
