  1. Feb 19, 2021 at 4:54 PM
    JDPNW
    JDPNW Well-Known Member
    S. Oregon
    2021 DCSB TRD OR Cement KDMax-Pro
    Eibach 2.0,SPC UCA,ECGS,ATS 4/1 rear leaf,5.29
    So installed the rek gen's the other day, got the rub at full lock and reverse. First made a 3d printed flush retainer that fit around the bolt head but then ran to the hardware store for cap screw and cut the hose spacer down to 1". That's what I did today other than drive it.
  2. Feb 19, 2021 at 4:58 PM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    ...and the link to this cool retro mod?
    rgljr831 likes this.
  3. Feb 19, 2021 at 5:03 PM
    cyked
    cyked Well-Known Member
    https://www.ebay.com/p/597554419
    To be clear, I added the sound post recording. The linked product does NOT make sounds. It just blinks.
    Also, I may or may not have driven 15 minutes to a friend's place with it on. I pulled the battery earlier that day for about 20 minutes. This thing did turn itself on after reconnecting the battery. Luckily didn't get popped for it.
    rgljr831 and oostroma[QUOTED] like this.
  4. Feb 19, 2021 at 5:12 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    That SX package on Super White really works -- sharp truck :thumbsup: and welcome to TacomaWorld !
  5. Feb 19, 2021 at 5:13 PM
    oostroma
    oostroma (Boomer)
    Ontario
    My spouse said if I did this mod I would have to have sound. This is going to be more complicated than I hoped.
    Bratworx and rgljr831 like this.
  6. Feb 19, 2021 at 5:15 PM
    cyked
    Download the scanning shooshing sound, loop it on a single track, burn it to CD/put on phone. Bam!
  7. Feb 19, 2021 at 5:23 PM
    cyked
    How much is the BAMF part? Couldn't I just just spackle over that and hit it with some paint?
  8. Feb 19, 2021 at 5:26 PM
    LukeTXAG04
    LukeTXAG04 Active Member
    Luke
    Ventura CA
    17 DCSB TRDOR 4X4
    In the last few days, did the 5100’s, OME 887, + Wheelers AAL and drivers side 1/4” top plate spacer. Then added the tall/skinny 255/85/16 Falken MT’s. Doing ECGS bushing as soon as it arrives too. Love the look. Got it aligned but need to go back and see if they can add more caster. Steering is definitely touchy on the highway.
  9. Feb 19, 2021 at 5:28 PM
    My12DCLB
    My12DCLB 21PRO
    Rich
    KS
    White 21 TRD Pro
    Added 3D decals to tailgate and lomax bed cover today. Very happy with both!
    M_McFly6, 13txtaco, japjoe7 and 22 others like this.
  10. Feb 19, 2021 at 5:32 PM
    Afilao
    Afilao Tacoma Driver
    SoCal
    ‘18 MGM DCSB Off-Road 6MT
    A DIY one. Cheap, works just as good, durability depends on which actuator you get but they are like 2 for $10 and many people have had theirs for 3+ years and if you are doing a DIY you can make it less loud than pop n lock or OEM.
    C41n, rgljr831 and tedusmc1345 like this.
  11. Feb 19, 2021 at 5:37 PM
    Cappy
    Cappy Well-Known Member
    Georgia
    I did the same thing. Ran the wires under the truck up through the grommet under the passenger seat then under the dash to the panel on the left side of the steering wheel. Ran power through the fire wall to the battery. Took more time but wanted something a little different.
  12. Feb 19, 2021 at 6:02 PM
    dkemp349
    dkemp349 Well-Known Member
    North Carolina
    2017 Tacoma TRD Sport
    Installed OME uca’s, progressive 3 leaf pack from Toytec, and a fresh alignment.
    29E39AC4-AEF8-49E9-BA47-41D22D5FA456.jpg FFA3989D-538D-402D-AFAF-39AB966D22EC.jpg
  13. Feb 19, 2021 at 6:41 PM
    dleriche
    dleriche Wanee Warrior
    D.J.
    Leander, TX
    2019 White ORD DCSB AT
    Try adjusting your air pressure first. When I got my skinnies they were at 40 psi, and had similar experience at high speeds. Got home lowered them to 35 and it was much better. I'm now down to 33 cold, which heats up to 35 driving. Seems to be the sweet spot for me. I'm still stock suspension and no other additional weight.
  14. Feb 19, 2021 at 6:52 PM
    TRDTaco420
    TRDTaco420 Chum is Fum
    The Bear
    Tacoville - Canada Eh!
    2019 Mid. Blk. Met. ACLB TRD Off-Road
    Kewl shizz
    I honestly didn’t know which one was hangup and which one was answer. Don’t know why I had to do this and not Toyota. (Other vehicles have it)
  15. Feb 19, 2021 at 7:05 PM
    Cappy
    Georgia
    I spy the Sunshine Skyway Bridge :D
    Are you also at Fort De Soto?
    rgljr831 and Soul Surfer[QUOTED] like this.
  16. Feb 19, 2021 at 7:13 PM
    tedusmc1345
    tedusmc1345 Well-Known Member
    ted
    2018 Tacoma Sport 4x4
    I have 5100 with stock spring, it’s really stiff compare to stock.
  17. Feb 19, 2021 at 7:19 PM
    Cappy
    Georgia
    But what setting are you on? I've read that using stock springs on some settings will make it stiff. The higher, the stiffer.
  18. Feb 19, 2021 at 7:27 PM
    tedusmc1345
    ted
    I have set at 2inch, it’s only stiff at turns. It’s not that bad.
  19. Feb 19, 2021 at 7:38 PM
    Guccitaco
    Guccitaco TRDPro 2020 Army Green
    2020 AG trd pro
    little bit of here and a little bit of that...
    Did you adjust the DD pros?
  20. Feb 19, 2021 at 7:41 PM
    playdixie
    playdixie Miss'ippi fella
    Mississippi
    2019 Cavalry Blue TRD Sport 4WD
    Question for those with the Teton Workshop shifters on the World of Tacomas:
    Has anyone else experienced some issues with the ring under the knob getting loose and sliding down?
    This is just a stock image obviously, but this is what I'm talking about. As a side note: I also have the Meso chrome delete ring over it. I've taken the Meso part off and loose with the factory part.
