  1. Jan 10, 2021 at 7:32 AM
    LawTaco
    LawTaco Well-Known Member
    Lawrence
    Bay Park,San Diego,Ca
    TRD SPORT 24
    Thanks. No lift 265 7017 ko2s. Install fairly simple just watch a couple of YouTube videos.
    rgljr831 and Tacospike like this.
  2. Jan 10, 2021 at 7:33 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    The brackets have 2 pieces. One piece bolts to your bedrack. The other piece bolts to your bedrail. And then those two pieces get bolted together.
    Here is the regular bracket:
    The BAK specific one:
    Sorry this one is a little blurry. The BAK one is a little touchy to maneuver but it can be done. The BAK cover relocates the bed rails and this bracket makes up for it.
    I have a hoist setup in my garage so taking it off and putting it back on are super quick and easy. Just 4 bolts. Otherwise, you and a buddy can do it manually. Its about 180 pounds with the rack and the tent.
    TnTHicks and rgljr831 like this.
  3. Jan 10, 2021 at 7:41 AM
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    A nice option to have!
    rgljr831 likes this.
  4. Jan 10, 2021 at 7:47 AM
    Interbeing
    Austin, TX
    About an inch of rake unloaded, about where I was stock. Once the weather gets better I am going to load it up and see what I have.
    rblalliance, boston23, RCrumb and 9 others like this.
  5. Jan 10, 2021 at 7:48 AM
    JB83
    JB83 Well-Known Member
    Jacob
    Louisiana
    2018 Tacoma TSS OffRoad
    Not today, but yesterday I installed fog lights and took off my chin strap! Looks good if I do say so myself.
    3A40EB6E-6C79-4187-A052-BBE929932174.jpg 029CA7BF-CD8C-4D1F-B28B-33AA0968634E.jpg
    rblalliance, boston23, Burns and 21 others like this.
  6. Jan 10, 2021 at 7:50 AM
    MtRainier
    MtRainier Well-Known Member
    Randy
    Seattle, WA
    2021 Super White TRD Off-Road 4X4
    Installed my relentless fabrication quick fist brackets and rear bed rail. Tonneau cover comes in this week so until then I only mounted the axe for the picture and won’t put any toys in the back until it’s installed. 72DBDE74-6A4C-4AD1-B804-5490A907EF63.jpg
  7. Jan 10, 2021 at 7:53 AM
    rgljr831
    rgljr831 The less you bet, the more you lose when you win
    Ron
    Monterey/Pacific Grove
    2021 TRD Off Road 4x4 DCSB Not_Silver Bullet
    285/75/r16 Nitto Trail Grappler M/T’s, Extang 2.0 hard tonneau tri-fold. Billstein 5100’s front/rear with OME 886 coils and Headstrong off-road 3 leaf progressive AAL. All speakers replaced with Kicker CS Series. BulletPoint Taco Bar with stubby CB mic holder and two-way FRS/GMRS radio holder. Uniden PRO505XL 40 ch CB. RCI engine and transmission skid plates. RCI sliders. Garmin Mini Dash Cam 2. CMC by Milogen Fabrication.
    I’m going to go the same route with the Headstrong 3leaf AAL. I had this on my ‘17 AC and left the overload leafs in because of the weight of the shell. Nice and level with Billstein 5100’s front and rear and 887 OME coils up front. What are you running up front? Did you remove the overload leafs? Thanks. Truck looks great BTW! :cheers:
  8. Jan 10, 2021 at 7:56 AM
    rgljr831
    Ron
    Much better without the chin strap! :thumbsup: One of the first things I did on my ‘17 SR5 AC. Looked like a buck toothed shark from the side. :rofl:
    Mobi42 and JB83[QUOTED] like this.
  9. Jan 10, 2021 at 7:59 AM
    rgljr831
    Ron
    Got the same brackets after I got my tonneau cover. Nice to be able to keep the bed floor cleared for other gear! :thumbsup:
  10. Jan 10, 2021 at 8:11 AM
    Interbeing
    Austin, TX
    I have the TRD Pro Fox suspension installed with a 1/4" spacer. I removed the stock overload springs as I wanted to try to maintain a fairly comfortable ride unloaded, and I also didn't want a big lift. I have about 175lbs of amor and I carry about 50lbs of gear in the bed regularly. When I am loaded with my camping gear and bikes it adds about another 150lbs. Prior to putting the AAL in I was pretty much level empty, and a slight bro lean with my regular gear in the truck. Once loaded up I dropped another 1/4", and was about 1/2" lower in the back than the front. Not too noticeable, but enough to bother me, thus the AAL. I chose Headstrong because it doesn't require any cutting, in case I wanted to remove them in the future. A nice little touch also it that the hangers for the brake lines can be reattached to the clip like stock. Time will tell how much sag I get over time.
    rgljr831[QUOTED] likes this.
  11. Jan 10, 2021 at 8:13 AM
    Grumpy Jesse
    Grumpy Jesse Well-Known Member
    Jesse
    Portland
    2018 Taco That Used To Be A Pro
    '18 Tacoma Dobinsons MRR front with UCA's CMC and plenty smashing in the of the tub Rear #600 leafs U-bolt Flip Can Clam 35's Custom Front High Clearance Bumper w/cheap LED's Air and Dual battery built by yours truly '85 pickup 60 and a 14B swap full width (on leafs) Fully hydro Dual T Case H1's re-centered with inner bead lock Cheap e30 Seats Flat Bed
    Yes sir.
  12. Jan 10, 2021 at 8:24 AM
    Tacospike
    Two Trucks
  13. Jan 10, 2021 at 8:36 AM
    rgljr831
    Ron
    Thanks man! I would prefer to keep a slight rake as well since it’s already hard enough to see over the hood when approaching a crest. Plus since I recently installed LED headlight bulbs I definitely don’t want the bro lean which would just lead to all oncoming traffic flashing their high beams at me. o_O This was an issue when I got my shell on the ‘17. The three leaf with the overload leafs worked out perfectly.
    Before:
    After:
    I appreciate the info! Just want a mild lift and your setup looks awesome! :thumbsup:
  14. Jan 10, 2021 at 8:50 AM
    johnnyroid
    johnnyroid Well-Known Member
    Vine Grove (Fort Knox) Kentucky
    2017 Black Tacoma Sport TRD
    What is this witchcraft?
    honey likes this.
  15. Jan 10, 2021 at 8:50 AM
    Interbeing
    Austin, TX
    Yes, your truck looks much better with the AAL, I like your wheels and tires too.
  16. Jan 10, 2021 at 8:51 AM
    johnnyroid
    Based.
    71tattooguy and honey like this.
  17. Jan 10, 2021 at 8:57 AM
    rgljr831
    Ron
    Thanks! The after picture was after I traded up for the 2021. Starting all over. :D
    Interbeing[QUOTED] likes this.
  18. Jan 10, 2021 at 9:05 AM
    JB83
    Jacob
    Louisiana
    What’s crazy is my mpg actually went up without it too!
  19. Jan 10, 2021 at 9:09 AM
    rgljr831
    Ron
    I didn’t lose anything either as far as mileage goes. It was just begging to be ripped off on a trail! :rofl:
  20. Jan 10, 2021 at 9:10 AM
    TVphotog97
    TVphotog97 Well-Known Member
    Codie
    Upstate South Carolina
    2019 White Tacoma SR5
    So far I really like it. Gives a little more pad and keeps me from wearing out the oem material. Only concern I'd have with your dog would be his nails possibly snagging in the fabric, but these covers are inexpensive so it wouldn't be a big deal to replace them if that were to happen.
    Afilao[QUOTED] and rgljr831 like this.
