  1. Jan 29, 2021 at 9:21 PM
    Goatfrog
    Goatfrog Well-Known Member
    Bill
    Pittsburgh, PA
    2020 Red DCLB TRD Off Road
    I was actually considering buying one of these but am on the fence still. Is your button seated all the way? Guess I better make up my mind by tomorrow as that is the last day for the TacoGarage group buy on these buttons.
  2. Jan 29, 2021 at 9:27 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Took some more precise measurements prior to 3leaf install. Wish I did this prior to Installing the truck cap so I knew what factory rake was
    center hub to fender. Check out that 3/8” taco lean on an Empty (15 mile to) gas tank. I’m still stock suspension- would that 1/4” driver side top plate spacer work for me?
    3C041827-AFDB-4F79-A194-32247508B029.jpg E00F2CB3-6ADC-4FBC-A48E-7F98BB60DD73.jpg
    TnTHicks and rgljr831 like this.
  3. Jan 29, 2021 at 9:44 PM
    rgljr831
    rgljr831 The less you bet, the more you lose when you win
    Ron
    Monterey/Pacific Grove
    2021 TRD Off Road 4x4 DCSB Not_Silver Bullet
    285/75/r16 Nitto Trail Grappler M/T’s, Extang 2.0 hard tonneau tri-fold. Billstein 5100’s front/rear with OME 886 coils and Headstrong off-road 3 leaf progressive AAL. All speakers replaced with Kicker CS Series. BulletPoint Taco Bar with stubby CB mic holder and two-way FRS/GMRS radio holder. Uniden PRO505XL 40 ch CB. RCI engine and transmission skid plates. RCI sliders. Garmin Mini Dash Cam 2. CMC by Milogen Fabrication.
    Thanks for the info. I remember torquing the u-bolts to 80ft lbs on my ‘17 (also from Headstrong). Yeah I don’t understand how know one else has had this issue either. Hope you’re able to either find the longer u-bolts like the stock ones or get the sumo springs notched so you can complete the install. Looking forward to seeing the end result with or without the sumo springs. :cheers:
  4. Jan 29, 2021 at 9:55 PM
    rgljr831
    Ron
    Think it would. That’s what I’ve seen used a lot here. Probably won’t be able to get equal measurements on both sides but should definitely be closer and no lean to the naked eye.
  5. Jan 29, 2021 at 10:04 PM
    baldbeardedtaco
    FL
    Most of the posts I seen (without paying much attention at the time) were that they were used when replacing the suspension because correct me if I read it wrong but factory accounts for this so driver and passenger sides aren’t the same. But with aftermarket they are the same so the spacer equalizes it.
    Trying to recall it the 1/4” spacer gets I think 1/2” result. And lifting the driver will lower the passenger rear. That 1/2” would be good for me when you add a full tank then it may be dead on. I can definitely tell the lean, not bad, but I notice it. But does adding the spacer up front require alignment?
    rgljr831[QUOTED] likes this.
  6. Jan 29, 2021 at 10:24 PM
    rgljr831
    Ron
    The following thread has some good information about stock vs. aftermarket (lifted) suspension. Hopefully it provides some clarification.
    https://www.tacomaworld.com/threads/question-regarding-taco-lean-spacer.199325/
  7. Jan 29, 2021 at 10:37 PM
    ixnay
    ixnay Well-Known Member
    Mark
    Portland, Oregon
    I used to write the answer and then the question (Jeopardy style) on the chalkboard at the beginning of class. I'd erase it 2 or 3 minutes in. It would show up on the exam, often as extra credit. And I would have mentioned it during the term, but it was all esoteric stuff, interesting tidbits, barely-more-than-trivia. I warned the class the first day. Those who took notes did fine. It paid to attend class and not be tardy.
    One day, after a particular(ly hard) mid-term, I grabbed my flak vest and my K-pot and wore them to class. Someone snapped my photo.
  8. Jan 29, 2021 at 10:57 PM
    baldbeardedtaco
    FL
    I just read that after my post. The alignment question i had is a yes but everyone mentions 1/2” lift but no mention that it lift the opposite rear too. Before I get completely off track here, I should stay focused at the current task (aal/sumo), let it settle and take my measurements on all 4 corners and go from there. I have a huge problem jumping around. I have so many projects going on and none of them done (house, truck, personal etc) I can’t focus on just 1 always getting sidetracked just like this
    rgljr831[QUOTED] and 907rx7 like this.
  9. Jan 29, 2021 at 11:15 PM
    18Tacos
    18Tacos Well-Known Member
    New Port Richey, Florida
    18’ Tacoma SR5 DCSB Silver Sky
    3” lift, 265/70/16 Wildpeak ATs on stock dipped SR5 wheels (for now). Meso stuff (puddle pods, Gasshole, stage 1 taillights) Pro grille, 5% tint, some other stuff
    15 on a good day
    Thunder Fist and rgljr831 like this.
  10. Jan 29, 2021 at 11:18 PM
    SoCalSport
    SoCalSport Well-Known Member
    Inland Empire, So Cal
    2020 Super White TRD SPORT
    They sound great, I definitely hear an improvement in the high notes.
  11. Jan 29, 2021 at 11:49 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    KTJO bowl lights (all 4 doors) and the passenger one touch (required for the rear windows only).
    All 4 bowl lights are in, and the rear passenger one touch switch modules are in. I didn't realize that my front passsnger window switch was already one touch (duh), so I have an extra, but no worries, I'll install it on a buddies truck (I only needed two of them, but ordered 3 by accident. Check your front passenger window switch for one touch before ordering). All were installed without removing the door panels by "fishing" the wires (be patient and careful with the small wires). Wow, what a difference! :eek::thumbsup: BTW, the Ice Blue bowl lights seems to match OEM perfect. 1.5 hr. total install.
    Passenger window one touch modules:
  12. Jan 30, 2021 at 1:11 AM
    RyanDCLB
    4/19 DCLBOR
    KTJO Rear Windshield One Touch:
    Not trying to be a fanboy, but, after using this post for the connector, the one touch rear winshield switch took about 15 minutes to install. No more taking my eyes off the road to find (and hold) the rear window switch... :eek: It works awesome. :thumbsup: Thank you for the picture @WaitingOnMyR1T , and * who shall not be mentioned for making the part.
  13. Jan 30, 2021 at 2:48 AM
    Jhoisi
    Jhoisi Well-Known Member
    St. Petersburg, FL
    2021 TRD Pro
    Yesterday! This was interesting- I bought my my TRD Pro 3 months ago and have about a touch over 3000 miles now with my stock wranglers. I had a ever so slight steering wheel off center to the right didn’t bother me to much and it seemed to drive straight no pull etc... so last weekend put the new 285’s FW AT3W on and have put about 400 miles this week to see how the truck is riding with new the tires. So now I have noticed a definite steering wheel off center and a slight pull with the more aggressive tire. Called the dealership told them what was happening and they told me to bring it in for a alignment check. FYI my dealership told me for the first year or 12,000 miles if for some reason you think your alignment is off or you have a tire balancing issue it’s pretty much no questions asked and they do it. So, this was what my alignment was and now. Interesting to me how trucks come from the factory brand spanking new and the alignment was off like this.
    So with that I add, if you recently purchased a new truck with or without adding new tires take your truck in and have them do a alignment for piece of mind.
    Mine drives so much better now and I had no idea it was off.....
    TnTHicks, jeejay, oostroma and 5 others like this.
  14. Jan 30, 2021 at 5:48 AM
    savin yours
    savin yours Well-Known Member
    Bryan
    SE Tx
    2018 TRD Off Road
    Mounted my 95L Roam Adventure box on the Prinsu, that I got from @Truck Brigade
  15. Jan 30, 2021 at 6:13 AM
    RallySOP
    RallySOP Well-Known Member
    Tom
    2018 Tacoma OR DCSB
    Amen brotha! Yesterday, I pulled my kick panel to work on some wiring. When I did, a small coil of white 16 awg fell out. It was run from the back of the cab and had yellow heat shrink at the tip.
    I ran this for a reason, and marked it in yellow for a reason. I could not find where it lead to and for the life of me, I can’t remember what it’s for.
  16. Jan 30, 2021 at 6:35 AM
    playdixie
    playdixie Miss'ippi fella
    Mississippi
    2019 Cavalry Blue TRD Sport 4WD
    Thanks! I bit the bullet and ordered some. Now to just impatiently wait for them to get here next week on a day I have to work :rofl:
    AZ_SIMBA[QUOTED] and rgljr831 like this.
  17. Jan 30, 2021 at 6:48 AM
    playdixie
    Mississippi
    Yeah I don't get that. But since they are going thru Amazon, that is probably why it's more expensive -- user fees.
    rgljr831 likes this.
  18. Jan 30, 2021 at 6:56 AM
    playdixie
    Mississippi
    Since it's in my signature line, decided to add a little flair for the new Mississippi flag to the truck:
    20210129_150408.jpg 20210129_151051.jpg 20210129_150509.jpg 20210129_162716.jpg
    (The light bar covers the front plate, but easily goes back in place.)
    wrekd619, boston23, TnTHicks and 14 others like this.
  19. Jan 30, 2021 at 7:14 AM
    SJBrown
    SJBrown Well-Known Member
    2019 Bearded SR AC 4x4
    Y'all's new flag is good looking.
  20. Jan 30, 2021 at 7:50 AM
    KWyle
    KWyle Member
    2021 Tacoma MGM DCSB TRD Sport w/black leather
    Interior Black Leather Seats TRD PERFORMANCE EXHAUST SYSTEM (BLACK) Kicker DS Series 6"x9" 3-way car speakers Kicker DS Series 6-3/4" 2-way car speakers 35% LLumar CTX Ceramic window films - all doors Bilstein B8 5100 (RIDE HEIGHT ADJUSTABLE) - Front SHOCK ABSORBER TRD 17-In. Matte Black - Alloy Wheel De-badged Extang truck bed cover TRD skid plate TRD Pro grill N-fab EPYX Step Systems
    5100’s Bilstein Front today, Stock Hitachi Rear
    13txtaco, boston23, TnTHicks and 15 others like this.
