  1. Feb 18, 2021 at 8:07 PM
    LeFreakyBone
    LeFreakyBone Well-Known Member
    Santa Cruz
    2021 Off-Road Midnight Black Metallic
    Leopard print steering wheel cover
    Installed a TRD skid plate.
    Also installed @MESO ultimate mirror turn signals but didn’t get a photo.
  2. Feb 18, 2021 at 8:11 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Hey, just wanted to mention you may want to check the recommended wheel width on the 33" tires you plan on purchasing. I know for the Toyota ATIII's they had a minimum width of 7.5", but the stock OR wheel is 7" wide :oops:
  3. Feb 18, 2021 at 8:12 PM
    DJFriar
    DJFriar Well-Known Member
    Tommy
    2021 TRD Sport 4x4 MT ACLB in Voodoo Blue
    Window Tint
    Is the black between the windows a Double Cab thing? I was thinking of removing mine and then when I picked up my Access Cab, it didn't come with it anyway.
    rgljr831 likes this.
  4. Feb 18, 2021 at 8:16 PM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
  5. Feb 18, 2021 at 8:24 PM
    rgljr831
    rgljr831 The less you bet, the more you lose when you win
    Ron
    Monterey/Pacific Grove
    2021 TRD Off Road 4x4 DCSB Not_Silver Bullet
    285/75/r16 Nitto Trail Grappler M/T’s, Extang 2.0 hard tonneau tri-fold. Billstein 5100’s front/rear with OME 886 coils and Headstrong off-road 3 leaf progressive AAL. All speakers replaced with Kicker CS Series. BulletPoint Taco Bar with stubby CB mic holder and two-way FRS/GMRS radio holder. Uniden PRO505XL 40 ch CB. RCI engine and transmission skid plates. RCI sliders. Garmin Mini Dash Cam 2. CMC by Milogen Fabrication.
    Actually rethinking this and may go with Methods hub centric wheels. Thanks for the input. Much appreciated! :cheers:
    RyanDCLB[QUOTED] likes this.
  6. Feb 18, 2021 at 8:25 PM
    SoCalSport
    SoCalSport Well-Known Member
    Inland Empire, So Cal
    2020 Super White TRD SPORT
    Its from AL Off Road, the Bare Outfitters/TRAILGATE panel. They had a group buy not too long ago.
  7. Feb 18, 2021 at 8:31 PM
    DLRIII
    DLRIII Well-Known Member
    David
    Baton Rouge
    2018 Quicksand SR5 DCSB V6
    They have a little give but they're hard plastic. Not as rigid as oem though.
    not_tacomike[QUOTED] likes this.
  8. Feb 18, 2021 at 8:32 PM
    lefty9206
    lefty9206 Well-Known Member
    Jarrod
    2021 gray TRD off road
    None yet
    That’s awesome.
    that’s awesome
  9. Feb 18, 2021 at 8:33 PM
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
  10. Feb 18, 2021 at 8:37 PM
    SoCalSport
    Not at all, SUPER easy. I have an aftermarket tailgate panel though. So I didn't even have to loosen any bolts from my panel for the install. I believe if you have the factory tailgate panel you will need to remove/loosen a few bolts to get the tailgate lock installed, but that's easy enough.
    playdixie[QUOTED] likes this.
  11. Feb 18, 2021 at 8:42 PM
    bacon_st
    bacon_st Well-Known Member
    San Diego
    16' Taco TRD sport
    I have two question guys:
    1. Is there any difference between the above two shocks?
    I mean, Yes, I can see that one says, 4WD and the other RWD. But are there any physical differences between them?
    Are there any difference in parts/supplied hardware that comes with these? Can an RWD shock be installed on 4WD? or a 4WD shocks be installed on an RWD?
    2. I know it says 'Requires UCA', but is UCA upgrade required for these shocks, even if I am *not lifting my truck up 3". I am only interested in leveling the truck (1.6" if I am not mistaken).
    Question is, do I still need to buy an AM UCA even if I am not lifting the truck with these shocks?
    (Before somebody tells me why I am not buying the 0~2" inches shock instead of the 0~3" shock, the reason is to avoid the coil spring compression. I don't off-road. I drive on-road 99.99% of the time. I want to tune for comfort.)
    (Recently when a friend got her Fox 0~2", 2.5 shocks, though they were already threaded to give a lift of 1.2" straight from the factory, she had to still compress the springs more to level her truck, thereby resulting in a more stiffer ride. I want to avoid this, so I am buying a 0~3 inch shock to give more room for tuning, less compression)
    rgljr831 and 45longcolt like this.
  12. Feb 18, 2021 at 8:45 PM
    lefty9206
    Jarrod
    None yet
    This is true. I got new wheels so I could get duratracs in a 285/75r16. Bfgoodrich k02’s are 7” wide plus so that is an option.
    rgljr831 and RyanDCLB[QUOTED] like this.
  13. Feb 18, 2021 at 8:49 PM
    Gettin Lost
    Gettin Lost Backwoods Rated
    Florida
    2021 TRDOR
    KDMax tune, eibach stage 2, ceramic tint, DD SS3 PRO fogs. Toyo AT3 285s
    What took longer to install, the fogs or the bakflip?
    My ss3 pros are supposed to be here Saturday. Went with clear color and had combo lenses added to the order. Won't be using them in traffic, going to be offroad/back road lights for me. Wanted more spread... And fog is not a issue for me often.
    Also debating between the bakflip and the gator tonneau covers.... I've had a bakflip g2 (I think) on a past Tacoma but bought it used for a steal.
  14. Feb 18, 2021 at 8:53 PM
    907rx7
    James
    For number 1. Part numbers are the same and there are zero differences between suspension on 3rd gen tacomas afaik.
    Number 2. I think the UCA upgrade is so you can get an alignment within specs if you lift past 2". Past 2 inches you get negative camber that you can't fix without the UCA upgrade I believe.
    I'm not a lift guy, I'm sure someone with more knowledge on the subject can chime in an verify the above.
  15. Feb 18, 2021 at 8:59 PM
    lefty9206
    Jarrod
    None yet
    Tonneau cover took longer. There is just more steps to completing it. I also have long arms so All I had to do was reach inside and installed the lights one handed. Bakflip and gator are made by the same company I went with Bakflip because the panels are thicker and the matte finish holds up better to uv. The mounting hardware is also supposed to be better but I have no way to prove that.
  16. Feb 18, 2021 at 9:01 PM
    rick carpenter
    rick carpenter Well-Known Member
    Rick
    Huntsville, East Texas
    2019 SR5 2wd v6 DCLB for the win!
    Well, crap, but good to know. I was hoping that this could somehow help mitigate against the dash display glare I get on my windows right "above" the mirrors. I always consider the semi-darkness just before dawn and just after dusk to be the worst for visibility. That glare makes it worse. Oh well........
  17. Feb 18, 2021 at 9:08 PM
    lefty9206
    Jarrod
    None yet
    What is the best tailgate lock actuator for 2021 Tacomas? Seems like pop n lock isn’t good anymore?
  18. Feb 18, 2021 at 9:11 PM
    bacon_st
    San Diego
    16' Taco TRD sport
    Who said that? I bought my taco in May 2016, and this was the first mod I did. It still works.
    I thought later models I believe it came from the factory I was told. Maybe I heard wrong.
    Mine still works fine 5 years later everytime I open and lock my truck. I hear that satisfying click.
    Thank you for answering. I'm not a lift guy either. Just want to avoid the front nose dive everytime I step on the brakes, avoid the squat and also level the truck out.
    Getting it tuned for comfort and smooth ride.
    rgljr831 and 907rx7[QUOTED] like this.
  19. Feb 18, 2021 at 9:12 PM
    tedusmc1345
    tedusmc1345 Well-Known Member
    ted
    2018 Tacoma Sport 4x4
    Got 1inch tow rope.
    DAS Taco, TnTHicks, japjoe7 and 8 others like this.
  20. Feb 18, 2021 at 9:12 PM
    TRDTaco420
    TRDTaco420 Chum is Fum
    The Bear
    Tacoville - Canada Eh!
    2019 Mid. Blk. Met. ACLB TRD Off-Road
    Kewl shizz
    Decal on the chrome ring. Next is the steering wheel.
    TnTHicks, markram and SJBrown like this.
