  1. Feb 11, 2021 at 4:45 AM
    LawTaco
    LawTaco Well-Known Member
    Lawrence
    Bay Park,San Diego,Ca
    TRD SPORT 24
  2. Feb 11, 2021 at 5:00 AM
    johnnyroid
    johnnyroid Well-Known Member
    Vine Grove (Fort Knox) Kentucky
    2017 Black Tacoma Sport TRD
    I have no idea who wrote it, I didn't smell it, and I didn't write it. Disclaimers complete. :D
  3. Feb 11, 2021 at 5:16 AM
    MiTacoTRD
    MiTacoTRD Well-Known Member
    N. Idaho
    2019 Tacoma TRD Off-Road DCSB
    ^^^This. They make em for MT as well.
  4. Feb 11, 2021 at 5:27 AM
    johnnyroid
    I found them here somewhere awhile back, but for the life of me can't find the post, so sorry about that. If I run across it, I will def share, maybe somebody else knows. They have held up quite well, no curling or unsticking.
    rgljr831 likes this.
  5. Feb 11, 2021 at 5:37 AM
    Ghostrider52
    Ghostrider52 Well-Known Member
    Nick
    Tampa, FL
    2020 Toyota Tacoma TRD Off-Road AV4
    6” Zone Suspension Lift 20” Fuel Rebel Wheels 305/55r20 Falken Wildpeak AT3W Tires
    I've been looking into these, how do you like the ride? Have you adjusted all the way down/up to see how the adjustment(s) feel? Curious as they are a better budget option to get both front and rear for the same price as a fox or kings. You offroad much? Curious how they handle those situations as well.
    gman2431 and rgljr831 like this.
  6. Feb 11, 2021 at 5:52 AM
    johnnyroid
    It doesn't stick as well as I would like, but what I found is that there are two different grades of velcro. The newer smaller velcro does not stick as well as the older, rougher stuff. I placed it then used my knuckles and rolled around on it real good, which seemed to work. Every once in awhile, one will get loose and I need to repressure it, but that doesn't happen very often.
  7. Feb 11, 2021 at 5:54 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Cali raised
  8. Feb 11, 2021 at 5:55 AM
    18Tacos
    18Tacos Well-Known Member
    New Port Richey, Florida
    18’ Tacoma SR5 DCSB Silver Sky
    3” lift, 265/70/16 Wildpeak ATs on stock dipped SR5 wheels (for now). Meso stuff (puddle pods, Gasshole, stage 1 taillights) Pro grille, 5% tint, some other stuff
    rgljr831 and TRDTaco420[QUOTED] like this.
  9. Feb 11, 2021 at 6:00 AM
    18Tacos
    I put 3M grip tape over the word Tyger on mine. Blends pretty well
  10. Feb 11, 2021 at 6:05 AM
    EGBTER
    EGBTER Well-Known Member
    Wayne
    Denver CO
    2016 TRD SPORT
    I just pulled those off. Came off easy by I just starting one end with a flathead.
    ReelAddict[QUOTED] and rgljr831 like this.
  11. Feb 11, 2021 at 6:10 AM
    philliam1
    philliam1 Well-Known Member
    Phillip
    Kennesaw Ga
    2022 Super White Tacoma SR5
    Do you use a pompous stone? I learned that little trick working in a detail shop. It is a life saver because this guy loves car rides and leaving his hair everywhere on the inside...
  12. Feb 11, 2021 at 6:30 AM
    Tacospike
    Two Trucks
    You made your truck happy I see o_O
    gman2431, Shayne, TnTHicks and 7 others like this.
  13. Feb 11, 2021 at 6:52 AM
    ReelAddict
    ReelAddict Well-Known Member
    Rob
    Lynnwood, Washington
    2018 TACOMA TRD OFF-ROAD DBL CAB
    SUSPENSION: Bilstein B8 6112 Off-Road Suspension Kit - 47-234413 (5/4 Setting) Bilstein 600lb Front Coils Bilstein 5160 Series Shock - w/0" to 1.5" Rear Suspension Lift SPC Adjustable Upper Control Arms (SPC 25470) Wheelers Off-Road Multi-Leaf Add-A-Leaf Set - 1.5" Lift 3 Leaf Progressive Wheeler's Front Superbump Set Wheeler's Rear SuperBump Bumpstop Set Tacoma 2005-2020 Toyota 4WD - Carrier Bearing Shim Kit by Old Man Emu 2016-2020 Toyota Tacoma 4x4 (2"- 6" lift) Front Differential Drop Kit by Revtek Front Strut Mounting Kit KYB SM5640 WHEELS & TIRES: Venomrex 602 17" X 9" -12 Offset Coal Black Venomrex Red Center Cap Inlay NITTO Ridge Grappler All-Season Radial Tire-LT285/70R17 C Rated Cab Mount Chop PERFORMACE: Toyota OEM Intake Flow Accelerator Mod Toyota OEM TRD Air Filter MBRP Cat-Back Exhaust System Single Side Exit 3" Black Series Toyota TSB Software Update (Transmission) KDMAX Performance Tune LIGHTING: AUXITO H11 LED Headlight Bulbs 80W 16,000LM (High & Low Beam) Complete Interior LED Lighting Kit (Xenon White) NAKOBO White 29mm Festoon Led Bulb (Vanity Mirrors) XSPEED 7440 7441 T20 LED Light Bulbs XSPEED 921 912 906 W16W T15 LED Light Bulbs XSPEED 7443 7440 7444NA W21W T20 LED Light Bulbs CaliRaised Side Shooter Ditch Lights R4T Smoked White Grille Lights Meso Customs Ultimate Turn Signal CaliRaised LED 18W Slim Flood Work Lights (Roof Rack) DV8 Offroad BS20E100W5W BS-20 20" SL8 Slim Series LED Light Bar iJDMTOY Yellow Fog Lights CaliRaised LED 18W Slim Flood Work Lights (Bed Rack) STYLING & ACCESSORIES: TRD Pro Grille W/ OEM Garnish Sensor Cover N-Fab Textured Black Nerf Steps Coverking Neosupreme Seat Covers Full Front and Half Hood CHIPPROTECT by IDENS 30% Front Window Tint Toyota OEM TRD Skid Plate Toyota OEM Bed Mat Toyota OEM Bed Cleats Toyota OEM Door Sill Protectors Toyota OEM All-Weather Floor Mats Toyota OEM Blackout Emblem Overlay Kit Matte Black TRD Off-Road Decals Bed Net Organizer Storage Box Center Console Organizer EGR Matte Black In-Channel Vent Visors TAC Fender Flares Sprayed W/Line-X Smittybilt Smart Cover Tonneau Cover AJT Key Fob CaliRaised Low Profile Ditch Light Brackets BFP Heavy Duty Recovery Tow Hook (Painted In Super Red 2) TufSkinz Red Glove Box Insert Center Console Armrest Cover Cup and Console Liners 7" Screen Protector R4T Off-Road Badges Prinsu Design Cabrack Anti Glare Hood Vinyl Custom Rocker Panel Vinyl Mountain Graphics TacoVinyl Pro Grill Decal Pelican Vault V770 Case (2) Blacked Out Side Mirrors X-Bull Traction Board's DV8 Toyota Tacoma Center Mount Winch Capable Front Bumper OEdRo D Ring Shackles Mountain Hatch Tailgate Insert (Red) Toyota OEM Tailgate Power Lock Custom Tailgate Vinyl by IDENS Kentro License Plate Holder AJT Steering Wheel Overlay (Red) AJT Cup Holder Ring (Red) Meso Custom Door Handle Covers Prinsu Ridgeline Handles All-Pro Off-Road Bed Stiffeners Rek Gen Mud Flaps (Red Lettering) Original Quick Fists (2) 3" Quick Fist (2) RotopaX RX-DLX-PM Deluxe Pack Mount (2) RotopaX RX-1.75G Gasoline Pack RotopaX RX-2G Storage Pack First Alert Fire Extinguisher Bond LH043 Red Fiberglass Shovel Gzila Awning Mount Thule 4.5' Overcast Awning CaliRaised DItch Lights Switch CaliRaised Zombie Lights Switch Nexar NEXS1 Smart Dash Cam Ironman 4x4 Fridge Slide Frontrunner RTT Quick Release Mounts Thule X Tepui Explorer Kukenam 3 Yakima Roadshower 7G Havoc Off-Road Running Boards JoyTutus Portable Car 42 Quart Refrigerator
    Nice! That's good to know. My buddy just bought a couple of them and hates the orange strip also. I'll tell him to pull them off. Thanks man:thumbsup:
    rgljr831 and EGBTER[QUOTED] like this.
  14. Feb 11, 2021 at 6:55 AM
    Shippe
    Shippe Well-Known Member
    Isaiah
    Idaho
    2020 MGM Tacoma TRD Off-Road / 2014 BW Corolla S
    Sorry about the truck and glad you’re okay. You could just trim the exhaust back for higher clearance and then it wound be noticeable.
  15. Feb 11, 2021 at 7:02 AM
    Ncousins1
    Ncousins1 Well-Known Member
    Niko
    Gainesville, FL
    2023 Solar Octane TRD Pro Tacoma
    Love those wheels!
  16. Feb 11, 2021 at 7:13 AM
    cbner
    cbner Well-Known Member
    2018 Tacoma trd sport
    Thanks to this guy I went to Walmart, Home Depot, home hardware, Rona, Michael’s, Kent and still couldn’t find any yellow stained glass spray. Online it is.
    Shayne and rgljr831 like this.
  17. Feb 11, 2021 at 7:17 AM
    igod69m
    igod69m Where do squirrels go during hurricanes?
    Wyoming
    2019 TRD OR Cement Gray Taco
    K&N COI, OV tuned, UpTop overland Alpha rack, backflip tonneau cover, rough country full bed molle system, cut in storage drivers side bed-added airline port inside, pro shift knob, meso customs interior cement kit, meso interior led lighting, meso pro shifter button mod, meso push start, meso mirror intermediate smoke turn signals, meso headlight trim, rigid diffused fog lights and brackets, rigid ditch lights, morimoto Low beam HID kit, morimoto license plate housing and lights,(4) Baja Designs rock lights on Alpha rack, meso pods for BD lighting, switch-pros 9100, extremeLED 38” s6x Amber/white light bar, extremeLED single 30” light bar, magnaflow cat back exhaust, level kit, front camera with switch, pop lock tailgate, 17” fuel trophy D551 wheels, AT3LS tires 265/70R17, Caliraised step sliders, ARB twin compressor, ARB 1 gallon air tank, M.O.R.E bracket for air tank/compressor, powertays holding blue seas fuse block/bussbar/switch pros, Fab Fours slimline bumper, custom TacoVinyl grill, eezi awn 2000 1.5 sepoia, UpTop awning mount, ARB recovery point, Cascadia 4x4 85 watt hood solar panel, RDJ smooth lineX fender flares, Nextbase 622GW dash cam,
    Perfect lighting
    LawTaco[QUOTED] likes this.
  18. Feb 11, 2021 at 7:17 AM
    igod69m
    Wyoming
    Not a bad price at all
  19. Feb 11, 2021 at 7:20 AM
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    What's a boot goofin ?
    flatus likes this.
  20. Feb 11, 2021 at 7:22 AM
    devale
    devale Well-Known Member
    sorry to be that guy but pumice*
    Jeff Dartfrog likes this.
