  1. Feb 12, 2021 at 11:42 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Ya, that's a nice power outlet, but I'm not sure about the light surround. Although, it is pretty cool that it goes from red to blue when charging is complete. You might consider this one to fit the center switch panels. I'm not confident the other one will fit.
    For the A/T shift window (which IMO provides the most glare), I went with this in flat black.
    rgljr831 likes this.
  2. Feb 12, 2021 at 11:50 AM
    DVCSam
    DVCSam Member
    2021 TRD Off Road DCLB - Barcelona Red
    I'm very surprised that it would work with the truck not running, since the outlet only supplies 100W in that case, and I would think that the vacuum cleaner would draw more than that. However, I'm fine with using it with the engine running so that the outlet is in the 400W mode.
    Yes, I saw that video sometime back, and it is quite interesting what you can and cannot operate from the outlet.
    Thanks for the response.
  3. Feb 12, 2021 at 12:55 PM
    MoseyTRD
    MoseyTRD Member
    Elon, NC
    2019 Cavalry Blue Tacoma TRD Sport
    it does not. I was afraid it would but my fears were exaggerated.
    rgljr831 and SirShaggy like this.
  4. Feb 12, 2021 at 12:58 PM
    MoseyTRD
    MoseyTRD Member
    Elon, NC
    Thanks! I got 2 of them. that one is a 71 that hasnt run in years. Its more of a parts Bronco than anything now. I have another 76 which Im in the middle of tearing down and rebuilding from the frame up.
    rgljr831[QUOTED] likes this.
  5. Feb 12, 2021 at 1:15 PM
    mmblue4x
    mmblue4x Well-Known Member
    '19 TRDOR
    did OEM TPS work? I watched a set on eBay and they just emailed a discount...I assume you ordered black lug nuts too. Mag type, not conical? And thanks, company is not taking phone calls right now. These are great looking.
  6. Feb 12, 2021 at 1:30 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
  7. Feb 12, 2021 at 1:31 PM
    Kenstogie
    Kenstogie Well-Known Member
    Ken
    19 SR 2.7 4x4
    I like the idea of the lighted rim and voltage indicator but I like the idea of clean factory looking install more so I my end up using that one you've recommended thanks! And maybe the shifter vinyl if mine doesn't work as well as I'd like..
  8. Feb 12, 2021 at 1:40 PM
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    They can be left open, but they would be "loose". When they are closed they have a latch system that installs.
    With it in the latched position, it opens from inside the bed (not the bedside).
  9. Feb 12, 2021 at 1:43 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Got the leaking axle rebooted and installed. The tulip was on there good as it took me three hours with a hammer, a punch, some penetrating fluid, and a torch to finally get it off. Never once did it let loose until it was completely removed.
    Also adjusted the coilovers back down to about 1” of lift to keep from topping them out on fast off road stuff. Makes me want to add limit straps in the future.
    Got a JLT catch can kit too in the hopes that I don’t hydrolock my engine at steep angles. Cheap insurance that may or may not work :notsure:
    don74, xxTacocaTxx, TnTHicks and 10 others like this.
  10. Feb 12, 2021 at 1:44 PM
    SirShaggy
    SirShaggy Member
    Dakota
    California
    2021 Cement Tacoma TRD Off-Road 4x4 Manual
    Nothing yet :(
    I have a tire/wheel warranty where as long as my tire is not bald, and wheel is not destroyed then Toyota will replace my tire/wheel FREE if any damage were to come of it.
    Better example, I could’ve gotten a nail in my tire the day after I drove it off the lot, and instead of patching the tire they would just give me a brand new tire free!! But it’s the same tire I get back (Goodyear Wrangler Kevlar Edition)
  11. Feb 12, 2021 at 2:15 PM
    TWTaco
    TWTaco Well-Known Member
    Dave
    Very nice! Those look great! Now you need a good tune for your truck!:rofl::rofl:
    PapaRee[QUOTED] and rgljr831 like this.
  12. Feb 12, 2021 at 2:30 PM
    igod69m
    igod69m Where do squirrels go during hurricanes?
    Wyoming
    2019 TRD OR Cement Gray Taco
    K&N COI, OV tuned, UpTop overland Alpha rack, backflip tonneau cover, rough country full bed molle system, cut in storage drivers side bed-added airline port inside, pro shift knob, meso customs interior cement kit, meso interior led lighting, meso pro shifter button mod, meso push start, meso mirror intermediate smoke turn signals, meso headlight trim, rigid diffused fog lights and brackets, rigid ditch lights, morimoto Low beam HID kit, morimoto license plate housing and lights,(4) Baja Designs rock lights on Alpha rack, meso pods for BD lighting, switch-pros 9100, extremeLED 38” s6x Amber/white light bar, extremeLED single 30” light bar, magnaflow cat back exhaust, level kit, front camera with switch, pop lock tailgate, 17” fuel trophy D551 wheels, AT3LS tires 265/70R17, Caliraised step sliders, ARB twin compressor, ARB 1 gallon air tank, M.O.R.E bracket for air tank/compressor, powertays holding blue seas fuse block/bussbar/switch pros, Fab Fours slimline bumper, custom TacoVinyl grill, eezi awn 2000 1.5 sepoia, UpTop awning mount, ARB recovery point, Cascadia 4x4 85 watt hood solar panel, RDJ smooth lineX fender flares, Nextbase 622GW dash cam,
    You looked at the meso vent rings?
  13. Feb 12, 2021 at 2:41 PM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Shit, those lights add 5-10hp each!! Can't stop my tires from spinning on take off! LOL
    honey, rgljr831 and playdixie like this.
  14. Feb 12, 2021 at 2:44 PM
    rgljr831
    rgljr831 The less you bet, the more you lose when you win
    Ron
    Monterey/Pacific Grove
    2021 TRD Off Road 4x4 DCSB Not_Silver Bullet
    285/75/r16 Nitto Trail Grappler M/T’s, Extang 2.0 hard tonneau tri-fold. Billstein 5100’s front/rear with OME 886 coils and Headstrong off-road 3 leaf progressive AAL. All speakers replaced with Kicker CS Series. BulletPoint Taco Bar with stubby CB mic holder and two-way FRS/GMRS radio holder. Uniden PRO505XL 40 ch CB. RCI engine and transmission skid plates. RCI sliders. Garmin Mini Dash Cam 2. CMC by Milogen Fabrication.
    Finally got the lift in. Will try to get better pics after work or tomorrow. Need bigger tires now! :D
  15. Feb 12, 2021 at 2:46 PM
    TWTaco
    Dave
    At least 10hp for sure! Your future is so bright!
    Taco2021LB and rgljr831 like this.
  16. Feb 12, 2021 at 2:50 PM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    What lift? How much lift ... etc
  17. Feb 12, 2021 at 2:58 PM
    rgljr831
    Ron
    Billstein 5100’s front/rear, OME 886 coils in anticipation of the front bumper, and Headstrong off-road 3 leaf progressive AAL. Haven’t measured the end result yet......
  18. Feb 12, 2021 at 3:13 PM
    ryanvar42
    None
    Looks great! How high did you go on the front bilsteins?
  19. Feb 12, 2021 at 3:24 PM
    rgljr831
    Ron
    Thanks! :cheers: They’re set at zero. Always set at zero with any OME coil. The notches are for OEM (factory) coils. :thumbsup:
    gabbo2112 and ryanvar42[QUOTED] like this.
  20. Feb 12, 2021 at 3:50 PM
    Taco2021LB
    Taco2021LB Well-Known Member
    Don
    WA
    2004 DblCab 4x4
    OME 882 Dakars Falken 235/85R16s
    Bling.
    It drains your wallet.
    Yet it doesn't make your ride anymore....willing.
    Like being married!!
    LOLOL
